04-20-2013, 04:43 AM | #45 |
10859
Rep 4,893
Is that pré or post cooler boost?
04-20-2013, 04:47 AM | #46 |
Rep 892
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i |
04-20-2013, 04:54 AM | #47 |
10859
Rep 4,893
Then that's a lot of boost
And that is boost over realtime atmospheric pressure? (so 11psi is also really high pressure ratio on high altitude) And your kit is rated @ 9 psi? Maybe the sci trim is very well suited at high altitude. I don't think you can read that of a CFM diagram and I don't think it is scaled proportionally with the parameters atmospheric pressure and temperature. (thermodynamics on this level is way to complicated for my mind ) On the other hand I see 29,9 inHG, which equals about 1000hPA (a little bit more), so if that's measured in the same situation it is an indication of the atmospheric pressure and that means that you were'nt on high altitude or that there was a high pressure area (probably the latter because I assume you knew where you were ), but that also means that this kit can put out the same amount of pressure at sea level (given the same ambient temperature). I mean: the amount of inHG you can measure is related to the ambient airpressure I think? (I'm going way off topic here )
04-20-2013, 07:52 AM | #48 | |
Rep 33
The maximum recorded pressure is distorted by the "water hammer" when remove gas.
Z4M E85/2006 || ESS CFR525 || AEM Water / Methanol Injection Kits || Supersprint Exhaust (catless,XPipe,rear exhaust race) || 4.10 || front brake AP Racing 6 piston kit (cp5575-1010) || K-Sport suspension with camber plates || Sparco Pro2000 seat || 6 pti Sparco belts -|| Hankook S1 EVO 1 (front 245/35 19 - rear 275/35 19) || OZ Racing Ultraleggera HLT 19"
04-20-2013, 08:20 AM | #49 |
10859
Rep 4,893
What's a water hammer? You mean that when you close the throttle valve the momentum of the air column (also driven by the sc of course) pushes in on itself?
Wouldn't the opening from the BOV compensate for that or is that system not fast enough to do so? Interesting remark though
04-20-2013, 12:20 PM | #51 | |
Rep 33
Sorry for my English. I meant this. My instrument, with active sports key, marked 14 psi. Is dangerous for throttle valve.
04-20-2013, 12:33 PM | #52 |
Rep 2,782
Vortech recommends a bypass with anything over 6 psi.
04-20-2013, 01:27 PM | #53 | |
///M-fanatic
193
Rep 3,885
Gotta pay to play I suppose Things are going to go wrong eventually, especially if these cars are pushed at all. So maintenance/repairs are a given hah Gonna be running a TIAL BOV. Andrew ordered one as well, but it was too loud for him, so he went back to the BPV included in the kit lol Last edited by mfanatic325; 04-20-2013 at 02:18 PM.. |
04-20-2013, 02:10 PM | #54 |
10859
Rep 4,893
Never thought about that. How big are these things? 50mm diameter or so?
Then they get a weight of almost 20kg (regarding 2 bar pressure: vacuum on one side, 14psi over atm on the other side) But a single throttle valve is much bigger (almost 70mm in my case) so that gets a lot more weight/pressure, almost 40kg
04-20-2013, 04:10 PM | #55 | |
Rep 892
Also, the low vacuum reading (29.9) is due to lift off. The can runs around 7 inHg at idle. Hardly; there's a reason for a BPV or BOV. Without one, the pressure would go back into the SC (damaging the blades) well before doing any damage to the throttle bodies.
04-20-2013, 04:29 PM | #56 |
10859
Rep 4,893
So you only have a pressure sensor after the throttle valve? Like connected on a vacuum line? (before any vacuum valve obviously)
04-20-2013, 05:24 PM | #57 |
Rep 892
Yes.
04-23-2013, 01:25 PM | #58 |
Rep 24
I hope I can add some positive results to the VF argument in the near future.. I've got the VF480 kit sitting in boxes @ home now. It will probably be at least a month before I get it installed, though, as I want to put my SS headers/exhaust + euro-cats on first and work out the kinks.
04-23-2013, 03:07 PM | #59 | |
enthusiast
48
Rep 1,695
04-23-2013, 03:18 PM | #60 | ||
Rep 1,739
Drives: 2008 Z4MC
04-23-2013, 04:34 PM | #61 |
enthusiast
48
Rep 1,695
04-23-2013, 11:09 PM | #62 | |
Car Geek
3626
Rep 3,594
04-24-2013, 12:07 AM | #63 |
enthusiast
48
Rep 1,695
They didn't send you a tune with the kit?
04-24-2013, 12:10 AM | #64 | |
///M-fanatic
193
Rep 3,885
Anyway, aerobod, do you know if the tune that they're working on is for the 480 kit or the 570 kit? Because I'm also waiting on them to send me my cable/tune |
04-24-2013, 12:33 AM | #65 | |
Car Geek
3626
Rep 3,594
I need the VF480 tune to work with a stock exhaust (we have automated cameras that activate at 92dB drive-by noise levels, then trigger a costly photo ticket in the mail, but the stock exhaust is exempt). Also my default altitude is 1250m (4000ft) and I use the car at ambient temperatures that vary from -25C (-13F) to +40C (+104F). |
04-24-2013, 12:39 AM | #66 |
Car Geek
3626
Rep 3,594
The kit comes with a cable and HexFlash software that becomes coded to the car VIN. The encrypted ECU / MSS70 DME flash is then downloaded onto a PC via the OBDII port and emailed to VF for a custom build. They have my ECU download, I'm waiting for the custom build to re-load.
