08-15-2011, 03:17 PM | #551 |
Engineer
216
Rep 2,122
Drives: M235I 2015, 335i 2011
cliffhopper Thank You for letting us use your car for the test. We appreciate!!!
08-15-2011, 03:18 PM | #552 |
Engineer
216
Rep 2,122
New pictures on page 25
08-15-2011, 03:55 PM | #553 |
Rep 648
Sweet, thanks. Glad you are going with the 3 1/4" Eisenmann tip style. I would have already bought that exhaust if it weren't for the cost...$2300 for only mufflers is a little ridiculous IMO.
Le Mans Blue '09 BMW M3 Sedan - Current Polar Silver '04 Porsche GT3 - Gone Persian Blue '08 Lotus Exige S240 - Gone Space Gray/Imola '08 BMW M Coupe - Gone |
08-15-2011, 03:58 PM | #554 |
Engineer
216
Rep 2,122
The price is not set, and for the GB will be even better.
08-15-2011, 05:38 PM | #555 |
Rep 784
Drives: 2011.5 E90 M3
08-15-2011, 06:41 PM | #556 |
Rep 1,543
Can't wait for this exhaust system. I've been putting off my exhaust purchase for a while. Excellent job Dio! It must have been a long journey to get here and I've been watching this thread since the beginning.
Not pushy but I hope the group buy will start/close before X'mas so I'll be out of money to buy gifts for THE relatives... |
08-15-2011, 07:39 PM | #557 | |
Engineer
216
Rep 2,122
08-16-2011, 04:44 PM | #558 |
Rep 987
It's an old post but I think TheBroker needs to go back to school if you don't understand a decrease in flow velocity given a larger diameter exhaust.
08-16-2011, 05:13 PM | #559 |
Engineer
216
Rep 2,122
Never said I did not understand, this was taken in consideration and the size we chose was the most adequate while maintaining thermal efficiency. I don't think we need to get on this and elaborate more since many factors were examined when we designed this. it's all about the product and it's functionality on the end.
08-16-2011, 06:10 PM | #560 | |
Rep 987
Diokaef I was totally agreeing with you (not the other guy)! Looks like a great product! How will weight compare to OEM? |
08-16-2011, 06:20 PM | #561 |
Engineer
216
Rep 2,122
08-16-2011, 07:19 PM | #563 |
Engineer
216
Rep 2,122
The GB will be by sections. example: Sec 1 S-pipe with cats/resonators/bypass pipe and Sec 2 X-pipe and mufflers.
08-16-2011, 07:56 PM | #564 |
Engineer
216
Rep 2,122
Any question about the pictures that I posted on page 25?
08-16-2011, 11:43 PM | #565 |
Rep 987
Yes. What is the cell count of the available cats? Do you anticipate having to push in any of the heat shield to avoid rattling? Do the resonators have O2 and EGT bungs? Do the quick releases utilize gaskets? Will the system come with all gaskets necessary or will we be instructed to purchase oem gaskets (like for the header). And have you actually tried to connect and remove the cats with removing and reinstalling the sensors. It seems it might be a bit tricky with having enough slack and the wires twisting too much during install. Seems you would have to install the O2 bungs first while pretwisting the wires in the opposite direction to avoid over twisting the wires when the sensor screw on and THEN connect the pipes last. The EGT sensor is easy since it doesn't twist the wire when u tighten it.
08-17-2011, 10:09 AM | #566 | |
Engineer
216
Rep 2,122
Removing the O2 sensor is not difficult because you can twist the cat itself before conecting with the quick release on the full system but is a bit trick ifyou keep the OEM X-pipe because you would have to atach to the oem X-pipe first. I hope this answer your questions. |
08-17-2011, 11:26 AM | #567 |
Rep 987
Thanks! I really hope I like the sound.
Did you try fitting resonators in the first part of the S pipe? In my former E46 setup I had resonators AND cats in the S pipe to limit the rasp. Also will you accept any special requests during the group buy (for additional cost of course) For example: adding a resonator somewhere in the piping. This may be unnecessary but I'm just asking in case the raspiness is still a bit much for me. I understand special requests may be too difficult to add but I thought I'd ask. |
08-17-2011, 11:41 AM | #568 | |
Engineer
216
Rep 2,122
08-17-2011, 11:44 AM | #570 |
Engineer
216
Rep 2,122
Also I don't see the need to add extra resonators with the cats. This will be in production what make us not able to add special request. Sorry
08-17-2011, 11:47 AM | #571 |
Engineer
216
Rep 2,122
The 300 cell is made to fit our x-pipe but also the OEM x-pipe, the 100 cell will only be sold to be used with our x pipe.
08-17-2011, 11:57 AM | #572 |
Engineer
216
Rep 2,122
300 cell cats to be used with Our X-pipe or OEM X-pipe.
Tags |
catalytic, exhaust, headers, muffler |
