07-21-2016, 11:25 PM | #1 |
Rep 204
need to buy new headlights..bi-xenon
My headlights are bi-xenon in my 2007 bmw z4 coupe, but as I stated previously the paint is bubbling (should of never painted them), and I need a new set. If I buy a set that's not bi-xenon can I convert them to bi-xenon somehow? How much is it to do this usually? Thanks.
07-22-2016, 10:24 AM | #2 |
Rep 187
I doubt they can be converted, and not likely worth the cost to do so if possible. Most xenon assemblies are wildly different in design than their halogen counterparts in terms of the wiring, projector size/shape, ballast mounts, etc.
Good luck on the hunt, shame about the mod failing. Headlight housings get HOT. |
07-22-2016, 01:09 PM | #3 |
Rep 4,057
Isn't it possible to buy a zenon retrofit kit for cars that have conventional headlights? If so, you could hunt up conventional Z4 headlights for your car and use them to replace the damaged zenon assemblies (which are crazy expensive). And then convert the replacements to zenon.
Huz-Z
07-22-2016, 01:58 PM | #4 |
Rep 4,057
Or, as suggested by AmmarYasirA here:
http://www.zpost.com/forums/showthre...9#post20296819 repaint your housings. Or perhaps try to remove the paint altogether and restore to OEM.
Huz-Z
07-22-2016, 07:04 PM | #5 |
Ammar
73
Rep 406
lol, J-Thurm Bud, no need to double post
-Here's a link to OEM black housings that are halogen (You're looking at the very least $500+ for a xenon conversion on these) -I did see another OEM Xenon headlamp on Ebay that had black housings, but I cant seem to confirm the part number on RealOEM. (These are going to cost a fortune if they're new, and used ones are still expensive... and used) -You could also go with Spyder headlights or some other aftermarket headlight but I haven't really heard any great reviews on them. And IMO, they dont look half as good as OEM. (Still cost over $200+) Once again, I implore you to just refinish your current headlights one more time. You'll have the opportunity to truly make them individual (again) to your car, and make them more durable, not to mention save you A LOT of $$$$ There ARE ways to convert halogen to Bi-xenon (look up theretrofitsource), but honestly, again, Its just sooo much cheaper to just redo the ones you already have. This time, just have them done by someone who has a lot of experience with headlight customization or retrofitting. TONS of people out there to choose from other than the ones BMW forums are used to.
2018 F150 Platinum - Black/Black - Leveled on 34's - DD |
07-22-2016, 07:37 PM | #6 | |
Rep 204
07-22-2016, 07:57 PM | #7 | ||
Rep 1,689
They specialize in headlights and the quality is very good. |
07-22-2016, 08:15 PM | #8 |
Ammar
73
Rep 406
The thing is, I get that headlights are exposed to the elements and it can get realllllyyy hot. And Paint may very well be the culprit in your scenario, BUT another thing that might be an issue is prep-work. It may not have been 100% properly prepped before they were painted. You have to make sure that you absolutely clean up any surface that you're painting and DEFINITELY get rid of the old paint. Pretty sure that's common knowledge, but I still had to mention it.
There are a plethora of ways to do what you want to do, but you really just have to see what you want. Also, you're seriously just a really quick Google search away from seeing what's out there, what's been done, what's held up the best, and how it was done. If you want an absolute expert opinion, start looking up professional headlight retrofitters/custom shops and call/email them and get their opinion on what you should do. IF it were me, and I wanted to do black housings ( I dont ), Id take the headlights apart, separate the housing from the rest of the headlight assembly, have it (housing) completely sanded down/stripped/sand blasted/etc (whatever got it down to bare plastic) and then probably just get them powdercoated. Its overkill, unnecessary, and might be a little more expensive than some other options out there, but just keep in mind that people get their wheels/brakes powdercoated because of its resistance to heat. This, however, is not your only option, and as I said, its kinda overkill. But its just something I would do. (Or think I would do) As far as light output on the road is concerned, all of the Z4's have bulbs inside projectors (pretty sure). The only time painting the housing would make a (major) difference in light output, would be if the bulb was in a reflector bowl (which it's not). If you reaaaalllyyy wanna get better light output, your next step would be to get a clear lens swap and maybe new bulbs preferably during your process of painting the housings. hope this helped.
