05-03-2012, 07:40 PM | #23 |
Rep 81
05-04-2012, 02:09 AM | #25 |
Rep 380
Good luck for your sale my friend..Can you please sent your cars pics with the last setup because its awesome..
Z4MC_Black Sapphire/Imola-_-DMS ECU ll H&S cat-back ll H&R coilovers ll CF Lip ll Lamin-X ll Matte black kidneys ll Afe drop in ll Afe intake elbow ll RPi scoop ll LeatherZ imola shift boot ll ZHP knob...
05-04-2012, 09:26 AM | #27 |
Rep 317
love the wheels... I wish I was looking for a set glws
K&W v3, APR splitter, magnaflow axle back35% tint, stubby antenna, Jet black, and interlagos blue stock wheels, clutch delay delete, illuminated ZHP shift knob, Leather Z m shift boot, and arm rest.
05-04-2012, 10:18 AM | #28 |
Rep 1,224
Fronts should be fine. Iffy on the rears depending on offset. My guess is anything in the correct offset range for the Z4M will be to much with that wide of a wheel for a non-M. If I thought they would fit I'd be all over them.
Shimmy, what are the offsets?
05-04-2012, 05:26 PM | #29 |
Rep 218
I cant really remember exactly but i think it was 22 for the rear and 26 for the fronts... If ur really interested i can pm u the numbers in the back of the wheels maybe that would help...
05-04-2012, 09:56 PM | #30 |
Rep 1,224
Just post the numbers, it will help any potential buyers (other models?). If your memory is good or even close your wheels will absolutely not fit a non-M Z4 in the rear. The factory M wheels (9" wide) on an Si will barely fit with a minor amount of rub which can be dealt with by being careful with tire size and corner profile (rounded v squared). 10" with that offset is a no go!
05-05-2012, 02:23 AM | #32 |
Rep 218
Ooops sorry bout that good thing you spotted that... Thanks got confused cause i recently swapped tires for my m3 and got falkens... Again my apologies
05-05-2012, 08:39 AM | #35 |
Rep 250
TOYO T1R's
235/40/18 fronts 265/35/18 rears HRE 547R 18x8.5 36ET, 18x10 18ET, Can you please confirm above is correct. I found info on some of your other posts. Is tire wear even? Pics look like inside edge are worn. What is DOT number on the tires showing the manufacture date, how many miles on them? Do all the wheels have curbage or scratches. I can't tell if pics are of one or all of them have some damage. Safe to assume center caps are also included? They look great, your new set up is also very cool. Thanks. Last edited by Punko; 05-12-2012 at 07:06 AM.. |
05-07-2012, 09:40 AM | #40 |
Rep 218
Correction on specs, i just called hre and heres the specs.. wheels are for M coupe 18x8.5 et 36 18x10 et 18 they also confirmed the wheels being legit.. so no more worries for you guys thinking its replicas...
05-07-2012, 09:53 AM | #41 |
Rep 218
Inside tire wear was from the alignment i got from platte forme.. rear tires were brand new and was only used for 2-3 months fronts might still have some life in them.. curb rash is on both driver side wheels.. tpms is not included and yes center caps are included in the sale...
