      04-19-2014, 03:10 PM   #67
Beedub
Originally Posted by tikamak View Post
What's take a seat mean? why do you talk shit i don't understand ?
Anyway, you are probably the reason why i bought this supercharger while i didn't know that in order to use the kit the way that i want to use it, i must pay so much in terms of money, stress, exchanging of parts and testing stuff out to make it work. I hate that you throw comments on your perfect kit that is very far from an ESS kit making people think that ESS will provide this to them if they chose this kit. So i'm here to clarify to all the future owners, DON'T buy this kit based on beedub's comment, do you research first.
I am happy with this kit but i would never ever recommend it to anyone. as simple as that.
Now back to the original comment i have made regarding the rotrex, evolve might be able to provide a PROPER kit that works 100% of the time in every single use you could imagine and that also happens to use a rotrex C38-91 which will make you very happy.
Please don't reply byron, i have no quarrel with you except that i kind of bought this shitty kit due to your perky happy comments that doesn't reflect the amount of work you had to put into it to turn it into a respectable kit.
ill send you some tampons in the post... i think your due. sell the kit and buy something else then... just stop your moaning, its fucking boring, don't get me wrong I'm not mega ess fan ANYMORE, i used to be... but i hardly sing their praises now days and tell it how it is take a look at the last 6 months worth of comments from me, including their own threads on different platforms, but i can't lie, their stuff has been fine with me on the whole, i can't make it up, i CHOOSE to modify the kit for the use i was putting it through, their are plenty of happy ess customers that use their car more normally than gmd for example... either way... I've made my point :-)
What I've learned is NONE of these kits will be up to a proper beating put the box, not ONE, everyone needs to know that imo.
      04-19-2014, 03:12 PM   #68
tikamak
Lebanon
58
Originally Posted by DasGerman View Post
For $9K++ I'd damn near expect close to perfect. I'd CERTAINLY expect NOT to have to replace simple things such as shitty clamps, wrong injectors & plugs etc (which are the ABC's of going FI with every other manufacturer).
I have seen an E92 M3 with an evolve E600 supercharger.
That's a proper kit.
I've seen a ferrari scuderia novitec rosso twin supercharger setup with Rotrex C38-91 and that is a damn fine setup. I have seen it drag with other cars allllll day lonnngggg in 40degrees Celcius heat.
I don't see why ESS can't bring a damn setup that works without all the shit involved. I used to think that it was my beta kit VT2-500 but then i started to see the problems i am facing with the production kit and that's not acceptable to me.
Anyway, apologies to the OP for thread bombing.
      04-19-2014, 03:14 PM   #69
tikamak
Lebanon
58
Originally Posted by Beedub View Post
ill send you some tampons in the post... i think your due. sell the kit and buy something else then... just stop your moaning, its fucking boring.
I don't live to entertain you englishman, i throw logical ideas at you and you come trolling.
Let's just quit this argument, it's better for both of us.
      04-19-2014, 03:25 PM   #70
Beedub
lmao..... you've made my evening brighter here..... I realise I'm entering into a battle of intelligence with an unarmed man.
arty 0030:
      04-20-2014, 11:12 AM   #71
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Happy Easter everyone!
      04-20-2014, 01:12 PM   #72
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
My nyukka
      04-21-2014, 02:13 AM   #73
tikamak
Lebanon
58
Happy Easter to you too.
"Al Masi7ou Kam" means christ has risen in lebanese
      04-21-2014, 04:34 AM   #74
Beedub
Happy Easter everyone !! I love abit of passionate car banter !! Hahaaaaaa :-)
Mfan..... What's so outdated about your blower ?? It's wasn't available in any other trim than s and si?
Ess use the si trim unit, I actually have a spare impeller if you want it ??????
      04-21-2014, 06:35 AM   #75
pokeybritches
2006 BMW Z4M  [8.50]
There's an SCi trim too, optimized for smaller applications. It's a trimmed Si impeller. I've got it on the non-M.
I still think it's something after the blower, especially if he's getting 9 psi at redline.
      04-21-2014, 07:15 AM   #76
Beedub
excuse me, i mean't sci , and si trim... i have a spare Si trim blower, but the Sci trim should actually perform better in the mid range, the Si trim gets better with more boost, the sci should be in more efficiency range @ the 5-9lbs boost range, if you seeing 9lbs on your boost gauge, then the blower isn't the problem....
something else is amiss.....
      04-21-2014, 09:07 AM   #77
mfanatic325
///M-fanatic
Taiwan
193
I honestly have no idea. VF never gives much detail. They just ask for more money and never come up with a real fix. Just bandaid on the wound to cover up the mess
But they said it should be around $400 to get it updated. I just can't afford the downtime on the car
I'm seeing 9psi max output, but my low to mid-range is definitely soft/weak. The ESS-supercharged Z4Ms I've driven were all a lot more eager to get off the line. Mine feels laggy, almost like a turbo in terms of the power build. Not sure if that's just the difference between VF and ESS kits or what.
      04-21-2014, 12:50 PM   #78
pokeybritches
2006 BMW Z4M  [8.50]
When I had a boost leak, my power delivery felt exponential rather than linear. Once I got it corrected, it felt smoother and "right". I know people have checked out the car, but I'd still give it a once over and tighten everything.
