      09-19-2011, 10:27 PM   #1
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
Stud conversion with close end nuts.
Will the turner motorsport's 75mm stud conversion kits work with close end nuts? What's the length of the close end nuts to use for 75mm stud with no spacers as of now?
I found some are 26mm, 35mm, 40mm and 48mm.
Anyone with 75mm stud use any of the above length open end nuts with installed picture?
thanks,
      09-20-2011, 01:48 AM   #2
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
I remember putting in 38mm Gorilla studs, and use Spoon lug nuts, which are considered "extended". Not sure how long the Spoon lugs are exactly.
Anyhow, g'luck man
I was of absolutely no help to you
      09-20-2011, 06:22 AM   #3
Beedub
i use the turner 75mm with kics r26 composite nuts open ended..... such an awesome combo which not only makes life much easier, it looks awesome as well.....
the 75mm nuts WILL NOT work with a closed end nut as the top half is like a smooth donut end with a hex end.....
just use an open ended nut much better in everyway!
      09-20-2011, 09:49 AM   #4
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
Do you have a picture of them installed? Does the 75mm stick out of your R26 quite a bit, if so how much? If you can measure it, it'll help me a lot.
BBS set seems to use 80mm with close end nuts.
I don't like the look of open end and I don't use spacer for all 3 of my wheel sets.
thanks,
      09-20-2011, 09:51 AM   #5
Beedub
when i get home ill post you some deailed pics, the rear stick out slightly... the fronts with a 12mm spacer are flush...
      09-20-2011, 09:55 AM   #6
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
So I guess I can assume. 12mm spacer + 26mm nuts = 38mm flush. So 40mm+ closed end is the answer?
I'll wait for your detail picture then ...
thanks Beedub,
      09-20-2011, 10:21 AM   #7
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I agree with Beedub.
The Kics are great lug nuts.
I'm using 90mm studs, so I use the R40 which are longer and hide the stud entirely.
I love the floating seat on these as well; wheels torque down more evenly and don't damage the wheel nut seats.
      09-20-2011, 01:28 PM   #8
Beedub
thanks Beedub,
just for you...........
POW..... cant get any more than that......
      09-20-2011, 02:06 PM   #9
mfanatic325
///M-fanatic
Taiwan
193
Want your AP BBKs
      09-20-2011, 04:25 PM   #10
Beedub
Originally Posted by mfanatic325 View Post
Want your AP BBKs
lol they are AWESOME!!!! after a full day of driving with VT2 power on the track these things were rock solid..... the rotors went bright blue!!! They are the best brakes ive every experienced... ever...... the only braking system ive felt with as good feel was a 997 GT3 RS..... ;-)
      09-20-2011, 08:51 PM   #11
twboy1999
Drives: 1994 honda accord
for my bbs lm
i am running 44mm length studs
i know some ppl run 60mm.
      09-20-2011, 10:06 PM   #12
acceleration
No_Country
21
Drives: G87
Originally Posted by twboy1999 View Post
for my bbs lm
LOL...what are you doing on zpost
      09-21-2011, 02:20 AM   #13
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
Beedub,
Thanks for the detail pictures. It shows me what I think I can accomplish.
75mm is way too long for my purpose w/o spacers. 75mm - 12mm spacer = 63mm.. Seems like 30mm closed end will work with 60mm studs with room to spare.
If I go with 60 mm, I can use 30mm closed or 26mm open for flush look...I'm now onto the hunt...
What's a good 60mm stud set if anyone knows? Maybe this? http://www.ecstuning.com/Volkswagen-...II--2.0/ES202/
      09-21-2011, 04:47 AM   #14
Beedub
Beedub,
im wondering??? does the turner 75mm studs INCLUDE the non threaded bit at the end?? im wonder if the whole stud may actually be longer??? either way these studs are awesome and the nuts are a thing of beauty...........
      09-21-2011, 06:43 AM   #15
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
The pic on Turner is hard to read but it looks like they spec the same as this pic from R.Eng.
      09-21-2011, 11:51 AM   #16
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
Thanks InTgr8r for the picture as I was wondering the same.
From your pic, 64mm is exposed after stud installed into the hub.
assuming Beedub using 12mm spacer is flush with 26mm nuts
wheel mounting width = 75mm - 12mm - 26mm = 37mm
60mm stud - 37mm wheel = 23mm
Should I conclude that 60mm H&R studs with Kics 35mm close end nut should fit with room to spare? How many turns do one need to safely secure a nuts to studs?
Studs - http://www.ecstuning.com/Volkswagen-...II--2.0/ES202/
Nuts - http://www.evasivemotorsports.com/me...tegory_Code=L1
      09-21-2011, 02:25 PM   #17
SmartBastard
Stupid as shit
SmartBastard's Avatar
Austria
25
Drives: '08 M Coupe
Thumbs up
Very nice setup you got there Beedub!
      09-21-2011, 02:32 PM   #18
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
It's actually less than that.
The rotor hides part of the threadless shank in the middle.
      09-21-2011, 02:50 PM   #19
Beedub
+1
      09-21-2011, 03:02 PM   #20
Beedub
thanks, its taken me years to build this car up...... much much more coming soon ;-)
      09-23-2011, 11:26 PM   #21
suprtran
suprtran's Avatar
111
Drives: BMWs
Question Help with BBS lugs!!
So I bought the BBS red lug kit and have been researching and contacting numerous vendors (even BBS USA themselves) to see what types of studs I need. Can't seem to get a for sure answer from anyone.
Does anyone know what I need in terms of the thread size and stud length?? I plan on running 10mm spacers in the rear.
This is the kit I bought:
      09-24-2011, 05:21 AM   #22
Beedub
wow those BBS nuts are gorgeous..... unfortuntly i cant help you with lengths, im sure the other guys will be in shortly to help you out :-)
