      07-27-2009, 01:00 PM   #1
alekos911
alekos911's Avatar
Greece
Drives: z4 coupe 3.0si-996 carrera 4s
Clutch chatter
I am a happy owner of a Z4 coupe 3.0. The car is perfect but there are some issues I have to cope with. The main issue is the clutch chatter. After some search in some others forums I noticed that this must be a common problem. HAs anyone had problems with the clutch? Is this a problem or something annoying. Thanks in advance.
http://www.z4-forum.com/forum/viewtopic.php?f=3&t=10553
Thank God for creating MAN to create THIS CAR
(ps: I am trying to improve my fluency in English, so feel free to correct me when it's neccessary)
      07-27-2009, 01:16 PM   #2
E82tt6
E82tt6's Avatar
104
Drives: '08 Black Saphire Z4 MC
It's there with my z4mc, I find if I take off at slightly higher rpms it isn't as noticable n
'08 Black Saphire/Black Z4 M Coupe
RIP Gretta: Blue Water/Lemon 135i. Died to save me.
-ChuckV
      07-27-2009, 11:32 PM   #3
VitaminT
Drives: 2006 M Roadster
If you are talking about chatter on clutch let out then it is pretty normal considering that I believe both 3.0i and M use an unsprung clutch disc which is different from most cars on the road.
      07-28-2009, 11:25 AM   #4
alekos911
alekos911's Avatar
Greece
When the engine is idle, I hear a tak tak tak...Then I press the clutch pedal and the sound disappears. Apart from that the clutch works perfect
      08-01-2009, 10:26 PM   #5
blender
Custom User Title
blender's Avatar
Drives: black
I have a certain amount of clutch plate chatter when I de-clutch first gear. My mechanic says it's from the two plates in the twin-plate clutch separating as they spin down. Seems logical in the absence of any information to the contrary.
      08-14-2009, 05:19 PM   #6
SSG S
Drives: DINAN Z4
I HAVE THE SAME PROBLEM!!!
I was driving yesterday and i decided to do some "spirited" driving and now that tak tak tak that i would get when the clutch was pushed in and then would go away a few moments later, ended up getting 10 times worst! I was told i need a new clutch... any advise on this? anyone had this problem before? PLEEEAAASE HELP GUYS
      08-14-2009, 08:00 PM   #7
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Except that it's not a twin disk clutch. But it is normal.
      08-30-2009, 02:53 PM   #8
alekos911
alekos911's Avatar
Greece
This is not my car but this sounds similar to mine... God HELP!
http://www.youtube.com/user/VideoPost2010
