      04-10-2014, 09:44 AM   #1
Imran@Evolve
Imran@Evolve's Avatar
Drives: All of them
Evolve Carbon Airbox and Evolve Alpha N tune installed by VAC
VAC recently installed an Evolve Carbon Airbox and Evolve Alpha N tune on a Z4M.
Here are some pictures of the install and dyno graph which shows over 300 WHP on their Mustang dyno which reads lower than a dynojet.
Will share some feedback from the customer when I have some.
      04-10-2014, 12:31 PM   #2
dorifto88
Drives: 88 Nissan Pathfinder
looks awesome! are there no other mods (such as headers, for example)?
      04-10-2014, 12:32 PM   #3
nekky
Wagon life
nekky's Avatar
Drives: '16 328d M Sport Touring
My bet is that catless headers are already installed, but you'd know better than me!
      04-10-2014, 12:38 PM   #4
dorifto88
haha ya he has headers and cams installed
      04-10-2014, 09:36 PM   #5
z4msteve
Drives: '07 Z4MC
I dyno'd 296/228 on a Mustang with just Euro headers, stock airbox and stock cams w/ Epic tune. The AFR looks kind of high there.
RPI scoop, Euro headers, SS PowerLoop, Epic race tune, AKG motor/trans mounts, Turner camber bolts
      04-11-2014, 10:40 PM   #6
Walkurie
Walkurie's Avatar
Drives: 06 M Roadster / 99 Jaguar XK8
EAS pulled 318 whp on mine with the Evolve box, tune, Euro headers and Euro cats. Stock cams.
      04-15-2014, 04:06 PM   #7
DRedman45
DRedman45's Avatar
35
Drives: E86 //M coupe
Not to be a pessimist, but I find these dynos completely pointless without a baseline, either compared to stock or just pre air box
2007 //M Coupe. BSM. Fabspeed headers. Catless. BMS x-pipe. Strömung cans. evolve tune. Turner CSL airbox. Airrex air suspension with autopilot v2 management.
My Build Thread
      04-15-2014, 05:29 PM   #8
fullerra
fullerra's Avatar
14
Drives: 08 Z4M Coupe
test test  [0.00]
2008 BMW Z4MC  [0.00]
Unfortunately you are right, which is why I was none too pleased to hear that one was not performed, especially as I both specifically requested it to be done, and because they promised me several times that it would.
With regard to the mustang dyno question, a quick google search finds that on the S65, there is a rather large spread on the mustang, with stock whp ranging from 305 all the way to 360. http://www.s65dynos.com/
Next week I'll be taking the car for a dynojet readout, not to flatter myself, but they seem at least to be a bit more internally consistent with each other, as to compare apples to apples, and not apples to bricks (poor attempt at a bit of humor)
      04-15-2014, 09:28 PM   #9
Walkurie
Walkurie's Avatar
The baseline stock S54 readings are well documented on this forum. They typically run between 265 and 280 whp. EAS confided that most are in the 265-275 range. The conversion factor to crank HP has also been documented to be between .85-.86. Euro headers typically account for 10-15 whp.
      04-15-2014, 09:41 PM   #10
fullerra
fullerra's Avatar
14
test test  [0.00]
I remember seeing your Dynojet plot back in January. I guess we, will see how it does next Monday on the Dynojet over here in Mass.
Either way, I am happy with the results... Absolute horsepower was not the goal, as I wanted to keep the car NA.
btw, I posted in the other thread that I am seemingly unable to blip the throttle for a heel-toe with this particular tune, any thoughts on this?
      04-16-2014, 08:18 AM   #11
Walkurie
Walkurie's Avatar
Dunno about the heel and toe. Mine is pretty responsive. Keep in mind we have climates that are very different. I do have the strange idle surging when it is cold and I put my foot on the brake. Other than that, it is fine after it warms up. Contact Imran, he may be able to do something about it. I do know they will adjust every installation. For example, all we can buy here is 91 octane, so he took that into account. Yes, I had to sacrifice a few hp but the tune matches perfectly. Had slight pinging under load before the tune, none now.
      04-16-2014, 08:32 AM   #12
DRedman45
DRedman45's Avatar
35
That's still not what you really want to compare to have really solid comparisons....dynos and conditions vary, and can throw readings by a long shot...my previous car dynoed 275 on one dyno and 330 on another so I take dyno results with a grain of salt
My Build Thread
      04-17-2014, 08:38 AM   #13
Walkurie
Walkurie's Avatar
Maybe the .5 second improvement in 0-60 and the 1 mpg improvement are also subject to doubt.
      04-17-2014, 12:59 PM   #14
Beedub
Evolve rock !! very nice people, id like to see them back off the lean AFRs however.... i know they have a strategy to deal with the higher AFR but i just don't like seeing mid 12 at redline.....
      04-17-2014, 05:39 PM   #15
angelr
mid 12's on an na car doesn't seem too aggressive to me. I ran cars on 40 psi that lean....12's are normally what give best mean tq on pump gas in an na car. Some want leaner than that.
      04-17-2014, 08:26 PM   #16
Devious21
Devious21's Avatar
No_Country
38
Drives: 2006 Z4M
Do you get a sudden loss of power w/ WOT around 6k RPM?
|Evolve Airbox - Euro Headers - Strömung Exhaust - H&R Coils - 19" BBS CH-R|
      04-18-2014, 09:33 AM   #17
Walkurie
Walkurie's Avatar
No, it pulls strong right up to 7900.
      04-21-2014, 03:42 PM   #18
fullerra
fullerra's Avatar
14
test test  [0.00]
Just had a Dynojet run performed. 334whp SAE corrected (Uncorrected was 349whp)
I will post the plot once I get the info e-mailed to me. (Their printer was out of ink)
      04-21-2014, 03:43 PM   #19
angelr
Very awesome.
      04-21-2014, 03:49 PM   #20
fullerra
fullerra's Avatar
14
test test  [0.00]
This is with:
RPI Scoop,
Evolve CSL Airbox,
Schrick 288/280 cams,
Evolve R Tune,
Turner Underdrive Pulleys,
Fabspeed Headers,
DKF Section 1, running Hi-Flow Cats,
RPI Exhaust
      04-21-2014, 03:55 PM   #21
Beedub
please man, post a detailed sound clip!! PLEAASSEE
      04-21-2014, 10:53 PM   #22
seank
enthusiast
seank's Avatar
48
What do you mean? Are you saying 12 is lean or rich.