07-22-2016, 10:53 PM | #9 | |
Rep 204
07-23-2016, 02:15 AM | #10 |
Ammar
73
Rep 406
I have like... negative experience with taking the headlights apart lol. Although it is a project I have been thinking about doing in the future.
However, its been done before. I'm also pretty sure there's a thread around here that someone made a DIY about taking the headlights apart. Id still consult with a true expert on powder coating the housings before actually doing them. Im sure there are other ways of doing what you want and powder coating may or may not be the best idea. I just thought of it because it seems like a great idea. I might be completely wrong.
07-23-2016, 02:32 AM | #11 |
Rep 204
Also, the housing is chrome because it extends the width of the beam. I think that's why my lights are looking all messed up and all over the place. I hope after I paint them again with whatever I decide to use will fix this issue somehow.
07-23-2016, 12:28 PM | #12 |
Rep 912
07-23-2016, 03:39 PM | #13 |
Ammar
73
Rep 406
They wouldn't make black housing headlights if it ruined light output. Like I said, all of these headlights have projectors with bulbs behind them. The projectors themselves have a reflector bowl towards the back where the bulb can use it to reflect its light onto the road. Chrome housings make little difference in light output because of these projectors.
The only issues I could presume as to why your light is going all over the place is either because of some issue with the projector, or your current paint flaking off and the light beam from your projector hitting the flaky parts. (Thus, causing them to go all over the place) You should be good though after new paint. Id personally go ahead and get a clear lens swap as well as new bulbs to cancel out any other variables in regards to subpar light projection.
07-23-2016, 04:34 PM | #14 | |
Rep 1,689
I put some of their lights in my brothers car and they are very well done. He didn't go for a lot of options but they turned out sweet. |
07-25-2016, 09:25 AM | #15 | |
Rep 912
I even asked for a custom quote....and nope! |
07-25-2016, 04:40 PM | #16 | ||
Rep 1,689
07-25-2016, 05:14 PM | #17 | |
Rep 912
They were quick to respond which was nice. There are other shops who have quoted me, but charge more specifically because of how the housings are sealed. |
07-29-2016, 05:15 AM | #18 |
Rep 506
Drives: 2007 M Coupe
Garage List 2007 E86 Coupe [0.00]
2006 Z4 3.0si Coupe [6.00] 2002 330 CI [0.00] 2018 BMW 240M [0.00] 2007 M Coupe [10.00] |
I came across some guys here in Atlanta, when I started having issues with the seals and the dealers of course said you just need to purchase a whole new light assembly. You can buy them for about $950 each on ECS or you can do what I did which cost me about the same and they turned out great.
https://www.ecstuning.com/Search/Sit...2722/ES172922/ |
07-29-2016, 08:31 AM | #19 | |
Rep 1,991
Do you still have flashers in the housing? It looks like the entire hockey stick is a DRL in your light. |
07-29-2016, 11:39 AM | #20 |
Rep 506
Ask for Dee at Tintworld at the Chamblee Location. He has a guy who works inhouse and really knows what he is doing. They did my fog lights as well.
http://www.tintworld.com/locations/ga/chamblee-010/ We swapped out the turn signals for LED's. I went all out on them, but it totally changes the look of the car. |
07-29-2016, 11:42 PM | #21 | |
Rep 204
07-30-2016, 03:43 PM | #22 |
Rep 506
I went all out and they ran about 1800. I had the projectors, halos and swapped out the turn singles for the LEDs. They used a heat resistant paint and they guarantee it. The guys they have in-house only does headlights and guarantees his work.
I had broken factory seals and these were actually cheaper than replacing the assembly. |
