      01-22-2014, 12:25 AM   #1
dschultz
dschultz's Avatar
26
Drives: 07 Z4MC
Why are my brakes cooked?
Help!
My front brakes seemed to be chattering a bit so before I take them to Laguna Seca this weekend I decided to have my mechanic check them. They said they had been badly overheated and that the calipers needed to be rebuilt. I trust these guys and no reason not to believe them. I have all of 4 track days in this car. My last track event was at Thunderhill in November. I never felt any brake fade, I don't think I was particularly hard on the brakes, I am certainly not the fastest or more aggressive driver out there. I am very careful on the cooldown lap and do a couple of laps around the paddock after every session before parking. So... what gives? Is it my driving style? Braking style? Z4MC, ATE Blue brake fluid, fresh before the last event. ... the only mods are a cup holder and stubby antenna!
      01-22-2014, 12:42 AM   #2
i2ichal2dZ4M
Drives: 2007 BSM Z4MC
explain chattering, definition/symptom may be differnt between others. did you try to rebead the pads?
2007 BSM Z4M Coupe - 18" VOLK TE37 - 18" Apex ARC-8 - GC Track/Street
      01-22-2014, 12:52 AM   #3
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Originally Posted by dschultz View Post
Help!
Lots of folks here with lots of track days, not many with cooked brakes. So, .
The most common cause of chatter, vibration, or "warped rotor" feel is uneven pad deposits. Floating rotors don't warp (very hard to do). Uneven pad deposits, however, are easy to acquire. There are numerous causes. The most common would be using the wrong pad for the application (e.g. stock pads or low MOT pads, etc.).
Not that I'm saying your mechanics are wrong, but the last person I know with a Z4M who "cooked" their brakes and had to rebuild really cooked them--as in they were smoking and pretty much on fire. And a rebuild in that case was really replacing the seals, not new pistons. While it's possible a caliper rebuild is needed, it doesn't sound like you've gotten the brakes hot enough to do that. Perhaps the prior owner did?
Even if you need a rebuild, that may be an independent issue from the chatter, which I'd again attribute more to deposits. Deposit issues are easily fixed with a re-bedding of pads in most cases, or, swapping out for an aggressive "cleaner" pads like hawk blues for a short period. Rebuild is more about safety IMO, and, that's if really needed.
If you're using stock pads, you might want to move up to a higher MOT pad, re-bed, or scrub the rotors as noted in the link, or some combo. No one right answer here, it depends on the cause.
      01-22-2014, 07:37 AM   #4
z3papa
Drives: 11 E92 M3 ZCP, 07 335i
I'd agree that most likely it is warped rotors or pad deposits. Braking technique has a big impact on rotor wear/heat. I don't know your style but I tend to be on and off brakes very fast since I try to minimize the time from brake to accelerator while getting to the threshold of optimal braking as quickly as possible. While not for the feint of heart, this minimizes transitional lift issues, and puts far less stress on the rotor than a slower progression of braking some implement much as if they were driving on the street.
Sold 2011.5 E92 M3 ZCP.
      01-22-2014, 10:48 AM   #5
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
I'm willing to bet that it's just your brake pads *bleeping* on your rotors, causing the terrible brake feel.
I'm also willing to bet that the shop you're going to just wants to make a quick buck...stock calipers can't possibly need rebuilding so soon
For the record, OEM rotors are damned good. It's the OE fluid and pads that can't stand up to even medium track use. But you knew that already
BBKs might be on your shopping list down the road if you seriously want to get into tracking and know that you'll be going several times a year. They're quite expensive, but well worth it. The peace of mind you get from not having to worry about any of your braking while on track is beyond anything words can describe; simply blissful
      01-22-2014, 11:21 AM   #6
The HACK
The HACK's Avatar
1821
It's either the cup holder or the stubby antenna.
You didn't say what sort of brake pad compound and tires. Those could go a long way to figuring out what exactly is wrong with the brake system.
As for the rebuild recommendation by the mechanic, it's entirely possible that the dust boot on the caliper has melted under the extreme heat introduced by tracking, especially if you go to very brake intensive tracks like Laguna Seca. I've noticed on the OE calipers, when the pistons are fully retracted (i.e. when new pads were installed) sometimes the boot does not retract or "tuck" the right way, causing it to come in contact with the pad backing plate. Imagine the heat from the brake system that is capable of making solid iron glow red...It'll make minced meat out of some rubber boots.
Ever since "new" I've had to double check my dust boots when I put new pads on, and make sure that the boots are tucked right so as to not come in contact with the pad backing plate. That problem has mostly been alleviated now.
      01-22-2014, 07:26 PM   #7
dschultz
dschultz's Avatar
26
Drives: 07 Z4MC
Thanks all. To answer some of the questions:
Pads are Axxis/PBR MetalMasters. I installed new rotors and pads before tracking the car. They have 4 track days on them (and are barely worn).
I haven't confirmed exactly what the shop did, but I believe they just replaced the caliper seals and boots. Will know more tomorrow.
Full disclosure... when I replaced the original rotors I noticed some minor damage to the caliper boot. It looked like a small nick, no outright melting. But I've never seen badly overheated brakes before so I may not recognize it if it's not really obvious. That's one of the reasons I wanted them to do a thorough inspection in the first place. (The recent chatter was the other.) So it's possible that the damage was from PO. Dunno.
I trust these guys, they've always done right by me. They also race bmws (nasa I think) and have done my track inspections for free (even when I *didn't* need additional work done!)
The chattering is recent, started happening long after my last trip to the track. It's a mild high frequency chatter, not what I would typically associate with warped rotors. Kind of "gravelly". Almost like ABS pulsing, but I'm pretty sure it's not ABS. The deposit/glazing theory sounds likely. I haven't tried to rebed the pads since it started happening. I'll give that a shot if it's still happening.
I guess I'll see what happens at Laguna Seca on Saturday. I'll pay extra attention to how I'm transitioning on/off the brakes. I've never had an instructor point out poor braking technique to me, but perhaps that's just because there are so many bigger issues.
Thanks for all your help.
@mfanatic325 -- "brake pads *bleeping* on your rotors"? Huh? Haven't heard that one before!
      01-22-2014, 07:29 PM   #8
dschultz
dschultz's Avatar
26
Drives: 07 Z4MC
Oh... tires... Michelin Pilot Sport PS2s. No R-compounds yet.
      01-22-2014, 10:25 PM   #9
mfanatic325
///M-fanatic
Taiwan
193
I've had many sets of OEM pads *bleep* on my rotors after Laguna track days. This was all while I was still under warranty of course, and could get free brake pad replacements. The local stealershits got to know my car REALLY well; as they'd see my car in for another set of pads every month or so two years ago
      01-23-2014, 02:20 AM   #10
Finnegan
Finnegan's Avatar
Rubber boots--totally possible. Sounds like the mechanics know their stuff, so, I think it's all good. The chatter is an independent issue and it's a good bet it's pad deposits.
There's this guy on the forum here who has a great piece on braking techniques. Have a look. I found applying what I learned very helpful in both being consistent and getting the most out of managing my brakes. (Btw, that guy is "The Hack" .)
