      12-17-2012, 06:15 PM   #1
jslym777
Z4M left front lower control arm
USD 200.00
I have a Z4M lower control arm for sale, drivers side. Brand new never used factory BMW part.
      12-17-2012, 07:13 PM   #2
Shipkiller
Shipkiller's Avatar
Drives: Me
If you have a micrometer, would you measure the cross section of the pintal that fits into the FCAB?
I need to know in millimeters what the cross section is.
      12-17-2012, 09:28 PM   #3
jslym777
what do you need the info for? i have no micrometer here.
      12-18-2012, 09:06 AM   #4
Shipkiller
Shipkiller's Avatar
Drives: Me
Z4M's use an offset FCAB similar to the '95 E36M3 and E30M3. What I am trying to figure out if the Z4M front wishbone will fit the hole in the above mentioned FCAB's.
Is it a perfect fit?
Is the wishbone too big?
Is the wishbone too small and requires a sleeve?
The ultimate goal is to find out if we (the Z4M's) can use an uprated FCAB from the older cars or are we stuck with the OEM FCAB.
I do know you 'can' use a centered FCAB but you have to realize that by doing this you change the suspension geometry (scrub and thrust first come to mind) and you WILL ABSOLUTELY have to have an alignment performed after this switch. I have calculated what the changes will be but I am not sure of some of the assumptions.
I am actually willing to go out and buy the different FCAB’s but I need some data first before I attempt this or waist my money.
      12-18-2012, 06:35 PM   #5
jslym777
correct me if im wrong but dont the older models use a circle shaped through hole whereas the z4m uses a hex shaped hole? so even if it did match up it wouldnt fit properly anyways.
      12-18-2012, 06:43 PM   #6
Shipkiller
Shipkiller's Avatar
Drives: Me
That is where a sleeve might come in.
Do not know until I try. No one else is...
      12-18-2012, 07:22 PM   #7
jslym777
what kind of sleeve? i think once you put a sleeve over the rear hex section of the wishbone youd be too big in diameter to fit through an older style bushing. if there was a simple solution im assuming one of the parts companies would have tried that already. I priced a mold to make new urethane bushings for the Z4M's and was quoted $8,000.
      12-18-2012, 07:36 PM   #8
Shipkiller
Shipkiller's Avatar
Drives: Me
That's just it. We DON'T know what the diameter of the Z4M wishbone is....
The first step in this process is to get all the background data...
      12-23-2012, 04:12 PM   #9
jslym777
NEW PRICE - $275 shipped, good opportunity for non M to upgrade as well.
      12-27-2012, 04:25 AM   #10
jslym777
no interest?
      12-30-2012, 07:27 AM   #11
jslym777
new price 250... this is a good deal for OEM
      01-14-2013, 06:59 PM   #12
jslym777
bump
      02-10-2013, 03:30 AM   #13
jslym777
any interest? willing to negotiate a little more if shipping is nearby
      02-26-2013, 01:22 PM   #14
jslym777
ok final offer $225, surprised no one want to upgrade their control arms
      05-27-2013, 09:10 PM   #15
jslym777
bump $200 this thing is still sitting in my garage brand new in the Turner box
      06-04-2013, 08:02 AM   #16
jslym777
this is a steal at 200 brand new
