06-16-2016, 12:22 PM | #23 | |
Rep 1,373
07 Z4 M Coupe AW/IR |
06-16-2016, 12:44 PM | #24 | |
Rep 11,667
The link you have now may be too long as it mounts center bar to strut tab. The GC link mount is on top, so the link will be shorter by at least 3-5 cm. Not a big issue as links can be had in just about any length. Edit: I see that GC does do custom length adj. end links. You might want to contact them to see if they can adjust your order. If you give them the length of where your links are set now, they should be able to factor for the reduced length in their design.
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 06-16-2016 at 01:00 PM.. |
06-16-2016, 01:43 PM | #25 | ||
Rep 1,923
06-16-2016, 02:14 PM | #26 | |
Rep 11,667
I'm sure your JRZ tabs as similar to my MCS. my end links are about 8.25" with the bar set close to 90deg. The GC link required will be considerably shorter.
06-17-2016, 01:28 PM | #27 |
Rep 11,667
Got a bit better information from Donavan at GC
" Hi Ian, The front bar is 1.25" OD and rear is 1.15" OD. The oem bar diameters are 27MM front and 22.5MM. We tailor our swaybar endlink lengths to suit our customers needs and damper brand. Donovan "
06-18-2016, 02:01 AM | #29 |
Rep 5,327
seems like they've made some changes over their end then....
06-18-2016, 08:58 AM | #30 |
Rep 11,667
Looks like it .
It's still like pulling teeth to get full disclosure though. They have 2 front bars. I asked what was the relative stiffness difference between them as compared to stock. The reply I got back was..... " The bars are hollow, so the outside diameter doesn't change with the different sizes that we offer. The inside diameter and wall thickness changes. " SMH
06-19-2016, 08:14 AM | #31 |
Rep 5,327
they are useless and they wouldnt get my money for that reason.... they do everything to NOT answer your question, when they do... its nothing to do with ur original question!!
06-19-2016, 08:38 AM | #32 | |
Rep 11,667
Leaves me feeling the same way...... I was contemplating changing for the weight savings in the hollow bar & the easy adjustment.
06-30-2016, 12:37 AM | #33 |
1621
Rep 4,294
just got the bars in the mail today. woot!!
and started to recondition them straight off.. The end links are actually very short.. They are extended atm at max (or so) length, so making them shorter will be no issue..
Powered by |
06-30-2016, 02:03 AM | #35 |
Rep 5,327
recondition them??
vane really interested in this install so keep us posted and take lots of pics where you encounter issues, if any at all.
06-30-2016, 02:06 AM | #36 |
1621
Rep 4,294
Lol yeah mate, those pics are after the reco.. they didn't arrive like that.. too funny
Ofcourse mate, wildo.
Powered by |
06-30-2016, 02:15 AM | #37 |
Rep 5,327
the parts looks excellent quality!!
