      09-23-2008, 03:38 PM   #1
double0jimb0
Drives: Z4 M Coupe
Winter Wheel will fit M3 Comp Package but not Z4 M?
Tire Rack lists two winter wheel options for the M3 Competition Package (ZCP), Sport Edition F5 and Borbet Type TS; yet only one for the Z4 M Coupe, the Borbet Type TS. Atleast one user here has successfully done the Borbets.
Link: http://www.tirerack.com/snow/WinterW...&Qty8=4&Qty9=4
Think the Sport Edition F5 will work on Z4MC? If a wheel/tire fits the M3 ZCP it should fit a Z4 M right?
I would much prefer the Sport Edition F5s over the Borbets since they dont require spacers or lugs, and are cheaper. I'm not worried about TPMS.
Thanks much!
      09-24-2008, 01:56 AM   #2
chris719
Drives: '08 M Roadster
You know, it seems like it would fit.. the issue with most 17s are brake clearance, so if it clears the ZCP brakes it should clear the M brakes. I'll probably check with TireRack soon and see, since they look better than the Borbets.
