      02-16-2014, 05:29 PM   #1
bryanm70
Drives: E85 Z4 M54B25
Need help finding transmission drain and fill plug
Hello, I drive a 2004 2.5i Z4 with an SMG transmission. It has about 73k miles on it and the gears are being sluggish and sometimes the gearbox doesn't re-act to my downshifting. I figure I would start by changing the transmission fluid and go from there, but for some reason I don't see any 17mm drain or fill plug. While I was under the car I noticed a leak as well which is included in the pictures. Any ideas on what it could be is greatly appreciated. Thanks in advance for your kind help, everyone.
      02-16-2014, 06:46 PM   #2
Small Yellow
Track Addict
Small Yellow's Avatar
Taiwan
110
Drives: 2010 BMW M3 E92 | 2008 Z4M E86
Drain is on the bottom. Should be the plug in first picture. Fill plug is on the side and should be the same plug. I cant tell the rest from the pictures :/
BMW ///M3 Coupe
Completed November 16, 2009
Received December 29,2009
      02-20-2014, 11:09 PM   #3
bryanm70
It must not be a 17mm then...I will get more pictures up Saturday for sure. Any ideas on what's leaking?
