07-20-2007, 09:25 AM | #1 |
Rep 199
Knocking noise from front suspension
Hey guys,
Anyone expierenced any knocking noises coming from suspension? the noise seems to come and go inconsistantly i could go over the same bump twice at same speed and only hear it once im gunna book it in after the weekend but this is just gunna bug me over the weekend >.< ive had problems with a previous m3 and that was shocks and on another occasion ball joints and wish bone which i know is a common thing to go wrong on e46... does the Z4 coupes suffer from anything prematurely suspension or otherwise? thanks in advance guys Cris EDIT: cars only done 9k btw |
07-20-2007, 10:05 AM | #2 |
M = Midlife Crisis
65
Rep 2,006
Only the well commented on popping from the rear towers when turning slowly over bumps on inclines. Nothing from the front end.
2006 Z4MC - #LL93158
07-20-2007, 01:07 PM | #3 |
Rep 14
I just brought my car in 2 days ago for the same problem. It sounds like a single pop noise when I go over a small ditch or bump. The dealer just fixed it and told me it is a defective shock mount, which was changed. So, definately bring it in and have them change it for you.
07-20-2007, 01:18 PM | #4 | |
Rep 199
anyone kno of any other defects the Z suffers from? |
07-20-2007, 04:43 PM | #6 |
Rep 199
07-20-2007, 08:30 PM | #7 |
My favorite sign.
169
Rep 4,333
I've been hitting alot of friggin pot holes and drains and other friggin obstructions since getting back up NE. And I thought the roads in SC were bad...
I guess I'll have to start listening for unusual noises...but the thought of it is kinda scary...I still haven't found a new dealership...
07-20-2007, 09:40 PM | #8 |
Rep 821
Oh, hey, so you guys know...
I was hearing a clunking/popping noise coming from my front suspension when I would go over small bumps and ridges at low speeds and with the wheel turned... Took it to the dealer, and they fixed her up by re-torquing some of the bolts on the engine mount braces - or so they told me. I had read about alot of people hearing this same, or a similar, noise from the front or rear suspensions, and many people have posted that the re-torquing of some bolts usually fixes the problem. So if you're experiencing the noise, I think your best bet would be to go to the dealer, tell them about it, and ask them to double check the bolts either in the front or the rear (could be the engine mounts, strut towers, suspension mounts, etc) and have them re-torqued if necessary. Hope that helps anyone who has the problem. I know information regarding the issue is ALOT scarcer than it should be, considering how widespread it is. Everything from 3er to Z4s to X5s have reported it!
Guy #1: "Hanz, I know zee window switches have always been next to zee shifter in zee 3er cars, but I think ve should move them to zee door!"
Guy #2: "But zee doors are already designed and ve do not have time to re-design them!" Guy #1: "Just make it verk or you vill be verking over at VW!" |
10-01-2007, 05:37 PM | #9 |
Rep 80
Yeah I have this too. A few days ago it got worse. Its random and annoying. Sometimes it happens constantly for a min. And sometimes it never happens at all. I just ran outta warranty on mines so I gotta figure this out and replace what ever is busted or worn out. Anyone else have any suggestions?
10-01-2007, 11:36 PM | #10 |
Rep 1,066
Drives: 2015 X5 50i M Sport
It happened to me when my car had about 3100miles on. At first it wasn't consistant, could only hear it in big bumps. But 2 weeks later, it got worse, it happened even when i shift. I brought it to dealer and they said it's just a loosen screw between the engine compartment and dashboard.
2019 Cayenne Turbo
Gone but not forgotten: 2006 2.0T A4 Avant, 2007 Z4 Roadster 3.0si, 2006 M Roadster, 2013 550i M Sport, 2015 Cayman S, 2015 X5 50i M Sport |
10-02-2007, 07:48 PM | #13 |
My favorite sign.
169
Rep 4,333
10-04-2007, 09:53 AM | #15 |
Rep 19
When gas presurized shocks begin to fail they sometimes (maybe always) make noises over small short-interval bumps. It is often heard at low speeds. The noises are not a rattle (multiple sounds). A sure sign of gas shock failure is oil seepage. This leakage is not likely to be seen on your garage floor as it is usually absorbled by road dirt. Your shock will appear to have an oily grime.
10-04-2007, 11:55 AM | #17 |
Rep 11,667
IIRC there is a TSB on this with revised mounting hardware
10-04-2007, 08:58 PM | #19 |
Rep 88
Drives: 06 M Roadster
It is the bolts on the strut braces. They come loose and when the body flexes they make a popping sound. Take it in to service, tell them they have a service bulletin on it and they will fix it. Only takes a minute.
10-04-2007, 09:01 PM | #20 | |
Rep 339
10-07-2007, 01:39 PM | #21 |
Rep 10
Wow, I've been hearing that for awhile. In my case I took it to 2 different dealers who told me they could find nothing wrong. A service manager even went for a ride with me to hear the noise, of course I couldn't get the noise to happen. One mystery solved, thanks!!
Now if I could figure out the random DSC engagement problem. Oh, and the air bag "off" problem and then the air bag warning light problem. All random and intermittent yet not a problem according to the dealer. |
10-25-2007, 04:53 PM | #22 |
Rep 80
My problem is a shocks. After i took the springs off. I found that the shocks compress really easily. No oily film but I can hear a swishing sound as i manually compress the shock. I shoulda taken it to the dealer while under warranty. Oh well.
