11-07-2019, 01:26 PM | #23 |
Rep 264
11-15-2019, 09:39 PM | #24 |
Rep 6
Great review, I was also on the market for one and after driving Vanne's car I knew I wanted one but the butchering of the interior was a deal breaker.
I finally pulled the trigger on a IRP (which I will post a review) and like Vanne said it's the best Mod ever for the Z |
12-28-2020, 10:01 PM | #25 |
Rep 701
Just an update for anyone who is thinking about doing this. Do NOT forget to re-use the OEM rubber shifter boot. I originally junked mine because it was easier and as a result the heat rising from that area was insane. It felt like you had the heater turned up to max all the time.
Needless to say, I had to do the entire unpleasant job twice as it was unbearable. Had to buy a new one and do a little trimming for it to fit, but after installing it the difference was incredible.
01-19-2021, 11:21 AM | #27 |
Rep 1,543
You can check out PSDesign shifter.. they are the same thing. Same origin I heard.. no affiliation.
01-19-2021, 03:38 PM | #28 |
Rep 134
01-19-2021, 06:06 PM | #29 |
Rep 701
The PSDesign shifter does look to be made by RTD just rebranded under their own name. This wouldn't be a huge surprise as they seem to be an RTD dealer.
However, the PSDesign shifter is not a lockout design nor does it feature adjustable side stops for 1-2 and 5-6 shift like CAE and the RTD REVO1. Never the less it is available in both 300mm and 360mm heights if that is all you are looking for. RTD is still available, look at their Instagram page for updates on production timeframes. Maher always delivers.
01-19-2021, 08:25 PM | #30 |
E86 M Coupe
265
Rep 406
I have a PSDesigns chassis mounted 300mm shifter! Hands down one of my favorite mods! Thanks for making this thread! Helped tremendously!
01-20-2021, 11:35 AM | #31 | |
Rep 298
Quick Q - I have a psd shifter being installed next week and have a new oem dust boot ready to go on. It looks like you’ve just trimmed the top tube which the shaft goes through, and then bolted the shifter on top of the rubber on the transmission tunnel. Do you feel any slop/slack in the shift given the shifter cage is sitting on the rubber and not the chassis direct? Also I not you’ve not cut off the bottom of the boot? Does this interfere with the shift action? Thanks for the idea of doing this in the first place - great encouragement to get on with it! |
01-20-2021, 03:11 PM | #32 | |
Rep 701
Well no, firstly the shifter is not 'sitting' on the rubber boot. Please look carefully at the picture and you will see I used three washers to clear the bottom lip of the boot from the top. The front washer I ground one side a bit flat to clear the boot so I did not have to trim the top flange. The washers I used were thicker than the thin rubber base flange on the top side. Believe me, when you torque all three bolts down it is metal on metal contact. Secondly, the bottom of the boot has been cut to clear the front bolt and DSSR. Please see the second picture. If you do not do this you will get rubbing as it sits very close to the bottom of the trans tunnel already.
01-20-2021, 03:45 PM | #33 | |
Rep 298
02-05-2021, 04:15 PM | #34 |
Rep 298
Just to update the thread, I’ve now fitted the psd shifter per Mr Anile8’s instructions with the oem boot in place. Works perfectly with no additional noise but a much shorter, crisper shift. Very pleased.
Ps no idea why photo is upside down! |
08-05-2022, 12:28 PM | #35 |
Rep 37
RTD’s site doesn’t list a Z4 M specific shifter. Is the correct one to order the e46 model (and NOT the e8x / e9x model) even though we have a different transmission to the M3?
How does the RTD race lever compare in terms of height and resistance to the CAE? |
06-04-2023, 06:18 PM | #36 |
Rep 37
Anyone with an answer here?
06-04-2023, 08:48 PM | #37 |
Rep 701
You want a E30, E36, E39, E46, E60, E63 shifter, the direct ordering link was provided in #1 post of this thread. For the Z4 platform you need to reverse-fit it as already discussed. The same goes for the CAE unless you want to start cutting up your interior trim.
Well unless this is a trick question the CAE Ultra Shifter is listed on the manufacturer's website as 315mm, the RTD as already mentioned in post #1 is 360mm for the Race version, so unless I'm mistaken the difference would be 45mm. Resistance will be determined largely by the height of the shifter as both offer a race chassis solid mount shifter with a through bushing design. Generally, the longer the shifter, the lower the force needed.
