      06-28-2012, 02:23 PM   #1
ECSTuning
New Lifetime Replacement Policy
ECSTuning's Avatar
818
Drives: Independent Tuning Specialists
:: ECS Tuning :: ECS 6-Piston Big Brake Kit E85/E86 2.5i and 3.0i and E36/7 Non-M
Big. Honkin. Brakes.
If that's what you want, we have what you need. Our Big Brake Kits are back in stock and ready to ship. The features list for these beauties is too long to fit here, so why not click through and check out the details.
We can tell you that this set is way too handsome to hide behind wheels, bolts on easily with common hand tools, and stops as good as it looks.
Check 'em out, and order your set before they're gone!
Click HERE to order!!!
Click HERE to skip a step of the ordering process
      06-28-2012, 04:40 PM   #2
MPowerZ32
MPowerZ32's Avatar
66
Drives: Man
Nice! Any plans on offering an M version?
      06-28-2012, 05:30 PM   #3
jair_onsa
jairon2
jair_onsa's Avatar
20
Drives: vt1-445 z4 MC- 14 335i M Sport
thats a good price, please tell me you guys got some for the M!!!!
      06-28-2012, 06:05 PM   #4
Rated M Roadster
Rated M Roadster's Avatar
160
Drives: F10 M5, i3, Z4M
I'd be in for an M version.
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX
SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i
      06-29-2012, 08:48 AM   #5
ECSTuning
ECSTuning's Avatar
818
Nothing for the M..... The brakes on the M are already pretty righteous, so developing a kit which out preforms them without destroying the balance of the breaking system takes a good bit more time and effort.
      06-29-2012, 09:06 AM   #6
spr_bimmer
Drives: 2004 Z4 Roadster
i was looking at these before but i'm not sure yet... what about the rears?
      06-29-2012, 09:10 AM   #7
3002 tii
3002 tii's Avatar
2286
no rear kit available but if they did, then i'd consider it since bias would be maintained. i think shifting more bias to the front would cause more understeer.
Follow for latest mods
      06-29-2012, 09:48 AM   #8
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
Yea, I agree.
I don't think we want anymore weight shifting to the front of the car.
      06-29-2012, 12:27 PM   #9
Rated M Roadster
160
If you put in the time and effort, you'd sell a couple kits
      06-29-2012, 01:05 PM   #10
Kgolf31
Kgolf31's Avatar
460
They even have a local tester in the area that is more than willing to have a BBK set-up on their car
      06-30-2012, 11:09 AM   #11
acvr4
acvr4's Avatar
Drives: 3.0Z4,VR4,Vehicross.Touareg
That is a sweet looking BB Kit -- hummmm
      06-30-2012, 01:52 PM   #12
Jony722si
The Wrapgician
Jony722si's Avatar
Drives: z4si
2006 BMW z4  [0.00]
2009 Bmw 135I  [0.00]
2022 BMW M4C  [0.00]
2009 335i  [0.00]
even e46 330ci, z4 3.0i M54/N52, z4 3.0si N52 has sme front end set up and using same king pin but ECS claim that this kit wont fit 3.0si. which is why I havnt put my money on it... any idea they will fit 3.0si?
      07-02-2012, 09:59 AM   #13
ECSTuning
ECSTuning's Avatar
818
At the current time we do not have plans of making a rear BMW Performance BBK.
Mathematically speaking, brake bias will not be significantly changed. Yes it will be slightly push to the front but a more aggressive pad in the rear of the pad can easily compensate for this.
Our parts applicator puts the 3.0si in a slightly different location than the other Z4s when adding parts (if that makes any since) long story short I just smacked my parts guy for not clicking the box that links the kit with the 3.0si. It was over looked this it should also fit the 3.0si as like you said the king pins and other front end components are shared.
Guys make sure you're wheels will clear the BBK, some people have noted needing 5mm spacers to clear the calipers. HERE is a template we have that you can print, cut out, and use on your wheels to see if the rotors and calipers will clear the spokes and barrels.
      07-02-2012, 10:59 AM   #14
3002 tii
3002 tii's Avatar
2286
3.0si shares same fronts as e46 330i/ci
3.0i shares same fronts as e46 non-m, non-330
      07-03-2012, 07:23 AM   #15
acvr4
acvr4's Avatar
I see that that most 17" wheel will clear - any idea if the 18" factory ones will ?
      07-03-2012, 09:05 AM   #16
ECSTuning
ECSTuning's Avatar
818
I haven't had any of my guys running 18s report any issues. To be safe, I suggest print out the pdf found HERE to scale. It is a fitment template that'll give you an idea of how the bbk will fit inside your wheels.
      07-31-2012, 08:27 AM   #17
Marlymarl1
Drives: 2007 BMW Z4 Coupe 3.0si
Will these work on a 2007 Z4 3.0si?
      07-31-2012, 08:29 AM   #18
ECSTuning
ECSTuning's Avatar
818
The kit is designed to work on the Z4 2.5i, 3.0i, and 3.0Si.
      07-31-2012, 09:44 AM   #19
3002 tii
3002 tii's Avatar
2286
If 17's fit, then 18's with same offset and width would definitely fit. The question is width and offset though...
      07-31-2012, 09:49 AM   #20
ECSTuning
ECSTuning's Avatar
818
To give you an idea of wheel fitment, on a 330ci the stock Style 68s (7.5X17 ET:41) require a 3mm spacer for proper clearance.
Spoke design has a lot to do with wheel fitment as well, not all wheels of XX offset are designed equally. That's why I suggest printing out the pdf found HERE to scale, and using it to double check your clearances.
      11-08-2012, 03:57 PM   #21
ECSTuning
ECSTuning's Avatar
818
      11-09-2012, 08:12 AM   #22
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
Holy cow that is a good price.
Another person in for an M kit.
Could you make an M kit that uses those calipers with the stock rotors? Just calipers, modified carriers, pads, and hardware? And maybe a well matched rear pad to keep the bias in check?
