04-13-2014, 06:24 PM | #1 |
Rep 223
DSP stereo sound quality...
...is not good. I have the '06 luxury package stereo, and I've finally had a chance to play some CDs and I gotta say, it is pretty terrible. The Harmon Kardon system in my '05 330i sounded hugely better that this. My other 2 current cars, a base Mini Cooper, and base Passat both sound much better too.
I am admittedly an audiophile, but but this is pretty bad even by non-audiophile standards. This sounds like a $60 boom-box. I was going to do the Bavsound speaker retrofit, but now wondering if I should just pull and replace the whole system. But I really like to just listen to the engine, so not sure if I want to go to hat length. |
04-13-2014, 08:04 PM | #2 |
Rep 2,541
You can code the DSP to E85 spec and get some more punch on the bass. Or a combination E85 and E86 coding. There are 55 filter banks. Do you have the EQ? Making changes there can result in better sound. I'm just saying there are ways to get some better sound out of the stock system system.
04-13-2014, 08:09 PM | #3 | |
Rep 820
Drives: 2007 Z4MR silver grey
Update: My bad, I see now you have a coupe. For some reason BMW changed the coding for the coupes. You are correct, they sound horrible. I had a good friend here in town who had a coupe, and he was amazed at how nice my system sounded compared to his, with just the tweeter replacements and adjusting it with the spectrum analyzer. |
04-14-2014, 11:28 AM | #5 |
Rep 370
Drives: 2007 BMW Z4MC
Garage List 2007 BMW Z4MC - Sold [7.66]
2006 330ci ZHP [0.00] 2000 Porsche Boxster S [0.00] 1972 DeTomaso Pantera [9.50] |
As a fellow audiophile, I completely understand your dilemma. I went with the Bavsound upgrade, and it's an improvement, but certainly not what you are looking for. Since I have the nav system and all, I wasn't willing to do the full "rip and replace" in my Z4MC.
I did that, however, in my Boxster - went with a Focal/JL/Alpine system that is REALLY nice, but starts to get into big elephant $$...does sound amazing tho!
[SIGPIC][/SIGPIC]
04-14-2014, 12:01 PM | #6 | |
Rep 223
04-14-2014, 12:03 PM | #7 |
Rep 370
I would NOT go with bestbuy. Bunch of high school kids that don't know what they are doing. I went with a custom installer for my Porsche, and they did a great job. Definitely look at their work, read the yelp reviews, and do your research before selecting...
[SIGPIC][/SIGPIC]
04-14-2014, 12:28 PM | #8 |
Rep 223
Thanks. I've found a few shops here is SF that look pretty good.
04-14-2014, 12:31 PM | #9 |
Rep 370
Ah, didn't read that you are in the bay area!
I used these guys for my Porsche -they did a great job: Ams Car Stereo & Window Tinting 3910 Stevens Creek Blvd San Jose, CA 95129 planning on getting the Z tinted there as well...
[SIGPIC][/SIGPIC]
04-14-2014, 12:58 PM | #10 |
Rep 223
Thanks. Do you think it would be possible/advisable to keep the factory head unit and just replace amps & speakers? I don't care about retaining Nav, but want to keep the understated stock look of the dash. I think an after marked head would really stand out.
04-14-2014, 01:39 PM | #11 |
Rep 1,107
Sorry to be the bearer of bad news, but the head unit for DSP with NAV systems puts out line out analog signals and the volume level is performed AT THE AMPLIFIER which receives its control signal from the head unit via the digital K - Bus. So, your choice is to either replace the head unit or have some type of multi-channel line out converter installed on the back end of the OEM amplifier.
04-14-2014, 01:43 PM | #12 |
Rep 223
04-14-2014, 01:57 PM | #13 |
Rep 370
Give him a call - He has done a lot of high-end cars, and really gets the install can and can'ts. They have done a few of the 49er cars there...
[SIGPIC][/SIGPIC]
04-14-2014, 01:57 PM | #14 |
Rep 5,327
i think its great !! lmao..... I'm no audiophile , but i do like to crank the music.... seems more than adequate for my needs :-) the car is knocking on nearly a decade old.....
04-14-2014, 02:03 PM | #15 |
Rep 2,860
You have the roadster, so there's basically nothing to complain about...from what I've found. It's a different story for us coupe guys
04-14-2014, 11:14 PM | #16 |
Rep 2,541
The coupe guys can code to E85 spec. AFAIK the systems are identical with the exception of the coding. There are like 60 differences in the coding between the E85 and E86.
04-15-2014, 04:03 AM | #17 |
Rep 820
JL Audio 3/4" Evolution C5 Series Silk Dome Tweeters. They are more efficient than the factory tweets, I had to crank down the EQ for the 5K and 12K sliders when I ran the pink noise through the system. The aluminium midrange speakers are actually not that bad. Replacing the tweets opened up the top end quite a bit.
04-15-2014, 08:35 AM | #18 | ||
Rep 223
04-15-2014, 04:55 PM | #19 |
Rep 219
Drives: 2007 BMW Z4 M Coupe
Garage List 2000 Volve S70 se [0.00]
2000 Triumph Dayton ... [0.00] 2007 Husqvarna TE250 [0.00] 2002 Ducati Monster ... [0.00] 2007 BMW [0.00] |
I was contemplating the Bavsound speakers, too.
At least I know it's not the final answer. |
04-15-2014, 05:22 PM | #20 |
Rep 2,541
Rename the attached file to FSW_PSW.TRC and use NCSExpert to write the file to the DSP module. Read up on cables, software and how to do it here. It's actually very simple once everything is set up. Also, once you have the setup, there's plenty of other stuff to custom program as well.
E86 DSP_E85.C02 FSW_PSW coded to E85.TRC.txt |
04-15-2014, 07:44 PM | #21 | |
Rep 2,860
Now...are there anyone in SoCal that has NCSExpert and is willing to help out a fellow Couper to get this programmed Willing to pay with beers |
04-15-2014, 09:03 PM | #22 | |
Rep 223