Do you have AFR/boost hooked up?
      04-21-2014, 10:14 PM   #79
mfanatic325
///M-fanatic
Taiwan
193
Will do.
Yes, I do have AFR and boost readings both hooked up to my P3C gauge. The AFR signal is provided by the Innovate LC1 wideband controller. However, as of late, I haven't put the P3C gauge back in, since I've been doing a lot of datalogs and tune flashes, etc.
I will check them once the tune is perfected and is out of the way completely.
      11-26-2014, 12:41 AM   #80
ANILE8
ANILE8's Avatar
No_Country
180
Drives: Z4 M Coupé - Carbon Black
Hello mfanatic325, I am very sorry to be reading about the problems and how some forum members might not be very helpful to others.
If another person had a problem after spending so much time and money and I could help; then why not?
It is shocking that VFE are basically wiping their hands of this problem from a good customer who just wants what they paid for.
If I was going FI the VF kit looks awesome and maybe nicer than the ESS counterpart but if you are 100hp down then the problem should be easy to troubleshoot one would think for them.
I know 007M has also bought this kit, not sure how they are getting on as there is no further info on the progress of their install or the results.
Once again this sucks
      11-26-2014, 03:11 AM   #81
Beedub
yeah..... update us on this...
      11-26-2014, 11:58 AM   #82
mfanatic325
///M-fanatic
Taiwan
193
Sorry, haven't been on the forum much at all lately. Ever since about half a year ago, I've been running an independent tune through Frank Smith, and the car behaves a TON better; putting out 440RWHP and 315RWTQ peaks. I'm not all to worried about the top-end power as compared to a supposed 472RWHP and 330RWTQ, as I am concerned about the overall driveability of the car. With Frank's tuning help, the car is much more stable and is much more docile.
For those that have gotten or will be getting VF's hardware in the future, I highly highly suggest you don't waste your time and money on VF's in-house tune. It is complete crap. Go with an independent tuner like Frank Smith or whomever else that has had firsthand experience tuning the MSS70 and that you have easy access to.
For the record, I still like VF's hardware a lot. The fit is so-so, but the finish is top notch. I'm personally still supposedly on the older supercharger blower trim, and perhaps where I lack a little bit of power is in the trim difference. But I've no immediate plans to update it anytime soon. Might wait until it completely goes bad, or otherwise needs rebuilding.
I've also flushed out the water system in the A2W intercooling. I was running a mix of water and coolant, but Frank Smith told me to run water-only, and to make sure to purge the system every now and then of air. I'm now running only distilled water in the independent cooling system and have noticed a slight drop in operating temps.
I have also put in a new LSD unit courtesy of Jim Blanton @ Performance Gearing, and the car puts down power like no other! I was a skeptic before, but after shelling out the money for the upgrade and doing some mountain runs, I was shocked at how the stock LSD could be so lacking in comparison to a "proper" unit
      11-26-2014, 12:09 PM   #83
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Thanks for the update Lon!
I think the better LSD is key to actually using that power effectively.
      11-26-2014, 01:15 PM   #84
Rated M Roadster
Rated M Roadster's Avatar
160
Drives: F10 M5, i3, Z4M
...power as compared to a supposed 472RWHP and 330RWTQ
lol
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX
SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i
      11-26-2014, 03:04 PM   #85
007M
007M's Avatar
17
Drives: '007 ///M Coupe & Boxster S
Yea, I bought the kit too, and the hardware is top notch. The tune is however utter and complete crap. My local race shop went back and forth with them for over a month with absolutely no progress. I spoke with MFanatic325 and he recommended Frank. My shop did separate research during the same time and their connections in the industry said to use the very same Frank Smith.
So, I went with Frank's tune. WOW! Talk about a complete change! Amazing! Without going to redline the car made 420whp on a Mustang Dyno which is 12-15% off of the standard Dynojet. Which means that I'm making 477whp and 494whp by regular calculations. Frank said that from all the S54 engines he's tuned for the vf570 this one had come out the strongest yet and he felt that going the extra couple hundred rpms to redline would've put me at 500-505 whp.
Not only that, but the thing is absolutely behaved under normal driving. Smooth as butter, no stalling, no rough idling... thing of beauty. Then when you step on it... power like mad. I'll be writing up a more complete post on this just haven't had the time yet.
Thank you Mfanatic325! For hooking me up with Frank and saving me tons of headache with continuing to deal with the super unresponsive and super unhelpful VF.
      11-26-2014, 03:58 PM   #86
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
How much boost are you making?
      11-26-2014, 04:03 PM   #87
007M
007M's Avatar
17
10.5 psi
      11-26-2014, 04:04 PM   #88
GuidoK
GuidoK's Avatar
10624
Drives: Z4 3.0i ESS TS2+
It is strange that a company like vf has such a bad tune and foremost bad support.
I mean: they also tune porsches&lamborghinis, for a lot of money.
I wonder if they think bmw z4m owners are not interesting anymore. (older car, cheaper kits). Maybe they only think customers who spend a lot of money (as in: even more money) are interesting enough for their attention?
