02-13-2011, 08:56 PM | #1 |
Rep 396
***RAC Gunmetal RG4 v2/Bridgestone RE-11***
My RG4s are for sale. 19X9" fronts w/ 245/35/19 ET37 19x10" rears w/ 275/30/19 ET25 Unfortunately, a tire installer scratched the h*ll out of a front wheel while installing the Bridgestones...I had one front & one rear refinished recently. (I had the rear redone as well so that the finishes on one side of the car would be exactly the same). While the finishes obviously don't match 100%, they are very close. Valve stem caps & center caps are not included. I'm asking $3500 OBO for the complete setup. Buyer pays shipping/paypal fees (Local buyers get priority but I will ship if I can't find a local buyer). The following info is copy/pasted from the original group buy thread: * 6061 T6 HEAT TREATED Aluminum Alloy (currently the best wheel material available) * 8000 TON SPREAD FORGED MONOBLOCK WHEEL * 19 x 9 Front , offset is +37 * 19 x10 Rear , offset is +25 * Wheels have a 72.6mm center hub bore so they are HUBCENTRIC (the fit is perfect, no centering rings needed) * Can accommodate a BIG BRAKE KIT without spacers * Powder-coated in a high quality Silver finish (brilliant) * Can accommodate tire sizes up to a 265F/285R max. * The RG4 wheel weights are: 22.5 lbs front and 23.0 pounds rear * The RG4s are currently only available in fitments for the E46 M3 * Wheels will accept the OEM roundel centercap. (RG4's are designed from the factory to use the OEM E46 M3 centercap) * The wheels will be forged in Japan at one of the finest manufacturing plants in the world, and normally take 30 days just to clear U.S. customs. The RG4 wheel exceeds all JWL & VIA wheel certifications for use on the E46 M3 On to the pics: The bottom 2 rims are the refinished rims, the top 2 are the original rims: Refinished front: Refinished rear: Original front: Original rear: One of the wheels has a few nicks/stone chips: An example of some residual clay/polish that I've been unable to remove deep in the spokes: A comparison of the 2 finishes, the rims on the left in both pics are the refinished rims: Remaining tread on the tires:
02-13-2011, 09:06 PM | #2 |
Rep 396
what they look like on my car:
http://www.m3forum.net/m3forum/showthread.php?t=317542 http://www.m3forum.net/m3forum/showthread.php?t=260116 http://www.m3forum.net/m3forum/showthread.php?t=314589 other e46's: http://www.m3forum.net/m3forum/showt...hlight=RAC+RG4
