      08-28-2016, 12:12 AM   #1
dschultz
dschultz's Avatar
26
Drives: 07 Z4MC
TCK D/A install questions
I'm in the midst of installing a set of TCKline DA coilovers this weekend that I picked up used. My questions are about the rear spring perch.
I understand the official install is to put the perch on the bottom, directly on the spring carrier. Like so: (not my picture)
This metal-to-metal contact with the adjustment tube seems a bit suspect to me. I see that some people suggest turning the spring upside-down and putting the adjuster at the top. Any reason to bolt the adjuster into place through the wishbone, as some have done?
Also, I don't have the set screws used to keep the collar from turning on the adjuster. Are they necessary?
Appreciate any advice from folks that have experience with this suspension.
      09-15-2016, 10:59 PM   #2
seank
enthusiast
seank's Avatar
48
I have ground countrol height adjusters on mine, so i can not assist. I suggest getting a spring adjuster for the rear.
      09-18-2016, 11:00 AM   #3
dschultz
dschultz's Avatar
26
Drives: 07 Z4MC
Thanks. I have a set of the (very trick) GC adjusters too, but they don't properly fit these springs. I discussed with the shop that did the alignment and corner balancing for me. They are very familiar with the TCK setup and said it worked well, so I just went with it. So far all good.
      09-18-2016, 04:29 PM   #4
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
I didn't notice it slowing you down much last Sat from the passenger seat.
      09-19-2016, 11:07 AM   #5
2282
If you really want adjusters you should look at the Rogue ones, those might work with your springs. I've yet to mess with my height after getting the car balanced. Luckily TCK's at lowest setting still provide enough practical ground clearance.
      09-19-2016, 12:34 PM   #6
Finnegan
Finnegan's Avatar
The Rogue ones are nice, the Ground Control are pretty much the same. (Ground Control actually put theirs out to market several years before Rogue.) The problem is the ones he has are for a different spring diameter than his TCK kit.
      09-20-2016, 12:09 AM   #7
dschultz
dschultz's Avatar
26
Drives: 07 Z4MC
Interesting that the pic of the spring perch on the Rogue site is with a TCK spring so I assume those would fit. I'll have to revisit this at some point, but I'm in no hurry to pull the rear springs again.
      09-20-2016, 12:10 AM   #8
dschultz
dschultz's Avatar
26
Drives: 07 Z4MC
      09-20-2016, 01:45 AM   #9
Finnegan
Finnegan's Avatar
Sorry, I wasn't clear, G/C has two sizes, 2.25" and 2.5". I'm guessing Rogue has the same. What's the inner spring diameter for the TCK?
I'm heading over to G/C Wednesday so get me whatever questions you have and I'll be happy to run them by Jay.
