      07-30-2013, 11:14 AM   #1
alpwhite46
Drives: 2013 X3 35i Mpkg
Headlight restoration
Just picked up my new ride... going to be posting pictures of it soon.
So i really did not like how the headlights looked and decided to take my time on them.
Took about 1.5 hours on each headlight.
I did sanding to start, starting with 800 grit, proceeding to do that about 15 minutes, then 1000, 1500, 2500 grits...
After that was done, i washed the headlights and felt if everything felt smooth.
I then proceeded to use the turtle kit from canadian tire which is great.
It comes with the headlight plastic polishing kit, and used a microfiber cloth.
This part takes a lot of patience, and time and hard scrubbing with your hand if you do not have the tool...
Anyways after that was done, there is also a cleaner bottle that you apply after... and after that the sealer cloth which makes your headlight not turn back to crap after a few months!
Here is a before of front left headlight... notice the buildup at the top, and the whole left part of the light
(dont mind my dirty bumper)
the other light
progress... left part completed, right side of the light not touched (although the right part is after sanding...)
and the finish
      07-30-2013, 12:20 PM   #2
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6159
Nicely done Just did this on my car a couple weeks ago using only the turtle wax kit, it came with a few sanding pads and chemicals. I spent maybe 30-45 min doing both by hand and most of the oxidation came off, however a few small stains remain. I suppose using a power tool would be best, my fingers were killing me when I was done
      07-30-2013, 12:22 PM   #3
Z@T
Pilot
Z@T's Avatar
Drives: M3, Vantage, 997, ModelX
Wow! Good job!
      07-30-2013, 03:58 PM   #4
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
you should replace that bumper
The Raspinator
      07-30-2013, 08:18 PM   #5
MZHammer
MZHammer's Avatar
45
Drives: E85 Z4M, F82 M4
2016 M4  [0.00]
2006 BMW Z4M Roadster  [0.00]
Nice job!
      07-30-2013, 08:50 PM   #6
alpwhite46
Thanks guys!
Yeah the bumper was dirty from the sanding, need to clean it... but yes it also has a lot of rock chips and that crack!
What can i get as a replacement instead of this bumper? would an M-bumper be a direct fit?
if not i'm thinking of just getting a regular bumper or fixing and painting this one
      07-31-2013, 12:55 AM   #7
papitosabe
Drives: '06 Z4 Coupe
we're different than the M guys, so we can't put M bumpers on. The good stuff is only meant for them
      07-31-2013, 06:12 AM   #8
alpwhite46
haha , i wish there was a lip that is easy to find for the car !
      07-31-2013, 08:24 AM   #9
THE JEDI
Drives: 2005 Z4 2.5i
Yeah me too this weekend
      07-31-2013, 11:21 AM   #10
nate96
Drives: TI Silver 06 Z4 Coupe
Not trying to hijack. I did this earlier this spring using the Mequire's headlight restoration kit. It took about an hour and a half. The headlights look brand new.
      07-31-2013, 01:06 PM   #11
Pheonix
2007 BMW/Z4MC  [0.00]
Nice job guys! Get the Restoration Kit (with attachment for a drill) and your hands will thank you.
      07-31-2013, 01:39 PM   #12
Drives: M2 Comp
      07-31-2013, 03:14 PM   #13
Z@T
Pilot
Z@T's Avatar
Thanks guys!
The Aero front looks almost better (lower) in my opinion and is a direct fit.
Another benefit when you want to sell your car, OEM front and not a M mess up
      07-31-2013, 04:24 PM   #14
alpwhite46
hmm wonder where i can get the Aero one?
      08-01-2013, 04:20 AM   #15
THE JEDI
I'm going to do mine this weekend, wife said she would help
      08-01-2013, 05:11 AM   #16
Shipkiller
Shipkiller's Avatar
Drives: Me
I think you need to do a little forum searching. Putting ///M bumpers on non-M's is a direct fit.....and has been accomplished numerous times.
      08-01-2013, 10:59 AM   #17
tom_48
BMW Novice
tom_48's Avatar
Drives: M Coupe
2007 M Coupe'  [0.00]
Is there a way to restore very lightly fogged headlights without the use of tools-using just some products?
      08-01-2013, 05:06 PM   #18
alpwhite46
Hey Tom,
If they aren't pitted like mine were, there is no need for the sandpaper.
The best way to do it then is turn your HID's on... let them sit for about 5 minutes so that your lights warm up..
Then use a microfiber cloth and proceed with the plastic polishing compound.
You will need to put some pressure and scrub for a good 15-20 minutes. See if that helps.
      08-02-2013, 12:59 PM   #19
tom_48
BMW Novice
tom_48's Avatar
Drives: M Coupe
Hey Tom,
Thank you, I will try that and see the results!
      08-02-2013, 05:38 PM   #20
Z4inAZ
Drives: Z4 2.5 03
You will always need sandpaper for a lasting finish. Otherwise the good look is only temporary until the plastic polish washes away in the rain.
Its really very easy... wetsand from low grits (coarse) to higher grits until 3000 grit or so. You dont need the "kit" with the drill attachment and many people recommend against using it.
Because the headlight's UV finish is being sanded off, its important to apply a UV clearcoat to the headlight when done. This is generally done instead of plastic filler since they do the same things. Some people use mineral spirits on thicker clearcoats to help it smooth out and lay flat.
Also OP, it will cost way less to fix the current bumper than it will to buy a new one, unless you get a good deal on one that comes painted the correct color
      08-02-2013, 05:53 PM   #21
alpwhite46
If you use the sealer, it won't come back..
Sand paper is not what makes it have a "lasting finish".. it will just make it more smooth and looking new.
      10-12-2013, 11:05 AM   #22
CC1980
Drives: Z4 3.0si coupe e86
3M headlight restoration on my e86
Just thought I would give some feedback with regards to the 3M headlight restoration kit I used on my E86 this morning. It was easy to use and the instructions were simple to follow. For a first attempt I think it was a success. I could have given it another once over with the polisher but the rain was coming. (There is some fluff from the cloth visible on the headlight, not scratches )
