      06-17-2018, 01:02 PM   #1
HTM101
Drives: 2007 Z4 Coupe
Headlight Lens Restoration
One headlight on my recently acquired car is 11 years old, the other is 1 year old. The older one appears to have a cataract, so I bought a 3M Headlight Restoration kit and got into the renewal. When I finished the project yesterday I was very satisfied with the result and stopped for the day.
Today I looked at the lens in a different light and noticed faint but obvious swirl marks on the entire lens surface. I re-did the last several steps of the process, (a) 3000 grit buffing pad and (b) the final polishing compound. I compounded the lens twice. All the swirls were still visible when viewed at specific angles.
I guessed the polishing compound to be the culprit, that it might be a bit aggressive. I drove to Autozone and purchased a Meguiars product, http://www.meguiars.com/en/professio...-remover-16oz/ . That bottle of very fine polish compound did the trick. All swirls gone and the overall finish was much glossier.
David
2007 Z4M Coupe
StickMon636.00
WhoU421.00
      06-18-2018, 07:22 PM   #2
Z4Lee
Z4Lee's Avatar
Drives: 2006 Z4 3.0i
It's all about the grit..... nicely done. and don't forget to seal or in a year you will be back to yellow
      06-18-2018, 07:28 PM   #3
HTM101
Thanks. The sealer is arriving tomorrow. Here are before and after shots.
2007 Z4M Coupe
      07-01-2018, 11:31 PM   #4
rsutoratosu
Drives: Z4 3.0i
ill need to do this also.. what sealer do you use or recommend... is the sealer something you need to reapply once every few months ?
-Roranji
      07-02-2018, 07:58 AM   #5
HTM101
I chose this product from Meguiar's. Don't know if its the best. Their text states it will last for 1 year.
https://www.summitracing.com/parts/m...t=All+Products
David
2007 Z4M Coupe
      07-03-2018, 03:54 PM   #6
rsutoratosu
Drives: Z4 3.0i
Thanks.. does it look like something you can replay more often or can't tell yet ?
-Roranji
      07-03-2018, 04:48 PM   #7
HTM101
Much too soon. I've owned the car for just 5 months, and bought it with the lens in its deteriorated condition. Previous owners probably had the car parked in the sun quite a bit.
I have a garage and now the car is parked in the garage 24/7. I drive it maybe once a week. It may be many years before I'll see the need for a re-do.
David
2007 Z4M Coupe
      07-06-2018, 11:19 PM   #8
RossBMWZseries
Instead of using a sealer, can’t you just use a LaminX film over your lenses?
      07-09-2018, 06:27 PM   #9
StickMon
StickMon's Avatar
Drives: 2006 MR
Not sure about LaminX, but I have Headlight Armor and it has about the same life span as the bare lenses, but replacing it is a lot harder than doing the old sand and buff.
      07-11-2018, 06:17 AM   #10
SwissArmy
Why so serious?
SwissArmy's Avatar
The best headlight restoration kit I've ever used has to be the Meguiar's Heavy Duty Headlight Restoration Kit. Comes with all you need, except a drill of course. Highly recommend it
http://www.canadiantire.ca/en/pdp/me...-0391037p.html
      07-12-2018, 11:06 AM   #11
RossBMWZseries
How bad was the condition of your headlights?
As bad as this?
2014 BMW X5 Sdrive35i F15
2011 BMW 328i E92 LCI
2006 BMW Z4 M Roadster E85
2013 BMW S1000RR K46 R.I.P.
      07-12-2018, 05:07 PM   #12
SwissArmy
Why so serious?
SwissArmy's Avatar
As bad as this?
Pretty similar. Im glad I document almost everything new I try. Here you go (in June). You should honestly try it. I can pretty much swear by it
Before:
After:
      07-13-2018, 03:58 PM   #13
RossBMWZseries
Before:
After:
Good to know. I used the Meguiar's but the "not so heavy duty" version. It did a good job and it was by hand. I'll try this one and use a drill this time. Thanks!
      07-13-2018, 06:29 PM   #14
SwissArmy
Why so serious?
SwissArmy's Avatar
No worries! I can stand by that kit. It's great! Did my buddy's headlights. One kit can do 3-5 sets of headlights.
      07-18-2018, 07:16 PM   #15
bgeorge0049
Drives: 2006 BMW Z4 3.0si
I used the Gliptone product that I bought from BavAuto during a sale. There is no sanding involved as it uses chemicals to peel off the oxidation. It also comes with a sealer. I did it this past January/February and loved the results with minimal effort. It is holding up great but the car sits in the garage at night and a parking garage during the day.
https://www.bavauto.com/bmw-headligh...on-kit-gt71647
StickMon636.00
      07-23-2018, 01:28 PM   #16
RossBMWZseries
So I ran to my local Wal-Mart as they had ONE in stock, bought it for $21. Did the lights in the 328i and man, car looked like a 2006, now looks like a 2015 E92 (had it continued production). Thanks for the recommendation Swiss Army, did wonders!
I put the clear coat at the end provided by Meguiar's but I'm letting the car cure at home, I'll be covering the headlights with Lamin-X today anyway to protect it from cracks or rock chips.
      07-23-2018, 01:44 PM   #17
gpraceman
gpraceman's Avatar
Drives: '06 Z4 ///M Roadster
I followed this video to do mine. They turned out well. Here's his two year follow up video.
2006 Z4 ///M, Interlagos Blue/Beige
2006 Z4M Interlagos Blue/Beige
      07-23-2018, 02:07 PM   #18
SwissArmy
Why so serious?
SwissArmy's Avatar
No worries! Glad it turned out great!
      08-10-2018, 08:18 AM   #19
Yapakanichi
Monkey Marshall
Yapakanichi's Avatar
635
Drives: 2005 Z4 3.0i
Wow everyone did an amazing job.
Personally I had a lot of luck with the turtle wax kit that comes in a box.
However I do want to redo my Mazda and put Laminex film on them
      08-10-2018, 01:44 PM   #20
mainsoda
mainsoda's Avatar
Drives: 2006 BMW Z4M coupe
Not my Z, but a girl at my work had some of the worst headlights I had ever seen. I polished them up not only as a public service, but just to see if I could. They came out pretty nice.
HTM10157.00
      08-18-2018, 12:31 AM   #21
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: '18 Frontier Pro-4X, '06 Z4MR
Good stuff y'all! I'll be tackling this, this coming week.
-Matt
| Z4M Build Thread | @violetnites | flickr |
      08-27-2018, 08:02 AM   #22
WangTa
WangTa's Avatar
Drives: E90 M3, E46 m3, Z4 M Coupe
When you guys say "sealer" is that the same as "clear coat"? Getting ready to buy one of these kits and from my research, I was under impression that much like paint - starting with lower grit and ending with higher grit sand paper was in order, then moving to polish and wax - and finally clear coat - was the key?
