      04-05-2012, 08:38 AM   #1
Addeg
Drives: 06 Z4 M Coupe ESS VT1-445
Help with VT1-450 belt question
Hello guys!
Since we are not allowed to modify our cars here in Sweden and are by law required to go through a inspection once a year, i now need to take my belt of the supercharger unit.
Although that might not be enough for me to clear the inspection(it has been reported to work in some cases), i think it might be worth a try so i dont need to remove the whole S/C unit.
Since im no mechanic myself, how would the car function without any belt at all/with stock belt? Keep in mind that i need to clear some exhaustvalue tests.
Any thoughts?
      04-05-2012, 08:58 AM   #2
Beedub
Originally Posted by Addeg View Post
Hello guys!
Any thoughts?
put a stock belt on the car, this will bypass the s/c system, run the car with the stock tune and it will be fine.... if it was me id leave all that alone get a cover fabricated that can bolt over the s/c unit, this way they wont know and it looks so stock lots of people wonder whats whats anyway....
btw my car passed all smog tests with stage 2 tune..... it'll pass the emissions, trust me!!
      04-05-2012, 09:11 AM   #3
Addeg
Sounds good!
I think i'll go with the stock belt, although, how much work is it vs removing the whole unit? Is it a easy task returning to stock belt? Any guidelines?
To run the car with stock tune, what do i need to do/purchase then? Since i let the guys in norway install everything for me im pretty clueless regarding this :P
Thanks for the answer
      04-05-2012, 09:15 AM   #4
Beedub
Sounds good!
the stock belt just bypasses the supercharger, but you can still see it??? so whats the point???
Re the stock tune, buy the ess flash tuner and just load it up to your car, they will have the stock z4m file their, you already own it as part of the s/c purchase price....
holy shit this sounds expensive..... i defo wouldnt put myself through this if the law meant i had to do what your doing.... forget that....
still think the best option is to run a cover, i have a friend in norway who;s done just that and passes everytime no problem...
      04-05-2012, 10:04 AM   #5
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
Probably easier to bribe the inspector with some beer
      04-05-2012, 11:25 AM   #6
Beedub
Dont be so stupid.....
you'd need naked hookers or AT least herion mixed with some sort of crack cocaine......
      04-05-2012, 11:35 AM   #7
Addeg
A cover might not be that stupid after all. Is it in some way possible to reduce the S/C noise? If thats the case this option would by far be the best!
Could you get your friend to post some pictures here? Would help alot seeing his solution.
      04-05-2012, 12:14 PM   #8
Beedub
Hes not on here but ill grab some pics, he made the cover using sheetmetal painted black. Looks verryyy covered. Lol
Mines pretty quiet at idle, is urs noisey??
      04-05-2012, 03:19 PM   #9
ZStig
279
you're being redundant.
I agree on making a cover for it. Should pass visual inspection. Its also quiet enough for a normal tech to think its a stock sounding engine. As for the emmisions, my car does not pass, and ESS said they were not designed to pass
      04-06-2012, 03:45 AM   #10
Beedub
lol redundant... :-) ha ha ha ha.... lol i liek that one.... hookers and coke will only work for bribery reasons, i promise!! lol
i have the uk pass sheet for ALL emissions tests :-) shall i post an iphone pic of this sheet?? if the stock cats are in place their is absolutely NO reason why this cant cant pass any tests a stock car would.... bare in mind during tests this car is making 0 boost....
      04-06-2012, 07:21 PM   #11
ZStig
279
mine's dirty, what else can I tell ya?
      04-08-2012, 01:00 AM   #12
Beedub
By the sound of things if my gf was as dirty as your car id be happy !!!
Lol.....
