      03-26-2012, 07:14 PM   #1
djlogan33
djlogan33's Avatar
Drives: BMW Z4 M Coupe
BMW Spare Tire - reduced price
I don’t know about you, I do not want to trust the BMW “Mobility System” of BMW,
that “applies a sealant to the inside of a flat tire, seal off the damage area, restore the tire inflation pressure and then continue driving”…bull-xxxx!
I want a real spare tire that I can use. I like going into remote areas and I do NOT want to be stranded somewhere without a spare tire.
For the last four BMW cars I have owned, that have no real spare tire, I have carried in my trunk the below real spare rim & tire.
I currently own a 2007 BMW Z4 Coupe. This rim will not fit over the much larger brakes.
I have obtained another rim and tire that does fit over the larger brakes, as a spare rim & tire.
So, I am selling the below BMW spare wheel & tire.
The tire & rim does NOT take much room.
When the rim is face-down, you can store item inside the rim
$225 or best offer (zip-code 45039)
djlogan33@cs.com
Currently own: - Z4 ///M Coupe with Black BBS CH-wheels
Previously owned: - Z4 Coupe 3.0si, Z3 ///M Coupe S54, Z3 ///M Coupe S52, ///M6, 635csi, 533i, 323i, F25 X3 with ///M Sports Package
      03-28-2012, 03:52 PM   #2
3002 tii
3002 tii's Avatar
2286
Have you actually test fitted that wheel? I know in theory it would clear the brakes but that looks like an e39 wheel, and I thought they had different hub sizes. Could be totally wrong on this.
Follow for latest mods
      03-28-2012, 09:33 PM   #3
djlogan33
djlogan33's Avatar
I used this wheel and tire, as a spare, for 3 different cars:
1. 1999 Z3 M Coupe
2. 2001 Z3 M Coupe
3. 2007 Z4 Coupe 3.0si
The wheel and tire fit on all 3-cars front & back, without a problem.
Only because the brakes are so much bigger on my 2007 Z4 M Coupe and that that this BMW wheels has an inner lip, the wheel will not fit.
I have another 17" wheels without the inner lip, that does fit over the brakes, that I am using as a spare.
This 17" wheel & tire will work fine as a spare on most Z3, Z4 and 3-Series cars.
      03-28-2012, 10:52 PM   #4
3002 tii
3002 tii's Avatar
2286
1. 1999 Z3 M Coupe
2. 2001 Z3 M Coupe
Thanks for the clarification. For some reason I thought that wheel was unique to the 5-er. Bump for a good deal =)
      08-03-2012, 04:50 AM   #5
djlogan33
djlogan33's Avatar
spare tire
Is still FOR SALE...
      09-15-2012, 08:35 AM   #6
djlogan33
djlogan33's Avatar
Still for sale -$150
Lowered the price to $150..
