      12-18-2014, 10:19 AM   #1
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6155
ECS S54 Service Kit Deal
When the hell did the shim kits get so affordable? I thought these were $400+ alone
http://www.ecstuning.com/News/BMW_Z4...eAdjustmentKit
ECS offering it with all gaskets AND and oil kit for $250? Is this real?!
      12-18-2014, 10:59 AM   #2
SD ///M4
///Multiple
SD ///M4's Avatar
I just saw this in the e-mail from I got from ECS. Shim kit alone is $54.95!
Doesn't look like it has as many shims as the BMW OEM though. Can anyone with an OEM kit compare the contents? (A friend with an E46 M loaned his to me.)
      12-18-2014, 11:09 AM   #3
ECSTuning
New Lifetime Replacement Policy
ECSTuning's Avatar
811
Drives: Independent Tuning Specialists
The Wiseco kit comes with 3 of each size, the BMW kit 6 of each size. Both kits include the same sized shims.
LINK to Wiseco kit
LINK to BMW kit
-James
      12-18-2014, 11:34 AM   #4
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
Is Wiseco the manufacturer of the BMW shims? If not, seems like a bit of a gamble on longevity of the shim.
      12-19-2014, 11:02 AM   #5
Beedub
+100.....
      12-19-2014, 11:16 AM   #6
ECSTuning
ECSTuning's Avatar
811
Wiseco manufacturers very high end performance parts for your cars, motorcycles, snowmobiles, pretty much anything with an engine. The use of this kit is documented over on M3Forum and various other sites. Personally I've used Wiseco shims in the S14 in my old E30 M, and have first hand experience with them in an S38 and a fellow employees E46 M3. I have no problem stating these are high quality products you should expect to perform just like the factory shims.
-James
      12-19-2014, 11:58 AM   #7
jdoublehcubed
Mechanical Engineer
If ECS is assembling these kits, it would be nice to have one specifically for the S54. You generally only need 3 or 4 sizes, at most I think 7 or 8 would cover all possible shims needed. I'd have to look through my records, but I think shims from 2.08 to 2.36 would be all you would ever need for an S54. 3 per size is not enough though, I've done valve adjustments where I needed 7 of a single size, and was reusing other removed shims to finish the job. 8 shims per size from 2.08 to 2.36 would be perfect.
      12-19-2014, 01:42 PM   #8
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6155
I guess I don't feel so afraid taking a chance on such a simple part as a shim, especially when the savings are so compelling. I'll pick one (maybe 2) of these up come inspection time. Cost of S54 ownership is a good deal lower now
      12-19-2014, 03:22 PM   #9
Drives: M2 Comp
^WHS.
I agree there are only a few sizes that are needed and definitely more than 3 of the mid range
Each shim has a different part number.
I ordered just the range I needed.
If ECS did an S54 kit, it would be great!!
      12-20-2014, 12:48 PM   #10
SlickShift
SlickShift's Avatar
No_Country
323
Drives: '11 BMW E90 M3 ZCP, '21 X5 ZMP
Nice find! Is it weird that I'm kind of excited to do the valve adjustment on my car?
-Nick
2018 BMW 440i - M Sport, Exec
Glacier Silver Metallic/Coral Red Dakota
Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i
      12-26-2014, 11:00 AM   #11
heligarret
Drives: 2007 Z4M Roadster
Does anyone know of somewhere I could rent the kit? There was a post along time ago on here and I contacted recently but no reply. Maybe someone knows of someone in the E46 forms that do this. I live in LA area
      12-26-2014, 01:17 PM   #12
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
I was psyched as well after watching one very well done DIY, but then after another one that made it look more complicated I'm now leaning towards paying my Indy.
I figure for a total valve adjustment newbie (me) who likes to work slowly to make sure I get it in "one take" it would take 6hrs. Yes/no?
      12-26-2014, 02:25 PM   #13
SD ///M4
///Multiple
SD ///M4's Avatar
I did mine a couple of months after buying my car in 2012. A friend who owned the kit helped me out. If you've done mechanical work before, it's no big deal. I had done valve adjustments years ago on other cars, but none that used shims. You just need to be organized and careful, check things twice, and be patient. The biggest caveat is to make sure that you have plugged all holes with shop rags or shop towels. You may drop a couple of shims, but as long as everything is plugged you just have to find the shim and fish it out. It took us about six hours but we also stopped for lunch in the middle and took a break.
It helped having a friend who had already done the valve adjustment on his E46 M3, but I wouldn't hesitate to do it myself next time.
      12-27-2014, 11:15 PM   #14
jdoublehcubed
Mechanical Engineer
I'm the one with the rental kit. I just got it back, waiting on a few refill shims to arrive. I'm even in the LA area.
Heres the thread with the info:
http://www.zpost.com/forums/showthread.php?t=763512
      12-28-2014, 03:36 PM   #15
heligarret
jdoublehcubed I was the one who sent you a pm. I live really close to you. Please let me know when you get the kit restocked. Thanks a million. ph 626 200 8372
      12-30-2014, 08:55 AM   #16
jdoublehcubed
Mechanical Engineer
Will do. It will probably be around the end of next week.
