03-26-2012, 07:14 PM | #1 |
Rep 116
BMW Spare Tire - reduced price
I don’t know about you, I do not want to trust the BMW “Mobility System” of BMW, that “applies a sealant to the inside of a flat tire, seal off the damage area, restore the tire inflation pressure and then continue driving”…bull-xxxx! I want a real spare tire that I can use. I like going into remote areas and I do NOT want to be stranded somewhere without a spare tire. For the last four BMW cars I have owned, that have no real spare tire, I have carried in my trunk the below real spare rim & tire. I currently own a 2007 BMW Z4 Coupe. This rim will not fit over the much larger brakes. I have obtained another rim and tire that does fit over the larger brakes, as a spare rim & tire. So, I am selling the below BMW spare wheel & tire. The tire & rim does NOT take much room. When the rim is face-down, you can store item inside the rim $225 or best offer (zip-code 45039) djlogan33@cs.com
Currently own: - Z4 ///M Coupe with Black BBS CH-wheels
Previously owned: - Z4 Coupe 3.0si, Z3 ///M Coupe S54, Z3 ///M Coupe S52, ///M6, 635csi, 533i, 323i, F25 X3 with ///M Sports Package Last edited by djlogan33; 04-02-2012 at 07:52 AM.. |
03-28-2012, 03:52 PM | #2 |
Rep 12,565
Have you actually test fitted that wheel? I know in theory it would clear the brakes but that looks like an e39 wheel, and I thought they had different hub sizes. Could be totally wrong on this.
03-28-2012, 09:33 PM | #3 | |
Rep 116
I used this wheel and tire, as a spare, for 3 different cars: 1. 1999 Z3 M Coupe 2. 2001 Z3 M Coupe 3. 2007 Z4 Coupe 3.0si The wheel and tire fit on all 3-cars front & back, without a problem. Only because the brakes are so much bigger on my 2007 Z4 M Coupe and that that this BMW wheels has an inner lip, the wheel will not fit. I have another 17" wheels without the inner lip, that does fit over the brakes, that I am using as a spare. This 17" wheel & tire will work fine as a spare on most Z3, Z4 and 3-Series cars.
Previously owned: - Z4 Coupe 3.0si, Z3 ///M Coupe S54, Z3 ///M Coupe S52, ///M6, 635csi, 533i, 323i, F25 X3 with ///M Sports Package |
03-28-2012, 10:52 PM | #4 | |
Rep 12,565
Thanks for the clarification. For some reason I thought that wheel was unique to the 5-er. Bump for a good deal =) |
08-03-2012, 04:50 AM | #5 |
Rep 116
spare tire
Is still FOR SALE...
09-15-2012, 08:35 AM | #6 |
Rep 116
Still for sale -$150
Lowered the price to $150..
