08-22-2016, 01:30 AM | #1 |
Rep 3
Anyone knows is there a 6 speed manual for E85 2.5i?
Does the 6 speed manual transmission gearbox 3.0i bolt to the 2.5i?
08-22-2016, 01:54 AM | #2 |
#buildnotbought
10979
Rep 4,912
No the gearbox is different so its not a straight swap.
It's shorter so you'll need a different propshaft. Chances are that the selector mechanism is different too and that the clutch wont fit: 6 speed has a 22spline input shaft and with the 5 speed the early ones have 9 spline and the later ones have 22 spline, I dont know what's in the z4. And maybe there are some different brackets for the gearbox mounting suspension etc.
08-22-2016, 04:35 AM | #5 |
#buildnotbought
10979
Rep 4,912
SMG might be mechanically easier, as that is dimentionally the same as the 6spd manual. (but you obviously need the gear selector mechanism)
But I dont know about the electrical consequences. It might be tied into the ecu etc. generating fault codes when the smg is missing.
08-22-2016, 09:54 PM | #6 | |
Rep 758
Top Down 365
08-23-2016, 04:29 AM | #7 | ||
Rep 2,287
