      05-03-2014, 05:11 PM   #1
SDCoupe
SDCoupe's Avatar
79
Drives: M Coupe
Headlight lens
Does anybody have advice for the best way to restore the fogged headlight lenses? Is some kind of polishing kit the way to go? Can the lens themselves be replaced? I did this for my e46 once and it was the best way to get crystal clear results. The polishing kit was less than perfect.
Thanks!
      05-03-2014, 05:42 PM   #2
M-Power M3
Retrograde
M-Power M3's Avatar
18
Drives: Bagged Z4
Unfortunately our lenses are not replaceable like the e46's (one thing I really miss about my e46's was how easy that was).
I had the dealership do their "restoration" on them when my GF worked there. I'm pretty sure they just wet sanded and buffed them. It came out pretty good but if you don't keep up on hand polishing them and waxing them they'll start to haze up pretty quick. I use plastic polish on them and a buffing pad then wax afterwards and it keeps them in good shape.
A replacement lens would be a god send though.
Bagged e85 Z4 | www.ogretrograde.com
Bagged TT 225Q SOLD - e46 M3 SOLD - W202 SOLD - e46 325i SOLD
      05-03-2014, 06:32 PM   #3
SDCoupe
SDCoupe's Avatar
79
Drives: M Coupe
Thanks for the advice. I guess I'm stuck with the buff and polish job. Too bad you can't just replace the lenses. Bummer. If anybody has a favorite kit/method that would be great to share. I've tried the Mequire's kit paired with a drill. It was OK.
      05-04-2014, 12:22 AM   #4
StickMon
StickMon's Avatar
Drives: 2006 MR
I had a lot of luck with 3M kit #39008 from Wal-Mart.
Then I put Headlight Armor over them and hit 'em with a good dose of 303 after every wash.
And I now back into my parking space at work so I'm pointing North.
Almost 2 years and still nice and clear.
      05-04-2014, 02:05 PM   #5
SDCoupe
SDCoupe's Avatar
79
Drives: M Coupe
Thanks for the advice! I'll check that 3M product out.
      05-31-2014, 10:25 AM   #6
SDCoupe
SDCoupe's Avatar
79
Drives: M Coupe
Worked great. Easy to use. I used a damp cloth to wipe the lens and also to unclog the sanding disks. I have enough product left over to do it again if I need to. Thanks for the recommendation!
      05-31-2014, 11:30 PM   #7
StickMon
StickMon's Avatar
Drives: 2006 MR
Thanks to ZPost. I picked it up on the recommendation of another forumite.
      06-01-2014, 07:22 AM   #8
Steeler
Steeler's Avatar
2429
Any before and afters?
      06-02-2014, 12:01 AM   #9
StickMon
StickMon's Avatar
Drives: 2006 MR
Mine was pretty much like the TV commercials.
Cloudy ---> Clear
      06-06-2014, 10:00 PM   #10
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
the key to restoring headlights is in the sealer you put on them afterwords. The meguiars kit comes with a nice wool buffer to use as the final step, but it has no sand paper and no sealer.
i've done half a dozen pairs of headlights by using the sealer and method detailed here:
http://www.autogeekonline.net/forum/...lant-idea.html
You can get everything you need for less than $30, it will look like it was professionally done, and it will hold up for years.
      06-21-2014, 09:48 AM   #11
SDCoupe
SDCoupe's Avatar
79
Drives: M Coupe
Here's a before and after. Sorry not the best photos. In the sun it looked much more apparent, but you get the gist.
      06-21-2014, 11:06 AM   #12
highbeamer
Overjoyed with the contents of my garage.
highbeamer's Avatar
Drives: Silverstone F82
I did the same thing (3M in a drill) to mine and was laughing at how well it worked. Laughing because it was perfect, and how often does something work better than expected!!
Would I be hijacking this thread if I asked if anyone has put the clear film over the lenses? Considering how hard it was to remove the small amount of factory hard coat/top coat remaining on that plastic, I can only imagine how vulnerable the new layer of plastic is that I just exposed. After I polished mine I read a pretty convincing article that claimed "sandpaper is the kiss of death" for these lenses. It's probably true but mine were way beyond ANY sealer type restorer. I know my clear bra works because I've seen rocks bounce off of it but I've never had it on my headlights.
      06-22-2014, 08:12 AM   #13
jdoublehcubed
Mechanical Engineer
Having restored a bunch with sandpaper, I can tell you that you will get 10x better results that the pic above. Of course, its also a lot more work.
I would stay away from clear film over headlights, because some Z4 owners have experienced cracking in the headlight lenses due to excessive heat build up.
If you want to seal them (and you should after polishing like that or they'll go back to being crap), use a 50/50 mix of spar urethane and mineral spirits. I know it sounds crazy, but it works awesome. Read the link I posted above for more info.
      06-22-2014, 12:08 PM   #14
SDCoupe
SDCoupe's Avatar
79
Drives: M Coupe
Here's a sunshine shot. Nice and clear. Plenty of product left over to do it again in a few years. For $20 and 20 minutes of time, it's well worth it.
      07-08-2014, 03:11 PM   #15
Huz-Z
Huz-Z's Avatar
"Headlight Armor" - is that an ArmorAll product?
Thanks!!
Huz-Z
      07-08-2014, 04:55 PM   #16
Dalecan
Dalecan's Avatar
102
Drives: Aston V8VS, F85 X5M, TVR, 128i
I've had the headlights covered with expel (the whole front end of the car) for several months now and nothing has happened to the headlights yet.
      07-09-2014, 11:44 PM   #17
StickMon
StickMon's Avatar
Drives: 2006 MR
Thanks!!
It's film.
I got the blue, which looked better than you would expect with the Interlagos paint. Not too ricey.
But after a year they're clear. Blue faded away, but they're nice and clean.
      07-10-2014, 12:55 AM   #18
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Me too...I've had Lamin-X on my coupe for over 4 years now. Other than the blue tint faded a bit, the lenses still looked perfect...none of the issues that everyone appeared to be complaining about
As a matter of fact, I was so impressed with the film on the coupe that I also put a set on my recently restored headlights (using the 3M kit) of my almost 11-years old X5.
      07-10-2014, 07:31 AM   #19
Huz-Z
Huz-Z's Avatar
Thanks guys!
Had a look for the 3M stuff last night but all I could see was the Meguiars headlight kit. Its got a polishing wheel that you attach to a drill - I don't know if its as good as the 3M product.
Huz-Z
      07-27-2014, 10:25 PM   #20
E86Z
Drives: 3.0si
I put my car through a harsh winter here with salt and rocks being shot up on the fogs and head lights. I restored the headlights and fogs with sand paper going from 1000, 1500 and 2500 then a compound and polish (megs 105/205).
Once they were clear and pretty much like new I wrapped them with laminx yellow for the fogs and clear for the headlights. Its been two years now, the whole thing is holding up great. I can polish the film to rid some scratches and I've recently noticed some oxidization on the edges that are not wrapped (precut left a few mm of gap). So the wrap has been very effective. I'll be doing it on all future cars.
      05-25-2015, 11:33 AM   #21
Huz-Z
Huz-Z's Avatar
I found one of the 3M kits a while back.
Any additional tips before I have a go at this later in the week?
Cheers!!
Huz-Z
      05-26-2015, 02:50 AM   #22
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
yeah mate, take your time, and as shown in the previous pics, make sure you mask off the paint areas. one thing though.. the liquid stuff your supposed to put on afterwards, never dried on mine. take some before and after pics Huz, then show us
Powered by
