01-03-2012, 10:34 PM | #45 |
Rep 251
Hey Dudez... well, I changed mine yesterday afternoon. I used the neo... from RE. I must admit that taking things apart was pretty easy but things don't go back in the same order - making things pretty difficult, if you don't have the right tools to screw/tight the top nuts on the trans mounts.... you'll be Ph*CkT for lack of better words.
Thank God my neighbor is another gear hear and has better tools than I and he saved the day. I recommend that you try to loose the top nut on the oem mounts before you remove anything... if you can get to them and loosen the nuts.... then you will have no problem screwing the new ones in place.... you'll see what I mean. After 2-3 hours of wrestling my trans and the drive shaft, I went up took a shower and got ready to go for a test drive, I jumped in the car threw in neutral and started it up, about 20 secs later I threw the car in 1st and with a panic face I said OH SH*T! shifting from neutral to 1st felt so smooth that for a split second I thought "I messed up my trans..." threw it back in neutral and paid a closer attention on how 1st engaged and felt..... slowly I let the clutch go and the car moved forward.... UFFF what a relieve. 1st gear is butter smooth now. 2nd is less notchy and engages faster. I know it sounds stupid, but I totally love my upgrade. if you hate your 1st gear..... do this upgrade, it improves the way the trans accepts the gears a lot softer and to be honest makes shifting half a sec faster = less fighting or keeping an eye on the right RPM so you can shift. Now I can shift from 1st to 2nd at 2.5 RPM if I want with no grinding. Shifting at 3.5 RPMs or higher makes any gear butter smooth. |
01-04-2012, 01:04 AM | #46 | |
Rep 5,328
01-04-2012, 04:22 PM | #47 |
Rep 1,663
JeffchaPz how would you rate the increase (if any) of NVH?
01-04-2012, 04:42 PM | #48 |
Rep 251
__________________________________________________ _______
It depends... if you drive with your right hand on the lever... you will feel more vibration. but if you don't.... trust me you won't be able to tell the difference in any NVH. but if you still want a # then I'll say = 7.30389% more Trust me it won't bother you and you'll love shifting more around town. |
01-06-2012, 09:22 AM | #49 |
Rep 855
Glad to hear your results are the same as mine. This is must for ANY BMW not just our car. They all use the same shitty transmission mounts.
2014 335i M Sport
2010 328i M Sport 2007 Z4MC #1019/1815 (Sold) 1997 M3 (Sold) 1991 325i |
01-14-2012, 04:46 PM | #50 |
Rep 704
Drives: '08 MC
Have also experienced all the issues mentioned everywhere about shifting. Between this thread and the sticky thread on tranny mounts and talking to Dubbed and others... I've gotta do this stuff too now.
ZHP done, Zeck CDV ordered, now adding the RE mounts, and hopefully getting both installed Monday, maybe a clutch stop as well. So much for 'keeping it 100% stock'... |
01-14-2012, 06:04 PM | #51 |
Rep 855
I wanted to keep mine 100% stock too but the thing is there are mods that really make the car so much more enjoyable. I have not done 1 mod that hasnt been a 100% improvement and none of them have had any downsides.
2014 335i M Sport
01-14-2012, 10:01 PM | #52 |
Rep 704
Drives: '08 MC
Yeah im starting to gather that many upgrades make so much sense, as I read thru threads. Glad im starting here with the tranny issues. I just need to resist building something crazy that'll get me into trouble.
And I'll do the clutch stop too. So, the 4 basics of tranny stuff. ex #5 the fluid. |
01-15-2012, 11:56 AM | #53 | |
703
The other thing worth considering are camber washers if you plan to Autox or take the car to the track. 20 bucks or so if you DIY the install, and 100-150 for a good alignment. Stubby antennas look good too, and are damn cheap (Mangowalk, 15 bucks). Or you can DIY a stubby yourself by popping off the plastic tip, cutting down the antenna, and popping the tip back on. From there, it's a slippery slope downhill to cosmetic improvements, wheels, coilover suspensions, exhaust systems, supercharger kits, and BBKs, I'm already on that slope! |
01-15-2012, 09:07 PM | #54 |
Rep 556
Drives: 2003 ESS TS1 Z4
I installed mine last weekend with the pucks and I prefer the stock over the new ones, but i do notice smoother shifts but more noise. I love the total feel of it, to me you feel more connected to the car but almost excessive maybe? Idk, overall I'm happy!
