06-18-2021, 03:43 PM | #1 |
Rep 232
Z4M- inspection I question
I need to get this service done this summer.
Currently sitting at 33K with zero issues. Aside from the glorified inspection, and valve adjustment; should I look at getting a Vanos repair kit at this low miles? Thanks - AC
'06 Z4MR
Black sapphire / Imola |
06-20-2021, 07:45 AM | #4 |
Rep 208
Drives: 08 Z4 M Coupe
The VANOS will start rattling before you need to address it. It usually starts between 2-3k rpm and gets worse from there. Given the low mileage, you probably don't need to worry for a while. You could consider the VANOS a "while you're in there" job when doing a valve adjustment, but the labor and parts costs for VANOS are considerably higher than taking the valve cover off.
'08 Z4M Coupe | Space Grey/Imola Red Extended/Carbon Leather | Eventuri Intake | Strömung Exhaust | Strong Strut Front/Rear Braces | 19" E46 M3 ZCP Wheels
kaybat125.50 |
06-20-2021, 10:04 AM | #5 | ||
Rep 2,866
Drives: Anything
racerbruce3853.50 |
06-20-2021, 05:01 PM | #6 | |
Rep 232
Can you expand in this...what YM , etc... |
06-20-2021, 09:50 PM | #7 |
Rep 2,866
Drives: Anything
Some times during the 2007 built cycle, BMW was aware of the VANOS cam sprockets bolts shearing off and replaced it with supposedly an "updated" version that comes with locktight on the thread. If your bolts have a hex head, it's the older version and that was the version that was prone to shearing off. The newer updated version have a torx head.
racerbruce3853.50 |
06-20-2021, 10:35 PM | #8 | |
Rep 232
06-25-2021, 02:54 AM | #9 |
Rep 975
