      12-11-2015, 09:08 AM   #23
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Yep, Byron is a good bloke, and knows his stuff. But thats neither here nor there, I am sure he was just trying to help. Now dammit, show me those numbers please
      12-11-2015, 10:04 AM   #24
Steenos
Drives: 2007 Z4M Coupe
2021 BMW M240i  [0.00]
2007 M Coupe  [0.00]
Alright. Lets get this straight. I understand the good intent. But lets get past that point. I disagree with his advise but that's just my opinion. Lets keep on topic here. Vanne putting some miles on the car before I take it back to the dyno. But it will happen soon.
2021 m240i on order
      12-11-2015, 10:43 AM   #25
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Bloody awesome mate, how's the butt dyno enjoying the show? The torque must be marvelous.. :-) more pics required. Also how do you go when you go to re-register your car and they look under the bonnet (that's hood for you guys and they see that compressor there? Do you need an engineering certificate over where you guys live or how does that work. The ESS kit looks like quality. Very bloody nice.
Powered by
      12-11-2015, 03:58 PM   #26
Steenos
2007 M Coupe  [0.00]
Thanks man. The butt dyno is incredible. The torque from about 3.5k rpm to the top is awesome.
They do not look under the bonnet here. They just hook up to your obd2 as well as look under the car to make sure you have cats. I need no certificates or anything. It's pretty nice.
ESS was able to tune for everything as well as make it o2 ready for emissions. Oh trust me there will be more video/pictures.
2021 m240i on order
      12-14-2015, 01:08 PM   #27
Steenos
2007 M Coupe  [0.00]
I'm an Air Traffic Controller and I was leaving work today. My coworker heard the Jet Engine sound it makes when the supercharger is cold and yelled, "Cleared for takeoff!". Haha
2021 m240i on order
      12-18-2015, 12:23 AM   #28
pungo
pungo's Avatar
I've seen several cars where perfectly good stock motor mounts failed after dramatically increasing the HP of the engine. Some failures caused plenty of carnage, huge dents in the hood, twisted and or cracked brackets, torn hoses, damaged headers/exhaust, and so on. I'm not saying it will happen to your car, but adding allot of extra HP increases the likelihood for stock mounts to flex too much and or eventually fail, so Beedub's recommendation to use stiffer mounts is sound advice.
Looking forward to a dyno chart showing your new found power.
      12-18-2015, 12:54 AM   #29
Beedub
bingo bingo bingo.... this isn't a guess, it WILL happen on the stock mounts, the engine moves around WAY to much with the added Tq, HP. i watched mine on the dyno and could not believe how much the engine was lifting up, easily enough to compromise the hood.
      12-18-2015, 09:53 AM   #30
Steenos
2007 M Coupe  [0.00]
This is not a thread about replacing my stock engine mounts. It's a thread about my build process and the increase in power. Once again. Lets stay on topic.
2021 m240i on order
      12-18-2015, 12:31 PM   #31
Steenos
2007 M Coupe  [0.00]
This tune is Spot on. I can't wait to see the dyno numbers. Need to do an oil change in 500 miles too =/
2021 m240i on order
      12-18-2015, 12:51 PM   #32
Steeler
Steeler's Avatar
2429
Steenos, double check all your clamped connections. I had a silicone coupler come loose on me shortly after my installation and I think Pokey had the same. A couple of heat cycles may leave the clamps loose.
      12-18-2015, 03:10 PM   #33
Steenos
2007 M Coupe  [0.00]
Thank you sir! I'll check.
2021 m240i on order
      12-18-2015, 03:13 PM   #34
pungo
pungo's Avatar
If you post a build thread and people with lots of experience provide good advice that is relevant to the thread, you should thank them and move on, not dis what they are saying. I not sure what you consider a "build process", but bolting on some proven parts in a kit form with instructions is pretty basic stuff, it's not like you are doing anything new that hasn't been done a whole lot.
Sorry you think providing good advice to prevent damage to your car from your "build process" is off topic.
      12-18-2015, 03:24 PM   #35
Steenos
2007 M Coupe  [0.00]
I never said I was doing anything new. I was sharing my experience. It may be good advice, and I said in an earlier post, I understand the good intent of the advice. I'm not hating on Byron or anyone in this thread.
I am choosing to not do the mounts at this time.
2021 m240i on order
      12-18-2015, 03:50 PM   #36
tikamak
Lebanon
58
I broke new ones in 1 week after ESS VT2-500 the original mounts move a lot and this will let the added power massacre it in no time.
if you don't want to go with vibra technics, go with Vorshlag red ones (cheaper), they have a bolt through design that is extremely tough and provide almost no increase in NVH, use stock trans mounts, this will let you shift faster as well.
This is my piece of advice sir.
      12-18-2015, 04:50 PM   #37
Steenos
2007 M Coupe  [0.00]
Thank you and Byron for the advice.
      12-18-2015, 04:55 PM   #38
Arsonism
Arsonism's Avatar
Drives: '08 M Coupe
If you can, go Vibra Technics. They are some very serious mounts and I would vouch for them day and night.
◙ Shane
      12-18-2015, 05:42 PM   #39
pungo
pungo's Avatar
Maybe the title should be changed to Motor Mounts for "ESS VT1 455 Gen 3 Build". Just kidding...
Seriously though, how much boost are you seeing with this kit? How easy is it to break the tires loose in 2nd? Might want to enable "///M track mode".
      12-18-2015, 06:15 PM   #40
Arsonism
Arsonism's Avatar
Drives: '08 M Coupe
Sorry for the thread jack pungo
◙ Shane
      12-18-2015, 06:34 PM   #41
Steenos
2007 M Coupe  [0.00]
pungo, I'm not really sure. I need to get a boost gauge badly. Gonna get the p3 vent gauge.
      12-18-2015, 07:14 PM   #42
pungo
pungo's Avatar
The P3 gauge should should provide plenty of important data. Have you seen any of the phone apps that pulls data, including boost from the OBD II interface? Though not as clean as the P3, the price is much less.
      12-18-2015, 08:48 PM   #43
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Lol, where abouts? tower, smc or center? might have chatted to ya already
Powered by
      12-19-2015, 01:46 AM   #44
tikamak
Lebanon
58
Just to give some evidence, this is a picture of the mechanic holding the engine mounts for me.
Notice how new the rubber on the outside still is and how the engine mount was torn apart into 2 pieces.
This is the new vorshlag engin mount design and from personal experience i've liked them a LOT, the bushing are also serviceable and cost 99$
