      05-31-2015, 12:12 PM   #1
Hedward
Hedward's Avatar
Drives: 2007 BMW M Roadster
CDV purchase
'07 MR
Late to getting around to replacing the CDV with a modified Zeckhausen version. As I recall, this was a $30 part in previous threads. Their site now reflects a price of $85 dollars (CDV-007).
Anyone have another source.
      05-31-2015, 12:35 PM   #2
dschultz
dschultz's Avatar
26
Drives: 07 Z4MC
I remember it always being about $75-$80 from Zeckenhausen, but how about this:
http://www.ecstuning.com/BMW-Z4-M_Co....2L/ES2823106/
      05-31-2015, 01:16 PM   #3
Pheonix
2007 BMW/Z4MC  [0.00]
Assuming your car is out of warranty already? Just remove it and be done with; you might need to adjust the hose a little bit. Another option would be drilled out your original and make the ID larger.
No need to purchase anything unless the car isn't under warranty.
      05-31-2015, 03:58 PM   #4
Sliktop
Drives: 07 Z4 M Coupe
why not just remove it? It's a useless part...
      05-31-2015, 04:25 PM   #5
intoflatlines
intoflatlines's Avatar
Drives: Z4MR, E34, E30
I'd never spend $85 let alone $30 for a "dummy" CDV. Just remove the CDV.
      05-31-2015, 08:47 PM   #6
Twixboy
Drives: '04 Z4 3.0i 6spd
My shop just removed mine. Said there was plenty of slack so a replacement wasn't necessary.
      06-01-2015, 02:09 PM   #7
DanFromTucson
Drives: Z4 M Coupe
Or if you want an excuse to buy something new, you can get a stainless steel clutch line. :-)
It requires a little more care in bleeding the system if you replace the whole line. On the plus side, you will see a cool blue stainless line every time you crawl under the car.
      06-01-2015, 07:28 PM   #8
StickMon
StickMon's Avatar
Drives: 2006 MR
No need to buy anything. The male/female fittings are identical, and there's plenty of slack in the hose.
      06-15-2015, 06:53 PM   #9
NWMcoupe
NWMcoupe's Avatar
Drives: 2006 M Coupe
I have one I never used. PM me I can send it to you for a small fee
