04-13-2016, 11:16 AM | #1 |
Rep 12,565
FS: Track Ready 3.0si Coupe 6MT (Silver on Red)
Not sure if I want to pick up a 3rd cheap commuter car or just sell the Z and get a better suited DD. But in case anyone's lookin, posting a feeler for for a very well sorted/maintained 3.0si track ready coupe with 85,xxx miles. Click on my garage link to left to see pictures. Exterior is a 9/10 -- track car that could pass for a show car after a nice detail. Paint is in great shape, car is mechanically sound, never money shifted and meticulously maintained. Clutch is still good since BMW replaced it under warranty. Last Blackstone oil analysis done at 75,000 miles and showed clean bill of health. Car weighed 3023lbs after rollbar was installed. I have a a folder full of service records & receipts. Regular maintenance includes Synthetic oil change every 5k Air filter every 10k Cabin filter every 15k Brake flush 2x per season Differential flush every year Manual (lifetime) transmission flush every 35k FCAB and RTAB every 40k Spark plugs at 60k Front lower control arms at 85k Maintenance in the last 20k Coil packs Alternator Water pump, thermostat, oil filter housing gasket Valve cover & valvetronic gaskets Eccentric shaft sensor DISA valve (exterior) Rear O2 sensors (both) Vanos solenoids (intake & exhaust) Things replaced under warranty Valve lifters Clutch replacement Major modifications - BMW Aero trim (bumper, rockers, CF spoiler) - AA flash + o2 simulators (passes emissions)) - Supersprint headers + custom 3” catback - MFactory 1.5 way lsd w/ 3.73 final drive - Recaro Pole Positions (Jersey Red) - Schroth 6pt 3" harnesses (x2) - Custom welded half cage (Imola Red) - TC Kline D/A & GC Hybrid camber plates - H&R adjustable front sway bar - Bimmerworld brake cooling w/ 3" hoses - BMW Performance strut bar - AutoSolutions short shifter kit - Bimmerworld Group-N motor mounts - GLS TopStud 82mm class 12.9mm studs - Reinforcement plates (front sway, front strut, rear spring perch) Chasing a 302 at the Glen Fighting through traffic at NJMP Exhaust start up post resonator install (no more rasp) Last edited by 3002 tii; 04-19-2018 at 10:43 PM.. |
04-13-2016, 02:07 PM | #3 |
Rep 12,565
76,xxx and won't move much since not daily driven. Not sure but maybe e90 m3.
04-14-2016, 07:37 AM | #5 |
Rep 12,565
lol just throwing it out there. I'm totally content keeping her for another 7 years
04-14-2016, 07:55 AM | #6 |
Rep 11,667
04-14-2016, 10:00 AM | #7 |
Rep 12,565
Each passing year the decision to keep actually becomes easier as I find less and less "new" cars out there that will offer same fun factor without paying double my asking.
I guess the real issue is why I'm doing less and less track days as time goes by. Last edited by 3002 tii; 04-14-2016 at 10:29 AM.. |
04-14-2016, 07:34 PM | #8 |
Rep 182
GLWS if you decide to go that route, just a fun fact for you; before I pulled the trigger on my coupe, I lurked around this board for things to look out for. I remember seeing your SIG picture and your car, taking (what looks like) a long left. It looks so much like the Jag E-Type coupe, but somehow more vicious, that I knew I had to have mine.
04-15-2016, 03:53 PM | #9 |
Rep 535
It's a bummer to see this potentially go but a E90 M3 is a solid reason. I have one alongside my Z4M and it is an absolutely fantastic car. Good luck!
05-24-2016, 02:31 AM | #10 |
E86 M Coupe
265
Rep 403
Bump for this great car and awesome member!
05-24-2016, 10:16 AM | #11 |
1621
Rep 4,294
far out mate, after all that work you put in her. I understand the pull, but hope you can resist.. Bump-age for awesome sorted Coupe
Loving it!!
Powered by |
05-25-2016, 07:18 AM | #12 |
Rep 12,565
Thanks guys, I'll be up at Lime Rock next month in case any local folks want to check her out.
05-28-2016, 09:29 AM | #13 |
dances with roads
4729
Rep 4,096
