      11-25-2009, 12:22 AM   #1
E85_Z
Drives: 2005 Z4 3.0
question about the kw and stoptech`
i already have a set of Kw v3 and stopteck 4p BBK on my 2005 z4 3.0i.
and i am gonna sell it (or trade in) for a m coupe.
the question is, can i still use the kw and stoptech on the m coupe.
One of my friends, he is a mechanic working in BMW dealership, says i can use them. But, i checked the website of kw, they have differnt parts no. for non-M and M.
Anyone have experience on this? What should i do?
THX
KW v3 / Esienmann Race / STOPTECH
Z4 PARTS OUT
http://www.zpost.com/forums/showthread.php?t=320129
      11-25-2009, 01:10 AM   #2
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Your mechanic friend should be shot.
      11-25-2009, 12:20 PM   #3
daveysew
daveysew's Avatar
Drives: '91 318is/'05 Z4 SC/'18 440ix
O-cha is a little over the top but is making the correct general point. Both are different parts (and part numbers) for M and non-M cars and don't transfer between the 2 cars. Even though aesthetically the cars appear the same they are very, very different when you get into the mechanicals.
I am curious what BMW dealer your friend works at? Dealer tech's often have little knowledge of aftermarket parts for BMW's as they are trained only on factory parts and as a matter of course only recommend you use OEM parts from BMW. As such dealers generally aren't a good place to have aftermarket modifications done to your BMW, specialty shops dealing in BMW performance / racing are generally a better way to go.
dave
      11-25-2009, 12:28 PM   #4
E85_Z
Drives: 2005 Z4 3.0
thank you for let me know the truth, bro.
u have a sick IR mcoupe,.
Z4 PARTS OUT
      11-26-2009, 05:57 AM   #5
AWM3
BMW Fan
AWM3's Avatar
11
Drives: 2012 E92 M3, Alpine White
The brakes certainly could not be used. But the springs and shocks might work, with minor modifications. I haven't taken these apart myself, but I would guess that the main difference would be in the front upper strut mount. I don't see why the bottom of the front mounting would be any different, or anything in the rear. Then it gets to a matter of shock and spring tuning for M vs. non M, which might be a matter of personal taste instead of a fitment issue.
      11-26-2009, 10:24 AM   #6
CalRick
Drives: '15 M235 & '95 M3 tracktoy ;
2016 X3 Xdrive28d  [0.00]
2015 BMW M235i  [0.00]
1995 BMW M3  [0.00]
The brakes might be usable/adaptable, but wouldn't be an upgrade from the OEM brakes. Stoptech specs 355 or 380 mm brakes for the M but 328 or 332's for the standard Z's - about what the OEM M is. If you want to upgrade your brakes your best bet is to sell off your Z BBK and buy the correct one for the M.
      11-26-2009, 10:18 PM   #7
E85_Z
Drives: 2005 Z4 3.0
That is true, even i can use it, it will not be an upgrade.
For the KW, i will ask more mechanican.
thank you for all of your help!!!!
Z4 PARTS OUT
      11-27-2009, 02:10 AM   #8
GP20
Drives: Z4M, F80 M3, 991.2 GTS
Don't bother asking your mechanic about the suspensions. O-cha is right. They won't fit. The non-M uses E46 style front struts. The M uses E36 style front struts. Completely different animals.
2019 Porsche 911 4 GTS
2016 BMW M3
2008 BMW Z4M coupe
      11-27-2009, 06:11 PM   #9
E85_Z
Drives: 2005 Z4 3.0
hey, buddy. u finally come.
i was looking for u all the time. i saw ur signature be4, i know u have had 4 Z4s, i am sure i have the experience for it.
thank you so much, bro.
Z4 PARTS OUT
      11-27-2009, 09:49 PM   #10
AWM3
BMW Fan
AWM3's Avatar
11
Thanks for clarifying that. I have never seen the front suspension on a regular Z4. Sorry for the bad information.
