10-05-2010, 05:25 PM | #287 |
Rep 4,726
I Never had your temp problems, and I still believe your temp problems are likely because you have your primary catalysts, seen it 100 times and most tuners will tell you that close coupled cats cause heat issues like no other.
10-05-2010, 05:37 PM | #288 |
Rep 385
-It's certainly a factor. I plan to do headers at some point, but for the time being both I (and ESS) would want to know how to get a hard-tracked CFR500 (VT, etc.) to run within acceptable heat ranges without the additional mod of headers. If it's a simple change like the diverter valve or a different style of oil cooler, then that would be much easier than a header swap.
10-05-2010, 08:15 PM | #289 | |
Rep 4,726
10-12-2010, 12:50 AM | #290 |
DHS
213
Rep 4,029
Drives: 2023 M4, 2020 Land Rover
Great post and journal. Helped me out a lot. Thanks!
Reminds me back in 2001 when I spent $33000 on my S2000 and another $28000 in mods for it back in the day. All it got me was into Import Tuner, Super Street and numerous awards at HIN and I loved the car and how it performed and looked. Now fast forward 10 years almost and I have another Roadster that in stock fashion eats the S2000 for breakfast and NSX...lol
2020 Land Rover Velar Autobiography
2023 BMW M4 2016 X3 |
10-12-2010, 04:49 PM | #291 | |
Rep 1,855
10-13-2010, 07:44 AM | #293 | |
Rep 2,747
Nice work on the S2K. The awards and magazine spreads had to be gratifying . I think it would be awesome to land a spread in magazine. It would be some sort of confirmation that the work done was accepted and admired. It would be cool to seem some pics of the S2000, and your M3. Great line-up of cars!
10-13-2010, 08:11 AM | #294 |
Rep 4,726
hey crfine, does your kit have the same vortech bypass valve? You guys should keep an eye on these. I had a lot of problems with mine. I would recommend buying a hand vacuum pump to check it's operation from time to time. The diaphragm likes to get ripped if it sees manifold pressure without having the vacuum line hooked up and the O ring that seals the plunger likes to disappear, both can cause boost leaks.
10-13-2010, 08:48 AM | #295 | |
Rep 2,747
I have done a ton of modification when it comes to suspension, brake, etc... but I am new to the FI world. I wll look into this.
10-13-2010, 07:58 PM | #296 | |
DHS
213
Rep 4,029
10-13-2010, 08:02 PM | #297 | |
DHS
213
Rep 4,029
One of my friends Tommy from Irvine made cover a year ago and was well deserved. Turbo and everything. Crazy car.
10-30-2010, 06:24 PM | #298 | |
Rep 5,329
11-02-2010, 09:17 PM | #299 |
Rep 1,090
LOVE the new rims, G2 ftw!
Any more pics with the spoiler fitted. Your new sig looks so hot.
135i N54 manual
MR-S with a 2zz swap and mods Sold EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold |
11-02-2010, 09:32 PM | #300 |
Rep 4,726
That's a vortech valve. It only leaks if it break, but there's a few ways that can happen.
11-11-2010, 06:03 AM | #302 | |
Rep 2,747
I will get some new pics and updates up soon. Thanks, man.
11-11-2010, 07:02 AM | #303 |
Rep 11,668
11-22-2010, 05:16 AM | #304 |
Rep 22
hi chris, this is david from malaysia i have follow up and very impress with your set up.. after use to run in at the track the ess until today is the engine still ok. please advise because i am looking forward to fix the ess..
11-22-2010, 05:54 PM | #305 | |
Rep 2,747
Thank you for checking out the mod journal. I have a little over 5,000 miles on the engine with the S/C kit. The oil temps are cooler than stock and the car is performing very well. I am very happy with the kit and the guys @ ESS really know what they are doing when it comes to our cars. I recomend you contact Roman with ESS for a more info on how they tune. If you want his info send me a PM Cheers, CF
11-23-2010, 06:14 AM | #306 |
Rep 5,329
cfrine88, have you done you inial supercharger oil change @ 2500miles?? ive done about 1500 miles since my install but they've been 1500 hard miles, ess say the charger oil must be changed from the run in oil @ 2500miles, also are you checking the s/c oil level? have you noticed any oil useage? i have checked my oil yet but i will get it changed next year as the car is currently in winter storage, just wondering where you are with this?
11-23-2010, 07:00 AM | #307 |
Rep 5,329
after looking at my install it seems the relocated powersteering tank i now in the way of getting to the dipstick!! im REALLY hoping checking the oil wont mean having to remove the power steering tank every 1000miles, this would really wear thin imo!! im hoping i can losen the p/s bracket to get enough movement to allow me to get to the dip stick, maybe you have sometips for me if youve been checking your s/c oil reguarly!
11-23-2010, 08:17 AM | #308 | |
Rep 2,747
Sent you a more detailed PM.
