      02-14-2009, 01:17 PM   #1
angelsz4
silver bullet
angelsz4's Avatar
Drives: bmw z4 silver bullet
service engine soon whats this
what goes in here? when you open it can you see the fluid. the reason i ask is because my service engine soon light came on and i checked all other caps and they all look good but not sure on this one. thank you
      02-14-2009, 01:42 PM   #2
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Muffler bearing fluid goes there. Autozone has some but it's behind the counter so you have to ask for it. Anything DOT approved works.
      02-14-2009, 01:47 PM   #3
angelsz4
silver bullet
angelsz4's Avatar
thanks, can you see the fluid in there when you open the cap?
      02-14-2009, 01:57 PM   #4
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Muffler bearing fluid is pretty clear, it's hard to see. That's why there should be a little thing floating in there to indicate the level. If the little stick like thing is floating about flush with the top of where the cap screws on your good, if it's not then you need to refill it immediately.
Regular distilled water will work temporarily like from CVS (NOT TAP WATER), but if it was low you need to go to autozone some time soon and get the fluid.
Can you take a pic with the cap off?
      02-14-2009, 01:59 PM   #5
angelsz4
silver bullet
angelsz4's Avatar
sure check back in 2 min. i think its low if i remember correctly. what that make the service engine soon light come on?
      02-14-2009, 02:03 PM   #6
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Only if it was really low, and there is a separate light on most cars for if the MBF gets low because of its importance.
Again taking the car to Autozone and they can scan the code for you through the OBDII port and tell you what it is for.
      02-14-2009, 02:05 PM   #7
angelsz4
silver bullet
angelsz4's Avatar
i hope thats what it is. i checked it and it doesnt seem like any is in there at all...... once i put it do you think the service light will turn off ?
thanks again
      02-14-2009, 02:10 PM   #8
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Holy shit, that is bone dry man, that might actually be the cause of your SES light, I would fill it up with distilled (again NOT tap water or any type of mineral water) if you have any on hand in your house before even going to get any fluid.
BMW actually recommends only using their fluid but distilled or generic fluid from autozone works to correct just a little low level. But since you have to add so much I might go ahead and use the BMW fluid.
      02-14-2009, 02:10 PM   #9
angelsz4
silver bullet
angelsz4's Avatar
any type that i should get. or is it pretty general
      02-14-2009, 02:13 PM   #10
angelsz4
silver bullet
angelsz4's Avatar
DARN the dealership is closed!!!!! i just missed them by 13 min ... no driving for me
hey thanks again O-cha
      02-14-2009, 02:13 PM   #11
O-cha
O-cha's Avatar
218
Drives: Mcoupe
See above post, BMW recommends their fluid. You might just go to the dealer and get a jug of it, mix it 50/50 with distilled.
      02-14-2009, 02:17 PM   #12
angelsz4
silver bullet
angelsz4's Avatar
what is it 100$ a cup. Stealership!!!
      02-14-2009, 02:21 PM   #13
O-cha
O-cha's Avatar
218
Drives: Mcoupe
About $20 for a jug which I think is 1.5 gallons?
      02-14-2009, 02:22 PM   #14
angelsz4
silver bullet
angelsz4's Avatar
do i have to mix 50/50 or straight ok.... sorry im an idiot when it comes to things and i wanna be super careful
      02-14-2009, 02:26 PM   #15
O-cha
O-cha's Avatar
218
Drives: Mcoupe
It needs to be a 50/50 mix.
      02-14-2009, 06:39 PM   #16
O-cha
O-cha's Avatar
218
Drives: Mcoupe
I figured someone would tell you by now.... That's for your coolant, and you're low, empty really, which is really bad. The muffler bearing thing was a joke, but everything else I told you was true, just replace "muffler bearing fluid" with "coolant".
      02-14-2009, 08:09 PM   #17
Tonybest
Enrollment Officer
Tonybest's Avatar
Drives: 997.2 Porsche C4S
I was wondering when you were going to tell him.
Flux capacitor jell recipient.
      02-15-2009, 06:18 PM   #18
angelsz4
silver bullet
angelsz4's Avatar
damn you!!!! And here I was thinks "what the hell is that". So would you still recommend the one from the dealership
      02-15-2009, 10:03 PM   #19
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Yes, and like I said everything I said actually applies to coolant, and yes it is VERY bad that your expansion tank is empty.
So long as you never overheated it's OK, but it's not a condition you ever want to drive around with.
