      05-09-2017, 03:37 PM   #1
Harrison256
Drives: 2006 BMW Z4 3.0si
Will a 3.73 differential fit into a 2006 3.0si?
I currently have the 3.23 differential in my car and wanted to swap up to the 3.73 which comes out of a N52 3.0i Z4.
The add I'm looking at says it will NOT fit any 3.0si models. Everything I've heard hear says otherwise.. that any differential is swappable with any other differential as long as its not an M. So who is correct?
2006 Z4 3.0Si
      05-09-2017, 06:09 PM   #2
Steeler
Steeler's Avatar
2429
I fitted a 3.73 diff from a non M N52 with an SMG trans and it fit fine.
Why not ask the seller why they think it will not fit and post that reason here.
Some info below.
http://www.bokchoys.com/differential/GearRatios_E46.htm
      05-09-2017, 07:51 PM   #3
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
All non m differentials across the BMW e46, x3, and z4 differentials swap over. All those chassis's share the same exact rear non m subframe. Yes the 3.73 from the n52 3.0i z4 will swap over like it was meant to be there. I swapped in a non m 3.46 e46 325i diff to my z4 3.0si no problem!
      05-10-2017, 06:53 AM   #4
3002 tii
3002 tii's Avatar
2285
yes it'll fit, that's what I'm running now (3.46->3.73)!
Follow for latest mods
      05-10-2017, 08:05 AM   #5
2006E85
2006E85's Avatar
Puerto Rico
Drives: 3.0si Roadster
2006 BMW Z4  [0.00]
I am still hunting for one. I swapped from 3.23 to 3.46, but I want MORE.
2006 Z4 3.0si, 6MT RPI Intake Scoop, K
      05-10-2017, 01:48 PM   #6
Harrison256
How noticeable is the difference?
2006 Z4 3.0Si
      05-10-2017, 01:49 PM   #7
Harrison256
Does anyone have a link to any useful DIYs on the actual differential swap. I'd like to attempt it on my own.
2006 Z4 3.0Si
      05-10-2017, 04:54 PM   #8
3002 tii
3002 tii's Avatar
2285
I do notice a difference; it's a nice improvement but nothing drastic neither.
Spoke with few diff builders and general consensus is 5% isn't worth it, 10%+ is when u get that kick in pants feeling but may come at the expense of driveability. Going from 3.46 to 3.73 was ~8% increase and I would say it's just right. On track it keeps my revs in the sweet spot especially when powering out of turns. Yet for everyday driving I don't find it to be any less practical. Can still cruise in 6th on the freeway and start from 2nd gear easier at a light if you're feeling lazy.
      05-10-2017, 04:57 PM   #9
Steeler
Steeler's Avatar
2429
Just to tack on, first gear is basically useless with the 3.73.
RPM @ 70mph is around 2900 rpm with 265/35/18 and 6 speed.
      05-11-2017, 04:27 PM   #10
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Had gotten into an argument with an auto scrap yard because they tried giving me the same bs, after 10 minutes of arguing back and forth the place refused to sell it to me. Most places have not a shits clue, this forum is filled with knowledge beyond what some "experts" thought on it is...I have 3.73 in si as well, it fits
      05-11-2017, 06:06 PM   #11
Harrison256
Do you have any regrets? Is first gear ridiculously short or is it still daily driveable
      05-11-2017, 09:37 PM   #12
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Zero regrets, def easily still drivable without any increase in aggravation
      05-18-2017, 03:03 PM   #13
2006E85
2006E85's Avatar
Puerto Rico
2006 BMW Z4  [0.00]
Harrison256
Did you get it?
      01-12-2018, 08:30 PM   #14
peter82
Drives: BMW Z4 3.0Si
Manual trans.
Hi guys, i am looking for diff for 2006 Z4 Si in manual trans. I am not sure if i understand it correctly so my simple question is: Will the diff from Z4 3.0si 3.73 Gear Ratio Automatic fit in MANUAL?
Thank you for your help.
      01-13-2018, 08:45 AM   #15
Steeler
Steeler's Avatar
2429
Some info below.
Yes
