04-06-2015, 01:03 AM | #1 |
Rep 162
Drives: 2008 Z4 3.0si Coupe
Coupe Trunk Struts
When I pop open my trunk, I find that I have to assist the trunk lid all the way up. It stays up, but the struts don't seem to push the lids all the way up on their own. Is this normal, or do my struts need replacing? If they do need replacing, what brand/model do I need? RealOEM doesn't seem to specify.
2008 Z4 3.0si Coupe
04-06-2015, 05:19 AM | #2 |
1621
Rep 4,294
You can re gas them, mine goes up by itself. ;-) actually, the nissan I had before this one you could regass them, the bmw ones, I am not sure... hope someone pipes in that knows..
04-06-2015, 06:37 AM | #3 |
Rep 11,667
Is it the same with the tonneau cover open or closed.
It could also be the cover that's binding.
04-06-2015, 11:00 AM | #4 |
Rep 222
I should be able to give you a definitive answer on this, hopefully by next week.
The hatch on mine has been getting a little lazy, and I have been keeping the hinges lubed, so I've got replacement lift struts ready to go in when I've got the time and someone to hold the hatch up while I do the replacement.
2007 3.0si Coupe
Dinan Stage I Suspension (Shocks, Struts, Springs), Ground Control Front Camber Plates, Treehouse Racing Front Control Arm Bushings, RTAB Bushing Limiters |
04-06-2015, 12:07 PM | #5 | |
Rep 162
2008 Z4 3.0si Coupe
04-15-2015, 07:52 AM | #6 |
Rep 222
Finally had a chance to replace the lift struts last night-- my Dad was visiting to hold the hatch up while I changed them. Easy enough job, though it's a bit fiddly getting the clips started back on the strut sockets that hold them in place. You do need an extra set of hands or something to hold the hatch up-- one strut is not enough.
Used to be a bit hesitant coming up, especially if it had to pull the roller shade over the cargo compartment-- it isn't anymore. By hand, can't tell the difference between the old struts and new, but it's definitely different installed. As an additional note, if I'm reading the specs on the strut correctly, these are 480 Newton struts-- that's well over 100 lb of force. I gave up trying to compress the new struts by hand for fear of bending the rods or breaking the end fittings.
2007 3.0si Coupe
04-15-2015, 08:23 AM | #7 |
Rep 11,667
good stuff!!!
A tip for reinstalling them is to slide the clips on part way. Then they just push home from there after the ball is in the socket.
04-15-2015, 09:24 AM | #8 | |
Rep 162
2008 Z4 3.0si Coupe
