01-08-2016, 03:39 PM | #1 |
Seasoned Novice
Rep 54
Front Tire Wear Pattern
Is this normal front tire wear (inside shoulder gone)? Michelin Pilots with (guessing) 25-30 K on them. I knew they we about due but was alarmed to see cord showing on the inside when I had the wheels off this week. Thanks, HDK
.HanK.D.KranK. <<<<<<<<<< |
01-08-2016, 05:57 PM | #3 |
Rep 11,667
Actually, neg camber in combination with too much toe.
I run neg 3.2 camber with no such wear, but I'm also running zero toe.
01-12-2016, 02:47 PM | #5 |
Rep 2,138
Drives: Me
inTgr8r is correct.
But, I think each suspension is a little different. I also run zero toe but when I set my camber above -2.7 I get the same very high wear on the inner shoulder of the tire. When I back it down to -2.5 all is good. Please, if you can or know, report what your alignment settings are. |
01-12-2016, 04:38 PM | #6 |
Seasoned Novice
Rep 54
I plan to have FCAB's replaced and new tires all around tomorrow. Friday I will take to get aligned. Have already been to frame and alignment shop and discussed with them. They are old school and will work with me. From what I have learned so far, I think zero toe and slight camber is what I will go with. I just am not certain what camber will be the best. Car is Daily Driver and may autocross once or twice a year. I will sacrifice competitive handling for better tire wear. I was thinking camber of -1 or so but it sounds like I could go higher, say 1.5 to 2. I will see what it measures before changes and go from there. Thanks for the replies and I will update.
Questions: My FCAB's are worn/cracked but not total trash; could they affect to such degree? Is there a recommended camber?
01-12-2016, 05:33 PM | #7 | |
Mechanical Engineer
96
Rep 1,025
01-12-2016, 06:44 PM | #8 | ||
703
01-25-2016, 02:03 PM | #9 |
Seasoned Novice
Rep 54
Okay - got new SuperFlex FCAB's and installed. Got new Cooper Zeon RS3-A tires all around. Took to alignment shop this morning and they told me front camber is -1.25 on both sides and toe is at zero (very close to those #'s). They did not change or loosen anything. They had car for 45 minutes, drove it, and told me there was no charge, just come back again. Went to Dallas Frame and Alignment - they had a Kenworth in next stall - cranking on it's front end. Good guys.
So - either my tire wear was due to FCAB's being worn (one fell apart when removed, one was quite cracked), normal settings/wear, or both. One of those things that I am just now "owning" as I have had her all of seven months and don't know prior two owners. I will just enjoy the drive and monitor my tire wear. Thanks all for the comments and suggestions, HDK.
.HanK.D.KranK. <<<<<<<<<< Last edited by HankDKrank; 01-25-2016 at 02:07 PM.. Reason: add |
01-25-2016, 02:16 PM | #10 |
1821
Rep 5,337
For street use I'd dial in some light "toe-in" rather than zero toe. With zero toe and light negative camber, the camber is going to toe-out when you brake, leading to the accelerated inner tread wear.
Take it back and have them add in ~1/16th" toe-in. Won't affect handling much, and will extend the life of your tires significantly.
01-25-2016, 03:24 PM | #11 |
Rep 2,704
^^^ great tip Hack
01-26-2016, 09:41 AM | #12 | |
Rep 904
01-26-2016, 10:23 AM | #13 |
Seasoned Novice
Rep 54
From what I gather/read, the pins are there to assist the initial assembly. I saw a video of someone driving them out (of an E46) with a hammer and just leaving them out. I noticed that mine have allen heads so may screw out. With the pins removed the stock camber range is somewhat less limited - but (based on reading) don't think you can get much past -1.5. I am guessing year and product models may vary.
Have also read that one full turn of tie rod equates to .24 degrees of toe (again on an E46). I may dial in some toe myself based on further research and scheming. Plan to play with my laser level some and see if I can get some consistent readings based on that or maybe rigging up some toe boards. This (toe/camber/caster) appears to be an area with a lot of opinions, lots of trial and error, testing, compromise, etc.. Science and art... I am learning and will take my time. Thanks for the input - it helps to hear what others do. BTW - really like the new Cooper tires. They are all season and I do believe there will be noticeably less grip on dry surface but ride is improved.
