05-23-2021, 01:17 PM | #1 |
Rep 170
Restore Ragtop
I have a 2003 BMW Z4(Still runs great and low miles), and I would like to know if there is any way that I can restore the ragtop. It's not faded, ripped, or has small holes. It's got sticky junk along the ribs, and I would like to bring it back to life short of spending 1500 for a new top. Ideas/suggestions?
Thank you. |
05-23-2021, 02:22 PM | #2 |
Rep 779
Prob need to clean slowly.. mine was full of green / algae.. chemical warfare failed. I saw a few online cleaner use steam cleaning on the top. That might be the way to go. I did not have a steam cleaner and no one I knew had one.. I end up using renovo to dye mine
Photos @ https://www.zpost.com/forums/showthread.php?t=1814316
-Roranji
05-25-2021, 09:37 AM | #3 |
Rep 63
My 2003 black top was not damaged, but was beginning to fade. Cleaned with the top cleaner from BMW followed by Renovo. Used about 2/3 of the bottle. Not new, but close to it. Still a bit of fade along the support bars. Will reapply later in the fall.
05-28-2021, 01:11 PM | #4 |
Rep 1,247
My tan top was a little dirty when I bought it and not repelling water at all. I used the 303 kit and it worked very well. I used a soft brush, but be careful as it can cause it to pile a little if you brush too hard or aggressively. I used my hand for as much as I could and used the brush for a little extra where needed.
The protectant works great and water beads up like a freshly waxed car when you are done. Just make sure you get it clean before you seal it. When applying - I bought some super thin/cheap huge drop clothes from walmart. Open your roof a bit and stop it then slid the drop cloth in and let it hang out of the windows and over the windshield and close the top on it. Now 75% of the car is protected and you just have to cover up the trunk. Works great.
06-28-2021, 12:12 PM | #5 |
Rep 170
What products should I be using? I was looking at the 303 kit that you were speaking of but all I could find was used for tires and such and nothing to do with ragtops. Also, I'll look into steam cleaning as well. Thank you all VERY much.
06-28-2021, 02:49 PM | #6 | |
Retired
96
Rep 174
https://www.goldeagle.com/303-convertible/ |
