      08-17-2022, 11:21 PM   #45
NLE
Drives: BMW M3 & Z4M
Reviving an old thread.
Are our oem / stock post-cat o2 sensor tables long enough to route those post-cat sensors after the secondary cats in section 1?
      08-18-2022, 06:53 AM   #46
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
2022 BMW X3 M40i  [10.00]
2011 BMW 135i  [10.00]
2007 BMW Z4M Coupe  [10.00]
1991 BMW 318is  [10.00]
Yes, it requires opening the wiring loom and re-routing down the driver side of the transmission tunnel vs the stock passenger side configuration. Documented in this thread here, can check out these videos as well from another forum member
David701567.00
      08-22-2022, 12:31 PM   #47
NLE
Is there any downside to running catless headers without a tune and keeping the CEL (aka any lack of performance or harm)? Seems like the CEL cannot be coded out easily like the e46 M3 and will require an actual tune or custom tune.
Alternatively, what's the go to tune to just get rid of the CEL for catless headers?
      08-22-2022, 01:19 PM   #48
Steeler
Steeler's Avatar
2430
Severn Tuning will find power for you with any modification from stock.
CEL should not be an issue to code out either.
      08-22-2022, 02:17 PM   #49
NLE
Can you share more details on how the CEL can be coded out without actually using a tune?
      08-22-2022, 02:19 PM   #50
Steeler
Steeler's Avatar
2430
I mislead I guess with my statement.
As part of a tune only.
      09-13-2022, 09:15 AM   #51
pal
pal's Avatar
433
Drives: Z4 M Coupe
If you relocate the post cat O2 sensors to the cats under the car, you won't need a tune or have any codes.
David701567.00
