      03-20-2017, 12:14 PM   #1
imported_mega
No_Country
122
Drives: various bmw's
Soft top hydro pump not working
The hydralic half of the soft top motor/pump serviceable?
My motor was bad, cleaned it up and fixed it. Now I'm looking at the pump and the bypass valve thing is stuck, permanently bypassed it does not push back against the bypass lever at all.
Any way to open these up and clean out the thing?
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten..
1974 2002, many various 3s.
      03-20-2017, 03:05 PM   #2
Spaceman Spiff
Drives: R8, 996 C2, Z4MR (sold)
Before you open up, take a look at the ball bearing inside that blocks the hydraulic oil line. On my 2nd pump it was half corroded inside.
These pumps are pretty easy to pick up for a few hundreds (or lower if you pull at junkyard) - Depending on the current shape, it might make sense to just replace the pump at this point to make sure you won't have to revisit in the near future.
      03-20-2017, 03:15 PM   #3
imported_mega
No_Country
122
How do you get to it? It's definitely corroded the whole thing is
      03-20-2017, 07:07 PM   #4
Spaceman Spiff
It's been a while since the last time I did mine, but IIRC the bypass mechanism is encased in a black plastic piece that's attached to the motor and can be easily removed (toward the top where the hydraulic lines are attached - Pretty large plastic piece). Remove that and you'll see the valve and the little brass stopper that moves when you pull the bypass cable. On my second pump the stopper part was half gone.
      03-20-2017, 07:21 PM   #5
imported_mega
No_Country
122
the brass part is stuck in the side of the housing
      03-20-2017, 07:54 PM   #6
Spaceman Spiff
Yep that's the part. It's a brass ball should move inward 2-3mm when pressed on.
      03-20-2017, 07:55 PM   #7
imported_mega
No_Country
122
is it removable? mine is stuck in
      03-20-2017, 08:30 PM   #8
Spaceman Spiff
It shouldn't come out of the housing, but should move a few mm in when you press on it (which is what happens when the trunk bypass cable is pulled). Again, I am remembering all of this from a couple of years ago so might be a bit foggy there.