*Edit* I'm inebriated and just figured out its UUC, not RE apologize
TS2/Cat-Less Headers/Jet Hot Coating 2000/CF Engine covers & Oil Cap/RPi Scoop/Matte Black Grills/H&R Sport Springs/15mm Spacers Rear/12mm Spacers Front/Flowmaster 40 series/Alcantara Shift Boot/CF Vinyl wrap/SPEC Stage 2+ clutch/8 Lbs Fly wheel/ZHP Shift knob/Hawk HPS Pads/Cross Drilled/Slotted Rotors/Performance Pedal Set/Stewart water pump
Love is like a fart; if you have to force it, it's probably shit. |
01-15-2012, 11:55 PM | #55 | |
703
01-16-2012, 03:00 AM | #56 |
Rep 556
I think I'm going to do that, there is just a little to much noise for my liking. Now sober I have read through the thread and a lot of good info, thanks!
01-16-2012, 01:57 PM | #57 | |
703
01-16-2012, 04:40 PM | #58 |
Rep 704
Drives: '08 MC
Just got done making the run to Zeck and then Rogue. Zeck CDV and the RE trans mounts are now on, as well as RE clutch stop. Overall, a noticable improvement in shifting thru gears, esp into 2nd from any gear. And releasing the clutch is much better without the stock CDV, hardly any bucking under power. Not noticing any additional noises either. VERY happy with all of it.
Finnegan, i'm trying to avoid that slippery slope! |
01-16-2012, 05:23 PM | #59 | |
703
As for that slope, man, it's a tough one once you're on it. Don't even go over to look at the slope--you'll be on it before you can say "oooopssss, weeeee!" See this example. |
03-11-2012, 04:52 AM | #60 | |
Rep 1,530
03-11-2012, 05:16 PM | #62 |
703
Agreed, Rogue Engineering neoprene recommended.
I'd say CDV delete (or Zeckhausen) as well. I'm biased, and a CDV hater. After driving stick for 30 years I'll decide when and how much the clutch engages. It's so much easier to be consistent and shift smoothly without it. With it, I was always trying to adjust for the CDV's interference. If you're out of warranty, you can just delete the CDV, no need for the Zeckhausen. |
03-11-2012, 06:39 PM | #63 | ||
Rep 1,739
Drives: 2008 Z4MC
03-11-2012, 07:09 PM | #64 |
Rep 704
Drives: '08 MC
In strong agreement with you guys on these last couple posts. Aries, I did them all at once, but knowing what to expect from each one serately helped me appreciate the real impact of them together.
I'd def give the CDV a try, whats the worst that happens if you fall into the supposed camp of not noticing a difference..... then youre out a few bucks and a little time. I doubt that happens though. And do the mounts for sure (now I'm even thinking motor mounts). (that darn slippery slope) Ironically, the clutch stop was the afterthought as I decided on the way to Rogue, to get that too. And thats the one you notice first instantly, marked difference. Make sure you tell the guys at RE to trim the length of the clutch stop bolt. I forget, but I think they either trim 20mm off of it, or they trim it to a total length of 20mm. But they will know....
03-11-2012, 10:51 PM | #65 |
Rep 855
I was going to say that the clutch stop made a nice difference too I immediately loved the change. Just go to lowes and make one that's what I did no problems at all
2014 335i M Sport
03-12-2012, 05:12 AM | #66 |
Rep 2,138
Drives: Me
Alright, someone please educate me on just who, what, why, when a clutch stop can, using some elses words on this board, 'dramatically change' how your clutch feels?
Please, because I just don't get it. Am I missing something? Maybe I am. I just don't know. |
