      09-29-2011, 12:49 PM   #1
Huz-Z
Huz-Z's Avatar
Quick Question - Rear jack Point???
guys - quick question!
Where are the jack points if a fella wanted to lift the back of the car to pull the rear wheel off? A buddy of mine thinks he has a slow leak in one of the rears.
Thanks!
Huz-Z
      09-29-2011, 02:27 PM   #2
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
If it's like mine you can use the rear brace point that's right in front of the diff as a jacking point as well. Do not use the diff itself! There are two jack points right in front of the rear wheels as well.
The jacking point in front of the diff method only works if I drive the car onto two 2x6 planks though (not much clearance under the rear). I also always use actual car stands under the side jacking points before messing around with anything--not safe with just a floor jack.
Chris has a DIY that describes it step by step.
      09-30-2011, 12:04 AM   #3
zubydafa
tosser
Isle of Man
32
Drives: '07 Z4MC
should i be worried?
my M3 had a rear mount point in the center of the subframe. no such thing in this car so i lifted via the rear diff once.
'07 MCoupe
lots of mods
      09-30-2011, 12:41 AM   #4
l4zy
l4zy's Avatar
Drives: 95 M3, 15 i3, 17 M3 Frz Wht
2017 BMW M3  [0.00]
2015 BMW i3 REX  [0.00]
1995 BMW M3  [10.00]
2013 BMW X3 xDrive35i  [7.00]
crfine88 shows how its done
      09-30-2011, 07:36 AM   #5
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
An alternate to the way Chris does the front.
I used to go in from the front instead of the side.
I rolled up on a couple of planks to get clearance for the jack.
      09-30-2011, 11:54 AM   #6
Huz-Z
Huz-Z's Avatar
Thanks guys!!!!
Huz-Z
