BMW 3-Series (E90 E92) Forum
N54 MHI Turbo Data
04-29-2009, 01:59 PM | #1 |
16
Rep 74
N54 MHI Turbo Data
Here's some compressor map data for the turbochargers on the x35 N54 vehicles.
From this we can gather that a pair of these turbos spinning at redline can produce ~1150 kg/hr of airflow, which translates into ~42.25 lb/min. Here's the MHI flow map with efficiency islands. Last edited by DMETune; 04-30-2009 at 01:35 PM.. |
04-29-2009, 02:09 PM | #2 |
Rep 3,735
GREAT fuckin information!!! Been looking for this for a long long time.
High five!
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
04-29-2009, 02:21 PM | #4 |
Rep 1,283
It means that the 335i can push 422.5hp worth of air and 24psi midrange and 18psi(compressor outlet peaks) at peak power while still staying in the compressor map(before choking the turbos) ie anything over 380whp is pushing the turbos beyond factory(mitsu) tested limits
The upcoming Helix direct bolt on turbos can push similar pressures but the power output potential is 570HP we'll get some pics up next week when Ralph and Eric return from Minis on the Dragon |
04-29-2009, 02:30 PM | #5 | |
Rep 518
Thank you so much for posting this. This is great information to have. |
04-29-2009, 02:33 PM | #6 | |
Rep 5,501
2007 E92 Montego Blue 335i
04-29-2009, 02:39 PM | #7 | |
Rep 2,842
I don't think anyone on stocks has dyno'd much above 420 hp except for Terry who hit a peak of 460 hp at 19 psi boost. But that was only for a short burst of 100 rpm. |
04-29-2009, 02:41 PM | #8 | |
Rep 1,283
-the turbos self destruct -you melt an exhaust valve -you melt a piston I personally feel that the tubine size and restriction as well as the wastegate size and design both hold power levels in check thats why we havent seen many issues with the above ^ |
04-29-2009, 02:49 PM | #10 |
Rep 4,764
TTurboBullett - thanks for your input. It would be great to have an upgrade option close by for the mid-atlantic states. Just hope that existing tuning options can map for it.
04-29-2009, 03:14 PM | #12 |
Rep 1,283
I can tune em w an attache no problemo, we already have(have had) a fueling option on the shelf now for about 9-10 months
04-29-2009, 03:15 PM | #14 | |
Rep 4,445
Upgraded fuel system?
04-29-2009, 03:20 PM | #16 |
Read the manual please, just do it before asking!
11
Rep 397
Thanks for the information!
is it possible to make a curve of maximum safe psi boost per RPM from this information? |
04-29-2009, 03:20 PM | #17 |
Rep 4,445
Interesting, I was hoping for an upgraded fuel pump.
04-29-2009, 03:23 PM | #18 |
this space left intentionally blank
15
Rep 293
Hopefully tonight I will make a more recognizable compressor map with the efficiency islands and such. I have all the data I need and have already started plotting it.
I have papers all over my desk with lines drawn on everything, lol. At best, these things don't seem that efficient. |
04-29-2009, 03:23 PM | #19 | ||
16
Rep 74
Thanks in advance |
04-29-2009, 03:35 PM | #21 | |
Rep 1,283
peak boost is shown in the middle of the map as 2.7bar (2.7 x 14.6psi = 39 - 14.6(atmospheric pressure) = 24.8 MAX PSI) max boost at max flow/choke point is 2.2 bar (2.2 x 14.6 = 32 psi -14.6(atmospheric pressure) = 17.52 PSI BOOST at choke point) once someone translates the map to either CFM or Lb/min and puts some efficiency % to the islands I can get as TECH as you want Anything missing? Last edited by TurboBullett@Ambient Thermal Management; 04-29-2009 at 04:06 PM.. |
04-29-2009, 03:37 PM | #22 |
Rep 1,283
those #'s are only part of the equation you need to know vehicle displacement - volumetric efficiency, boost level and RPM to know exactly where the turbos are beeing run at any point in the compressor map
