01-21-2016, 01:29 PM | #1 |
Rep 870
Drives: 2006 BMW Z4M Roadster
2016 Z4M
Woohoo! I feel like I traded my 2006 Z4M roadster for a 2016 Z4M. I know a lot of this is old hat for you guys, but for anyone just getting into the Z4s and Z4Ms, I highly recommend the Vibra Technics engine mounts, Rogue transmission mounts, weighted shift knob, and throw that dang CDV in the garbage. I also had a valve job, engine mounting bolts replaced, and all fluids replaced. Just got the car back a few minutes ago. Wow! The car is like a brand new one. I am loving it! Shifting 1st to 2nd is now a pleasure, and none of that weird CDV-induced 2nd gear weirdness. You know what I'm talking about.
I also had the grease applied to the differential input flange per the service bulletin, and yeah baby, NO MORE CLUNK! Doing a wiggle dance. And if all that weren't enough, we installed the Strömung exhaust, and now I can't keep my foot out of the pedal. It sounds awesome. Salty
01-21-2016, 01:41 PM | #2 |
Rep 1,107
Very cool. How would you describe differences made by the engine and transmission mounts? My tranny has luckily been one of the good ones, no real notchiness on the 1-2 shift.
And yeah, getting that CDV outta there while not a 100% night and day does make it come together much better all the time. Can you point me to the "grease on the diff input flange" service bulletin? I've never heard of that in the 4.5 years I've had the car. I'm looking forward to doing my FCABs and RTABs when it warms up and see how that freshens things up (55k miles) |
01-21-2016, 03:34 PM | #3 | |
703
"It's a brand new car!!!" Good to hear buddy! Well done. |
01-21-2016, 05:42 PM | #4 |
Rep 91
Way to go! Start planning for a mountain trip to explore your new limits!
2007 Z4M Stromung exhaust, CDV delete, Vibra-Technics engine mounts, Rogue Engineering Transmission mounts, Auto Solutions SSK, Bimmerworld spherical RTAB's, BMW STB, SuperPro FCAB's, SS brake lines, Eibach springs, Beyern Wheels, 245/275 Michelin PSS.
2008 135i Barely running. Work in progress. |
01-21-2016, 09:18 PM | #6 | |
Rep 870
Here is a link to the original SB: http://www.bimmerforums.com/forum/sh...8#post28851588 Others have also used Loctite 660 on the splines. I don't think my indy did that -- just the grease. I hope it holds, but right now, the clunk is completely gone. I could keep it from happening most of the time just with shifting adjustments, but it's nice to not have to worry about it. Salty
01-21-2016, 09:21 PM | #7 | |
Rep 870
Salty
01-21-2016, 09:27 PM | #8 | |
Rep 870
Salty
01-21-2016, 09:29 PM | #9 | |
Rep 870
Salty
01-22-2016, 07:51 PM | #10 |
Proud E86M Owner
79
Rep 650
Is all those changes you made like something the dealer would do in an inspection 1 or 2?
I really feel like my first to second gear sucks. Did you just bought the parts and change it yourself? I am very interested in this.
2007 Z4///M Coupe Monaco Blue (Weekend + Track)
2018 S1000RR San Marino Blue Wrap (Weekend + Commute) 2016 Honda CR-Z EX Jet Black (Daily Commute) 2008 Kawasaki ZX6R Plasma Blue (SOLD) 2008 Z4///M Roadster Space Gray (SOLD) |
01-22-2016, 08:08 PM | #11 | |
Rep 2,866
I did mine in stages. RE transmission mounts were purchased and installed at EAS before I knew about VT mounts. I also had EAS replaced the engine mount bolts with the uprated 10.9 motorsports version at the same time (I brought them the bolts). VT mounts were purchased through the group buy here a while back and got Bullet Performance in Costa Mesa to install that for me. |
01-22-2016, 09:05 PM | #12 |
Rep 46
M-vie!
You know you M guys are creating some M-vie here. I have driven a roadster and a coupe, both M's, and will say that it is a very different experience than my 3.0. That being said, I don't know that i would ever use the 'extra'. But when I read about the M-folks, it sure does stir my curiosity on ownership. Keep writing, and keep driving!!!!
