05-11-2012, 04:40 PM | #1 |
Rep 4,531
Blackstone Oil Report: Cause for Concern?
Report shows some extra metal that is usually contributed to rod bearings. My temperatures do rise alittle ONLY when I'm autocrossing. Immediately after the temps fall under 210F again and never get above that during DD. As well, anything that can explain the gas?
Thoughts? |
05-11-2012, 08:39 PM | #2 |
Rep 376
Those number are high but not quite to the panic point. The iron has more to do with the amount of time the oil was in use than wear it seems. Lead would be worrisome to me at 9-10PPM on a 4K oil change interval. Your change interval was too long to to jump into swapping bearings. Reduce the interval to 4K and see if wear decreases. I would sample at 2K and 4K followed by a change to see if your wear numbers are trending higher than average then decide what to do.
Also, Google "S54 Oil Analysis" for some interesting reading. http://www.bobistheoilguy.com/forums...Number=2482388 FWIW, I would panic at or around 15-20PPM of lead on a 4K change interval.
Mods: OEM Euro Headers, RPI Scoop Daily: 2010 Tacoma Double Cab |
