      11-22-2009, 02:35 PM   #1
jra
Drives: 2005 z4
attempting to shed some lbs
anyone know the weight of the manual non heated seats and the manual non heated m seats?
      11-22-2009, 02:54 PM   #2
MVF4Rrider
PCA, BMWCCA
MVF4Rrider's Avatar
102
Drives: 997S, MV Agusta F4, E46 M3
How much do YOU weigh? And whatever pounds you lose in the seats you'll never be able to detect a performance gain so why bother???
'08 Carrera S 6MT Guards Red/Black ext leather, Carbon fiber pkg, sport exh, sport chrono +, PASM, Nav, Bose, 19" forged turbos, red tranny tunnel
'07 MV Agusta F4 1000 R 1+1, Corse Red/Silver, RG3 race pipes and factory race ECU
      11-22-2009, 03:11 PM   #3
jra
Drives: 2005 z4
I knew that would be the first response I found a pair of manual non heated m seats.
      11-22-2009, 03:35 PM   #4
The__J__Factor
The__J__Factor's Avatar
Australia
88
Drives: ///M Coupe
I think someone said the stock electric m seats weigh around 50lbs?
Swapping to some Recaros or similar would save a good deal of weight. Probably one of the best weight savings we can do.
Then if thats too much work a lightweight batt and lighter wheels/tires would also cut down a fair bit.
135i N54 manual
MR-S with a 2zz swap and mods Sold
EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold
Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold
      11-22-2009, 04:27 PM   #5
jra
Drives: 2005 z4
lw battery is a good idea, a forum member is helping me out with the wheels (ssr comp h's), would like to get a uuc bbk before the end of the year as well
      11-22-2009, 05:54 PM   #6
MVF4Rrider
PCA, BMWCCA
MVF4Rrider's Avatar
102
I'm glad you're sticking with the same seat. Racing seats are great for the minimal time you need them. Getting in and out of them is no fun whatsoever, even if very trim like me. I love my seats, and appreciate the power option for the perfect adjustment.
      11-22-2009, 05:56 PM   #7
BlackSapphireZ
Drives: 22 GLE 53 Coupe
non-powered seats are significantly lighter
but heated or non-heated should be a difference of ounces not pounds
2022 GLE 53 Coupe
      11-23-2009, 05:56 AM   #8
rc'Z
Drives: 2009 335i Convertible
A good way to see if weight reduction is going to be more than just 'locker room' talk is to go to the track, road or drag, which ever you do. Make a couple of runs at stock weight. Then put a 10 lb bag of something in our car and make a couple of runs again. Compare times. Put a 20 lb bag of weight in your car and make a couple of runs, compare times. The time you loose by adding the weight should give you an idea of the time you might gain by reducing your stock weight the same number of pounds. Good luck.
      11-23-2009, 08:20 AM   #9
Huz-Z
Huz-Z's Avatar
I've never raced so this may be a totally stupid suggestion; I apologize if it is.
How about if you run with the gas tank only filed with what gas you need for each run? I assume gas weighs about the same as water, which is 1 kilogram per litre, or almost 9 pounds per gallon.
So for example, I think the car has about a 50 litre tank. If you only half fill it, you drop the car's weight by 25 kg or 55 pounds. Only quarter filling it takes that to about an 80 pound weight reduction.
Again, sorry if this is already common practice.
Huzz
      11-24-2009, 05:12 AM   #10
rc'Z
Huzz
That is a good trick also. Might want to take an extra can with you to get you to the nearest station after the run.