01-22-2016, 09:12 PM | #13 | |
Rep 870
Car had 33000 miles when this was performed. Here's my work list: Known Problems • All fluids need to be changed (capture engine oil and trans oil for analysis—interested in bearing wear and synchro wear. Previous owner died unexpectedly – history of car unknown. Middle-aged gentleman, rarely driven) • Oil was overfilled (Oil uses 5.5 L, not 6.5 to 7 as many think for some reason) • Inspection I never performed (contacted dealership)– some light valve or vanos noise at 2500-3000 RPM – may be normal (was valve noise engine now quiet) • Drivetrain clunks probably beyond normal. Very sloppy. (fixed) • Shifting notchy and noisy (may be normal – know about 1st to 2nd shift characteristics) (completely gone) • Please drive and evaluate • Fluids o Oil change with new OEM Twin Power Turbo ///M 10W-60 5.5L • Have kit with oil, filter, seals, and new plug • Capture sample for oil analysis from mid-stream o Brake and Clutch Flush, Refill, and Bleed o Transmission Oil Replace (Royal Purple Synchromesh, Redline, or OEM?) (Used Redline) • Capture sample for oil analysis from mid-stream • Rarely get 3rd to 4th deny at low revs (gone) o Differential Oil Replace (OEM or Redline?) (Yes - Redline) o Replace coolant? (Yes) o Inspect power steering expansion cable (trombone slide) for leaks and wear against oil pan (Part 32 41 2 283 893) o Oil was over-filled. Anything to check? CPV valve? (upgrade o-ring to Viton) o Fuel filter? • Drivetrain/Clutch o Drivetrain clunking (beyond normal ///M sounds?) Possible issues: driveshaft, cv joints, center bearing, giubo, differential mounting bolts loose, diff flange requires grease? SI B33 04 08 Rear Axle August 2009 Technical Service This Service Information bulletin supersedes SI B33 04 09 dated October 2008. [NEW] designates changes to this revision The differential input flange mating surface with the input drive pinion is insufficiently greased. E82 and E88 (1 Series), all models E85 and E86 (Z4), all models E60 and E61 (5 Series), all models E63 and E64 (6 Series), all models E65 and E66 (7 Series), all models E90, E91, E92 and E93 (3 Series), all models The customer complains that a single cracking or clicking noise can be heard from the rear of the vehicle while engaging a drive gear, releasing the clutch, during load reversal (shifting from reverse to drive, etc.), or when accelerating from a stationary position. This is not a failure of the differential assembly. Do not replace the complete differential. Remove the differential drive flange in accordance with Repair Instruction RA 33 11 021. Apply lubricant [NEW] P/N 83 23 0 443 864 on the input flange mating surface (1), as described in the illustration. Before complete reassembly. replace the input flange seal and collar nut retaining plate as described in RA 33 01 021. Refer to the EPC for correct part numbers, based on model. o Replace CDV with Zeckhausen modified CDV (have part) • Engine o Valve adjustment (shimmed-sounds great) o Inspect vanos (OK) • Bolts (loose, rattle)? (No) • Exhaust hub tabs broken? (No) • Inspect Timing chain guide (good) • Eventually upgrade all parts in VANOS (Dr. Vanos, Beisan, etc – not now unless necessary) o Replace engine mount bolts with upgraded 10.9 bolts and washers (have parts) – were current ones broken or loose? (No) o Replace engine mounts with Vibra Technics (requires tab to be hammered down on mounting bracket) (have parts) o Check for proper torque on strut tower braces and shock mounts. Strut tower braces show signs of movement in the past (don’t think this is the cause of my car’s drivetrain clunk, though it can be in some situations) o Air Filter? (yes) o Spark plugs? (yes - probably OK, but what they heck, we're there) • Suspension o Inspect bushings (OK) o Inspect springs (broken?) and shocks (OK) o If springs broken, upgrade to H&R coilovers? Also Rogue Engineering rear shock mount replacement for future use. – only if spring broken at this point. • Underbody o Passenger side from front wheel well -- looks like tar. Replace wheel well liner. Salty
Aux Port|LED Interior|LED Strip Trunk|Underseat First Aid Box|Stubby Antenna|Intravee II|BMW Oil Change Kit|Top Down Side Panels|Vibra Technics Engine Mounts|Rogue Trans Mounts|Engine Mount Bolts Upgrade|RS Windblocker|Euro Front Plate|M5 Illum Shift Knob|Supersprint Powerloop Exhaust|Gruppe-M Intake|RPI Scoop|Black Grills|19x8.5 ET35 F 19x9.5 ET22 R Sportline 8s PSS| Besian Vanos|CDV Delete Last edited by SaltyNC; 01-22-2016 at 09:19 PM.. Reason: Added info |
01-22-2016, 09:49 PM | #14 |
1621
Rep 4,294
mate, shagged bushes, around 30K for engine and tranny, for me made the most noticeable difference when i had them done on my Z. And your spot on mate, feels like your driving a spanking new car. The connection to the road is awesome.
congrats Salty,
Powered by |
01-23-2016, 08:46 AM | #15 |
Rep 1,253
Drives: F10535, E90M3, E30M3, E28M5
Garage List 2017 Alpina B6 GC [0.00]
2014 535xi M Sport [0.00] 2014 X3 3.5 M Sport [0.00] 2011 M3 E90 [9.74] 2007 Z4 M Coupe [7.00] 1990 M3 [9.50] 1988 M5 [10.00] |
Congrats Salty! You have convinced me, I need to do the same/similar work. When you get a chance can you pm me your Indy and approx cost? The 1-2 shift notchiness is killing me!
Cheers, Chris
ESS VT-1 550 | M24 Oil Cooler | Fall Line Half Cage | RaceTech 4009W | 6 pt Harness | Lifeline Zero 360 Fire Suppression | Rear Seat Delete | Motion Control DA Dampers w/remote reservoirs | 900/650 Hyperco Springs | RD Sport Sway Bars | Brembo 380 BBK | GC Camber Plates | Hoosier R7 | Eisenmann Sport | Stack Gauges | Painted Challenge Front Lip | Painted ZCP Rear Spoiler | Xpel Ultimate Film | LuxAngelEyes |
01-23-2016, 10:53 AM | #16 | |
Rep 870
Salty
