      09-29-2007, 04:52 PM   #1
ricerx1
Drives: 2016 M4
Volk Progressive ME Finally Came in
Wow only took 2 months.
On some Azenis RT-615 Rubber
18x8.5 +36 245/40
18x9.5 +20 275/35
Rubs a bit in the back but its probably due to the Azenis having a stiffer sidewall and running a bit wide. But most likely it won't rub with the same sizes with a different brand of tire. Car is lowered on H&R springs.
But those wheels sizes.. are perfect if you don't want the wheels to poke, but I've heard more agressive offests will fit the Z4M
These are the same wheels inTgr8r got but in a smaller size I think.
      09-29-2007, 08:45 PM   #2
Drives: M2 Comp
Lookin' good
      09-29-2007, 10:03 PM   #3
Feyd
Feyd's Avatar
346
Drives: a DEEZZULL
hot!!
      09-29-2007, 10:13 PM   #4
Artz 330
Drives: Z4M, 335i, 135i
2006 330i  [0.00]
nice! what do they weigh a peice. I am on 615's too. I Like them alot. My 255's look like 265's lol. I have 235 fronts and they weigh 2lbs more each than the stock tires.
      09-30-2007, 11:06 AM   #5
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
Drives: 2007 M Coupe
Nice. Not sure about the sky blue brakes, but the rest is hot.
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int.
Best Website EVER!
      10-01-2007, 06:59 PM   #6
ricerx1
Drives: 2016 M4
Acutally I have no clue about the weight. I was too excited and didn't weigh them. I like them alot also for the price they're great tires.
      10-01-2007, 11:53 PM   #7
Waldorf
Black Opps field agent
Waldorf's Avatar
Drives: 135i M
Actually, if you look at it a few times the blue calipers look really good with the car's grey.
:rocks: Montreal to Vermont OktoberFast cruise. :rocks:
http://www.e90post.com/forums/showthread.php?t=79557
      10-02-2007, 06:39 AM   #8
Drives: M2 Comp
IIRC the 18s are < 20lb, my 19s (8.5 & 9.5") are 22 & 23lb per wheel.
They're a 1 piece forged & very strong.
They'll take quite a bit of daily drive punishment.
      10-02-2007, 06:55 AM   #9
ronn888
ronn888's Avatar
15
Drives: 135i
the car is hot! The coupe really looks great in this color!
      10-02-2007, 04:12 PM   #10
ricerx1
Drives: 2016 M4
Yea, I've always had great luck with Volk 1pc Forged wheels, no bending, cracking or flaking. Thats why even on this car I decided to go with them again.
inTgr8r is it just me or what. But I think the wheels look better a bit dirty. haha
      10-02-2007, 05:01 PM   #11
apexstrafer
Drives: Z4 M Coupe
Wow, nice setup. I especially like the brakes, are those direct bolt ons from Rotora? Also, how do you like the Rt615s on this car? I only have 200 miles on my new Z4MC and I already hate the stock Continentals. I always run the RT615s on my Evo and love them.
      10-02-2007, 06:01 PM   #12
ricerx1
Drives: 2016 M4
Yea they're direct bolt on. Rotora called me for a test fit, so sure why not. I think they're also going to be releasing a Caliper Only upgrade kit soon. Since the stock rotors are big enough but 4piston caliper, larger surface area pads, and quick easy pad changes will be an improvement over stock. When that comes out I might sell the BBK and just get the caliper upgrade.
615's are ok on the car. I kept lowering tire pressure the whole day i was at the track started at 38. And it just wasn't feeling right. I know the door says 30psi, but I was also worried if i go 30 or lower I might knock off a bead on the track if I went into the dirt. Maybe next time i'll just man up and do it.
Try Kumho MX they're another well priced street/track tire.
The stocks tires suck ass. I attribute the stock tires to the reason why every magazine liked the Porsche Cayman S better. But thats just me
      10-02-2007, 06:30 PM   #13
apexstrafer
Drives: Z4 M Coupe
Wait, you went down to 30psi hot? That's way too low, you should be 38-40 hot. Cold temps don't really mean much, adjust em after doing a few laps, if you're not doing that already.
How does the turn-in feel? Can you feel the stiffer sidewalls or is the suspension not tight enough for it to transmit to the driver?
      10-02-2007, 06:44 PM   #14
ricerx1
Drives: 2016 M4
I my last target was 35 hot. I started at 38 cold.
I guess I shouldn't try 30psi then, I just heard that its a good starting point to use the pressure marked on the door.
Suspension wasn't tight enough you can feel the shocks giving. I think some hardened upper mounts will help or some pillow ball mounts.
      10-02-2007, 07:47 PM   #15
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
I dunno man. To each his own I guess. I think my brakes could use another coat of paint since the black is coming off. I'd have to go either red, or really red.
Best Website EVER!
      10-05-2007, 12:54 PM   #16
Evoking
Drives: Z4M Coupe
Great looking car. What about all of this talk about H&R's making clunking noises and being too bouncy with stock shocks? Do I really have to get coil-overs to lower properly? I've used H&R on my NSX's with no problems.
http://www.cardomain.com/id/amacc
      10-20-2007, 05:34 PM   #17
giem
giem's Avatar
Drives: BMW
keep the rice on the rice cars, ricer
      11-01-2007, 01:29 PM   #18
RussRamz
M Slut
RussRamz's Avatar
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
+1
38-40 is a great target temp when HOT. 30 is way too low--even dangerous. If you really want to measure accurately, get a pyrometer and measure the temp across the width of the tire when hot. Google search tire pressure and pyrometer and you'll understand this a little more.
Good luck!!!
      11-01-2007, 11:22 PM   #19
KevinC
your average JAMF
KevinC's Avatar
'21 M2 Comp
'19 Golf R
      12-18-2007, 06:37 PM   #20
Drives: M2 Comp
like this???
      12-19-2007, 12:19 AM   #21
OH FO SHO
OH FO SHO's Avatar
15
Drives: z4
badass
'03 3.0i z4: tiag ext., red int., SMG, sport, premium
HAMANN exhaust l HAMANN front lip l 19" Miro type 366 (HAMANN edition race replicas) l RPI air scoop l KW v2 coilovers
-*MY PICTURE THREAD*-
      12-19-2007, 01:58 AM   #22
sketchmunky
sketchmunky's Avatar
Drives: 2008 Z4 3.0si Coupe
I'm really feelin' them!
