      05-25-2018, 09:30 AM   #23
ZAR4MC
South Africa
93
Drives: '07 Z4 M Coupe
Originally Posted by Frank851 View Post
If these are the original wheels on the Z4M they should be 18" wheels, not 17" wheels.
I'm asking because style 23 wheels are 17" only. that first pic looks like style 23 on the Z4m.
http://www.bmwstylewheels.com/bmw/23
07 Z4 ///M Coupe - Sapphire Black / Imola Red
My S54 Journal
      05-25-2018, 09:38 AM   #24
MeisterS
Rennfahrer
MeisterS's Avatar
44
Drives: E90 325xi E36 M3 & E92 M3
Originally Posted by mziggy16 View Post
I don't have a whole lot of info on those wheels, but I can grab whatever you'd like when I get home.
The previous owner mentioned having spacers but I don't think they were actually installed on the vehicle. Those wheels tucked into the wheel well a bit and would certainly have benefited from spacers.
I was waiting until the Fall to sell them since they have winter rubber on them, but if you're interested I'd be happy to make a deal. I even have 2 brand new winter tires that I can include, in addition to the 4 on the wheels. PM me if you have interest.
I am tempted to go with 17" but would like to avoid using spacers. I will be interested in the wheels only but not sure if Style 23s is what I want. I WLYK
Current- Jerez Black E92 M3 | Arctic Silver E36 M3/4/5 | Monaco Blue E90 325xi
Past- AW Z4-M roadster| JB Z4-3.0si | '98 Accord V6 coupe
      05-26-2018, 11:02 PM   #25
mziggy16
Drives: '07 Z4MC, '01 911 C4 Cabriolet
Correct. Bought the car with 17" style 23's and winter rubber.
Swapped out the style 23's for the stock Z4MC 18" wheel after they were refinished.
CURRENT: '07 Z4 M Coupe /// ‘01 911 C4 Cab
SOLD: '06 330i / '07 335i / '07 X5 4.8 / '13 335i
      05-27-2018, 01:28 PM   #26
ZAR4MC
South Africa
93
and you had no issues with them touching/rubbing with the 17's?
My S54 Journal
      05-28-2018, 04:38 PM   #27
mziggy16
I did not experience any issues with the 17" setup.
It certainly handles better with summer rubber and they 18's though.
      07-27-2018, 09:57 PM   #28
mziggy16
Well, I decided to bite the bullet and take care of all the major S54 items. It all started with my first oil change when the new plug wouldn't seat all the way back in the pan. Apparently the previous oil changer didn't use a torque wrench and stripped the threads, so the oil pan needed a time-sert, which I wanted to have professionally done. I was also due for a valve adjustment...and then just went for it all.
1. Vanos Upgrade to Dr. Vanos, including seals and oil pump disc + upgraded supply lines. - The exhaust hub tab was broken (see pics) so this was a no-brainer.
2. Rod Bearings (WPC). Car had stock bearings at 127k, so I felt that it was on borrowed time. The pics looked decent for the mileage and my first Blackstone report was spotless, but there's copper visible in the closer up image.
3. Driveshaft Guibo - was cracked, plus I was getting some drivetrain vibration.
4. Engine mounts...came out in two pieces
5. Recharge the AC
6. Code out TPMS
7. Oil pan time sert
8. Valve adjustment
Pretty sure this will be my reaction when I go to pay
Shortly followed by this when I turn the key
XMetal1125.00
StickMon636.00
      07-27-2018, 10:53 PM   #29
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Bearings isn't too bad considering 127K
      07-28-2018, 12:38 AM   #30
StickMon
StickMon's Avatar
Drives: 2006 MR
Pretty much the same that I did at 127k.
      08-07-2018, 08:48 AM   #31
mziggy16
Some updated pictures post Vanos work and after getting the intake shroud re-powdercoated. Engine bay is finally looking better, but still needs some detail work.
Vanne1620.50
      08-07-2018, 08:50 AM   #32
mziggy16
A quick run to Ikea and a pic of a dirty car + debadged the M's off the side. Anyone want to guess the car in the Z's reflection?
      08-09-2018, 01:05 PM   #33
cooticooti16
cooticooti16's Avatar
44
Drives: Lexus
Acura MDX.
What do I win?
      08-23-2018, 08:52 AM   #34
mziggy16
Originally Posted by cooticooti16 View Post
Acura MDX.
What do I win?
Correct! You win the satisfaction of knowing you won
Got the orange bumper reflectors out and painted to match the body.
