12-02-2014, 12:51 PM | #1 |
Rep 187
winter mode
My Z4MC is officially in winter mode, really. The temperatures have dropped and the doors are now frozen shut, I've tried the usual hair drier trick on the seals with zero luck. My problem is that the windows will not drop down to clear the seals and allow the door to open. I have tried holding the unlock key but the window motors are not able to drive the glass down even if I try to assist them by pushing down on the glass gently.
Does anyone else have any tricks? I'm daily commuting in my e30 directly into the sun and my prescription sunglasses are locked in the Z!
1990 332i 5 speed (OBD2 S52 Swap)
2018 VW Golf R (6spd manual/copper orange metallic) 2008 KTM SuperDuke 990 2007 Z4M Coupe (#1026/1815) SOLD |
12-02-2014, 01:25 PM | #2 |
Rep 4,051
Pour a bucket of HOT water along the window seals maybe?
Huz-Z
12-02-2014, 01:28 PM | #3 |
Rep 178
Drives: 2007 Z4 3.0i Roadster
Deicing windshield washer fluid & a hair dryer have always worked for me.
Afterwards be sure to dry the seals and coat with light layer of vaseline to prevent further freezes.
2007 BMW Z4 3.0i Roadster / Silver Grey BMW CCA 492691 |
12-02-2014, 02:54 PM | #4 |
Rep 1,134
Drives: '07 M Roadster
I would be very carefull trying to roll down the windows when they are covered in ice. There is a lot of pressure on the glass and you can break the mechanism. Happened to a volvo I was driving a couple years ago. Hair dryer may not be enough heat too, a cheap heat gun from walmart or a hobby store would be faster.
I've also seen somewhere a really good idea of putting a blanket over the car (windows at least) to make de-icing or removing fresh snow a lot easier than scraping it off. Edit: found it. It's made for the windshield, but could just as easily be used for the door http://www.icescreen.com/
12-02-2014, 04:34 PM | #5 |
Rep 187
It's open! A few buckets of hot water and the window finally dropped down, I've driven the car to work for the day to defrost it and applied vaseline to the door seals and inside up top where the window slides in.
I think my go-to solution to the problem is to park the car in a family members garage for this winter. Hoping to have a garage of my own for the vehicles next year. Thanks for the tips!
12-02-2014, 05:13 PM | #6 |
Rep 2,526
Use some Gummi Pflege Stift' Rubber Care. It keeps the rubber supple, reduces stuck doors due to freezing and prolongs the life of rubber by reducing it from drying out. I've been using it for many years, its easy to apply, not greasy and makes the rubber nice and black.
I would not use vaseline since it's known to deteriorate rubber. |
12-02-2014, 05:30 PM | #7 | |
Rep 4,051
Huz-Z
12-02-2014, 05:33 PM | #8 | |
Rep 4,051
Huz-Z
12-02-2014, 07:21 PM | #9 | |
Rep 187
I think part of my freezing problem stems from what appears to be a moisture problem. I had ice all over the inside of my windshield when I finally got inside. I always suspected a moisture problem due to having some fogging when I first got it. The carpets feel dry however, and my condensate drain appears to work ok as when I checked in the summer it would drip like expected.
I always run the car in full auto HVAC, as it seemed to help control the moisture during driving, but maybe that's not a good practice on the Z4? Quote:
12-03-2014, 09:09 PM | #10 |
Rep 56
I have always heard that vaseline or any petroleum based product will break down rubber seals. You also want to stay away from anything with silicone in it. If the BMW gummi pflege (literally "rubber care") is not available, then my choices would be:
1Z Einszett Rubber Care Stick Wurth Rubber Care Gel Stick Zymol Seal
