      03-10-2012, 08:53 PM   #1
HaiDef
Drives: M240i
RTAB
Well, I looked at my tires today and my rear right passenger shows wire on the inside. I looked it up and it appears that my RTAB are worn out. Anybody have any good recommendations for some? I was looking at rogue engineering.
      03-10-2012, 08:54 PM   #2
HaiDef
Drives: M240i
and if someone has a DIY...I only saw transmission mount DIY in the DIY section
      03-11-2012, 01:40 AM   #3
doozyj
doozyj's Avatar
14
Drives: 2007 M Coupe
Could be your alignment as well, too much toe. How many miles do you have?
2007 /// M Coupe Alpine White / Light Sepang Bronze 6MT
2003 /// M3 Alpine White / Imola Red SMG II (Sunroof Delete) SOLD
      03-11-2012, 10:31 AM   #4
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Powerflex or OEM with Vorshlag shims
      03-11-2012, 10:39 AM   #5
HaiDef
Drives: M240i
I have 32k miles on my car..
      03-11-2012, 11:24 AM   #6
aerobod
Car Geek
aerobod's Avatar
3626
Drives: Caterham R500, M2-G87, Macan S
At that mileage, I would suggest alignment is more likely problem than worn RTABs, unless the RTAB is physically damaged due to impact or a manufacturing defect.
      03-13-2012, 08:59 AM   #7
HaiDef
Drives: M240i
I know this is a long shot...but does anyone in Houston have the bushing tool I can borrow? I tried calling autozone and orielly for rentals already.
      03-13-2012, 10:43 AM   #8
03BeastCharmer
03BeastCharmer's Avatar
257
Drives: '13 M3
Might ask on the Houston BMW CCA forum.
Current: '13 E92 M3 Euro Delivery
Gone: E86 M Coupe; E30 M3, E39 M5, E36 M3
      03-13-2012, 10:54 AM   #9
mshanno1
I had the same problem with my car at 21000 miles. I had the alignment checked, and everything was fine. Does anyone have a link for further info on RTABs (IDK even what they are) Thanks!
      03-13-2012, 11:00 AM   #10
03BeastCharmer
257
Drives: '13 M3
Rear Trailing Arm Bushings
      03-13-2012, 06:27 PM   #11
Ron Stygar
Drives: 2006 Z4 M Coupe
Z4M Rear Axle Camber, Toe Adjust
      03-13-2012, 06:32 PM   #12
OG_M3
Drives: ae86; z4mc
2011 BMW M3  [0.00]
2007 BMW Z4MC  [0.00]
1985 AE86  [0.00]
how many miles on the actual tire?
      03-14-2012, 10:15 AM   #13
HaiDef
Drives: M240i
around 15k on the tire
      03-14-2012, 10:33 AM   #14
OG_M3
Drives: ae86; z4mc
2011 BMW M3  [0.00]
1985 AE86  [0.00]
imho you may have rtab issues, but it looks like more camber wear than anything. rtab wear usually affect the tire as a whole because the actual bushing is flexing and causes the tire to "toe in" and "toe out" at excessive angels. This would show in the overall tire; and on some cars, even wear tires very rapidly. see below:
http://forum.e46fanatics.com/showthread.php?p=11250499
also note that his excessive wear came from the outside->inside.
      03-14-2012, 08:01 PM   #15
HaiDef
Drives: M240i
Good read, thanks! I was just planning on doing everything right the first time. RTAB replacement along with alignment and new tires. It would suck to do alignment to find out bushings are shot to changing bushings and then getting another alignment after bushings. Around $200 plus some elbow grease. Should be a fun learning experience
      03-14-2012, 11:48 PM   #16
OG_M3
Drives: ae86; z4mc
2011 BMW M3  [0.00]
1985 AE86  [0.00]
yeah, sounds like a plan. probably get aftermarket (stronger) bushings along with the rtab limiters as well while your in there.
http://www.akgmotorsport.com/catalog...og.php?item=34
      11-24-2013, 09:44 PM   #17
S2000
Drives: E86 Z4M, E60 M5, E92 M3
I would like to do this RTAB myself after watching a lot of E46 video posting on youtube.
However, there is the Z4M rear splash guard is in the way and no video on it.
Can someone have good drawing / instruction on how to remove the rear splash guard without damaging it?
Thanks
      11-25-2013, 05:18 AM   #18
Shipkiller
Shipkiller's Avatar
Drives: Me
Why add two limiters to an existing RTAB? Why not just install an RTAB that is an intergrated unit, like the Bimmerworld one's?
http://store.bimmerworld.com/powerfl...-rtab-p91.aspx
Thanks
It's a two piece unit. Just remove the 8mm screws and one plastic fenderwell nut. Both just comes off to allow access to the RTAB.
http://www.realoem.com/bmw/showparts...52&hg=51&fg=75
With the proper removal tool, it took approx. 45min a side to replace and install new RTAB's.
      11-05-2015, 08:21 AM   #19
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
For those who have installed limiters, I have read that with limiters installed the bushing will rotate under force when installed so there is no need to do the pre-load positioning of the bushing in the carrier. Does this sound correct?
Lastly, if someone could point me to the pre-loading instructions in the online TIS manual I'd greatly appreciate it (http://workshop-manuals.com/bmw/). I can never find things in there.
      11-05-2015, 09:19 AM   #20
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
With OE RTABs to set the preload, you jack up the trailing arm to the normal position as if the car was on the ground.
Then tighten everything up.
      11-05-2015, 10:12 AM   #21
elerner61
elerner61's Avatar
157
But you can't fully tighten the center bolt after carrier is bolted to the car.
I'm leaning towards one of these two methods:
1. Install but don't fully tighten bushing to carrier
2. Raise wheel assembly to ride height
3. Bolt carrier to car
4. Unbolt carrier and mark position of bushing to carrier
5. Jam something between carrier and RTA to maintain position of carrier relative to RTA while tightening center bolt to 81 ft/lb
6. Bolt carrier to car
a. When lowering old bushing, mark position of carrier relative to RTA
b. steps 5 and 6 as above
      11-05-2015, 10:35 AM   #22
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
It's been a while for me, I went with poly the last time (no preload)
With the RTAB up in position, can you not get to it with a spanner to tighten it, ( to hold position);
Then lower it to torque?
